vprašanje o podnapisih
Eki ::
Čao
Za svojega otroka sem snemal risanko sedaj sem pa odpru ta fail in našel to:
ow to play vobsub subtitles...
To play these subtitles you need the program vobsubs.
Get it here: http://vobsub.edensrising.com/vobsub.php
Install the program.
Unpack the rarfile, you now have two files, idx and rar.
Put these two in the same directory as your avi file.
All three files must have the same name.
So you have:
filename.avi
filename.idx
filename.rar (containing a subfile)
Start up your movie and vobsub will load automatically.
Notice the green arrow in your system tray, click it and you can
choose your preferred language.
Burn the idx and rar with the movie. As long as you do not unpack
the rar, it will fit on a 700mb cd.
Thanks for downloading this movie from warez.rozica.com
Enjoy! :D
Zanima me če mi zna kdo pomagati kako to naložiti in pa predvsem kako to narediti. jst sm probal odpreti to internetno stranico pa ne gre .Vsaka pomoč dobrodošla
Hvala
by moderator: mal sem ti naslov dopolnil, da odraža vsebino teme
  • spremenil: Predator ()
Predator ::
imaš film kr_en.avi in kr_en_velik.rar kjer so podnapisi;
najprej downloadaj in instaliraj vobsub ;
potem odzipaš kr_en_velik.rar in dobiš dva file-a: kr_en.idx in kr_en.rar;
daš stvar v isti folder kot imaš film tako, da so potem te file-i skupaj
kr_en.avi
kr_en.idx
kr_en.rar
( imena morajo biti ISTA, če ne se vobsub ne bo zagnal )
ko boš zagnal film v kateremkoli playerju se ti bo avtomatsko zagnal še vobsub ter naložil podnapise
Integrirani podnapisi
Oddelek: Zvok in slika
3610183 (7916) dzinks63
[DivXviD] filmi na Divx predvajalnikih brez problemov
2123721 (10722) bbbb
Pretvorba iz DivX, XviD v DVD
72534 (2442) raptor1
Kako convertirat DivX v VCD??
415125 (3761) jabe
SVCD + podnapisi
Oddelek: Programska oprema
111570 (1430) bastadu
