Cryptographic Services - Chrome ne nalaga strani
kajetan ::
To težavo imam že 1 leto.. Namreč Chrome mi ne nalaga strani če ne izklopim storitve: Cryptographic Services. Problem je da se ta servis sam nazaj vklopi. Opazil sem da ne moti samo Chrome ampak tudi platforme kot so Origin, Steam in praktično vse kar ravi povezavo do interneta.
Je kdo imel že to težavo?
poskusil sem to pa ne deluje - mogoče kake pol ure:
sistem nočem updatati, ker si ne morem privoščiti še drugih problemov, ki pa jih na žalost windows update vedno prinese s sabo. Windows je drugače stabilen.
Kateri win ?
Provides four management services: Catalog Database Service, which confirms the signatures of Windows files and allows new programs to be installed; Protected Root Service, which adds and removes Trusted Root Certification Authority certificates from this computer; Automatic Root Certificate Update Service, which retrieves root certificates from Windows Update and enable scenarios such as SSL; and Key Service, which helps enroll this computer for certificates. If this service is stopped, these management services will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start.
Kaj ima Cryptographic Services povezave z updejti ?
  • spremenilo: sbawe64 ()
Problem z ramom ali diskom? Prosim za nasvet.
111578 (1480) Duhec
Mednarodna prodaja!
425944 (5297) razzor
Ponovna poplava popravkov
Oddelek: Novice / Varnost
203348 (3348) andrej
Kako izklopit Windows MESSENGER ?!
172021 (1664) krucymucy
Pozor, resna pomankjlivost v WINXP
Oddelek: Programska oprema
152440 (2101) andrej
