Novi biosi za Epox 8KRA2+ in 8RDA** ...
rap3r ::
Novi biosi za Epox plate:
Model: EP-8KRA2+
BIOS: KRA23828.BIN (A100)
Date: 08/28/2003
Fixed:
1) Add to show AppleBred CPU information at screen.
2) Add "Power_On by on Board LAN" control in menu item.
3) Patch some RAMs hang at POST 29H when Load Fail-Safe Default in the BIOS Setup.
4) Enhance the function of pressing Insert key to safe boot, set memory timing by SPD.
6) Always enable VT6420 device if the CMOS checksum error.
7) Fixed install SATA driver on Windows ME, blue screen after reset.
Model: EP-8RDA3+
BIOS: 8RD33827.BIN (1300)
Date: 08/27/2003
Fixed:
1) Add "Auto_Precharge_Selectable" option to patch some DDR unstable issue. (i.e. A-DATA DDR400 / TwinMOS DDR 400)
2) Add support MagicScreen utility function.
3) Reduce code size for aggressive ROMSIP table. Enabled CPU Interface item.
4) Remove Reset Configuration Data item, because the BIOS doesn’t support ESCD.
5) Added to show AppleBred CPU information at screen.
6) Solved CPU warning temperature/Shutdown temperature function fail.
7) Show help message for VDD Voltage Regulator item.
8) Remove some items:
-OS Select For DRAM > 64MB
-Typematic Rate Setting
-Typematic Rate (Chars/Sec)
-Typematic Delay (Msec)
Model: EP-8RDA3G
Date: 08/27/2003
Fixed:
Model: EP-8RDA
BIOS: 8RD13827.BIN (4700)
Date: 08/27/2003
Fixed:
4) Solved CPU warning temperature/Shutdown temperature function fail.
5) Show help message for VDD Voltage Regulator item.
6) Update awdflash.exe utility version of 8.23F to 8.24V.
7) Remove some items:
Model: EP-8RDA+
BIOS: 8RDA3827.BIN (5700)
Date: 08/27/2003
Fixed:
Sam sm lasnitk 8RDA z nforce2 ultra 400 čipsetom in winbond rami. K pridem dam bomo dal tale bios gor in vidl kaj je po pravu. Na AOA forumu ni niti enga k mu po tem k je flashu nov bios nebi šou FSB višji kukr prej. V pričakovanju:D
Aja biose se dobi tuki: epox.org
Ne droga, ne trava me ne mika, le kakšna promilja alkohola se učasih po krvi mi potika:)
_Dejan_ ::
jst mam EPOX 8RDA pa sm flashau z zadnjim biosom pa se mi računalnik sploh ne boota na 222x10 z 8RD13305 pa mi dela stabilno tko da ne vem kaj je narobe, aja isto je tudi z predzadnjim biosom.
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
rap3r ::
s kerim biosom ti dela?
_Dejan_ ::
z 8RD13305 mi dela. narejen je se mi zdi 3.5.2003
Biosi za bolše navijanje?
Oddelek: Navijanje
51469 (1280) Klemzz
Problem z novim BIOSom na EPOX 8RDA+
91326 (1223) fefko-the-bulldog
Nvidia System utility, kar smo čakali smo dočakali :)
252269 (1795) njok
KT600
Oddelek: Novice / Matične plošče
82884 (2884) Dr_M
Katero od teh dveh EPOX plat? (strani: 1 2 )
536967 (6331) krucymucy
