MariaDB - IF / ELSE IF / ELSE - kakšna je pravilna sintaksa?
HotBurek ::
Evo, imam super preprost problem.
Baza je: MariaDB 10.3.15
GUI je: DBeaver 6.1.5
Probam pa naredit IF/ELSEIF/, ki bo glede na input prebral podatke iz različne tabele. In je problem, ker je nekaj narobe s sintakso in ne najdem kaj.
Se pravi, kakšna je pravilna sintaksa?
Tole je pa primer, ki ga poženem in dobim errorje za vsak IF, ELSE IF in END IF.
USE db1;
SET @val1 = 0;
IF @val1 = 0 THEN
	SELECT * FROM db1.table1;
ELSE IF @val1 = 1 THEN
	SELECT * FROM db1.table2;
END IF;
root@debian:/# iptraf-ng
Please resize your window
videc ::
IF condition1 THEN
{...statements to execute when condition1 is TRUE...}
[ ELSEIF condition2 THEN
{...statements to execute when condition1 is FALSE and condition2 is TRUE...} ]
[ ELSE
{...statements to execute when both condition1 and condition2 are FALSE...} ]
END IF;
https://www.techonthenet.com/mariadb/lo...
OracleDev ::
Prva stvar je verjetno ELSEIF mora biit napisan skupaj, drugo pa verjetno napaka tudi drugje v kodi (deklariranje spremenljivk, select ki ne ve kam dati rezultate,...).
HotBurek ::
Ok, popravljen v ELSEIF. Pa so isti trije errorji.
Za prvi IF, za vsak ELSEIF, ter na koncu še END IF.
In to je celotna koda, ker si prirapvljam kveri, da bom naredil pol proceduro...
SQL Error [1064] [42000]: (conn=7771) You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '' at line 3
Query is: IF @val1 = 0 THEN
SELECT 1
java thread: DBeaver: SQL script execution
SELECT 1
SQL Error [1064] [42000]: (conn=7771) You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'ELSEIF @val1 = 1 THEN
SELECT 1' at line 1
Query is: ELSEIF @val1 = 1 THEN
SELECT 1
SELECT 1' at line 1
SELECT 1
SQL Error [1064] [42000]: (conn=7771) You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'END IF' at line 1
Query is: END IF
Query is: END IF
HotBurek ::
Problem rešen, potrebno je bilo dodati DELIMITER. Neki zarad podpičji.
https://mariadb.com/kb/en/library/delim...
Sample je sedaj takle (ki bo pol imel še ELSEIF in tabele ad01, ad02 , ..., ad10, ad11 itn...):
USE db1;
DELIMITER //
CREATE DEFINER=`root`@`localhost` PROCEDURE `db1`.`spCheckIfAdExists`(IN catval INT, IN subcatval INT, IN adid INT)
BEGIN
	IF catval = 0 THEN
		IF subcatval = 0 THEN
			#SELECT cat.id, subcat.id, ad00.id FROM db1.Category AS cat
			SELECT COUNT(*) AS 'count', IFNULL(usr.id, -1) AS 'userId'
			INNER JOIN db1.Subcategory AS subcat
			ON cat.id = subcat.categoryId
			INNER JOIN db1.Ad00 AS ad00
			ON subcat.id = ad00.subcategoryId
			INNER JOIN db1.Users AS usr
			ON ad00.userId = usr.id
			WHERE cat.categoryValue = catval AND subcat.subcategoryValue = subcatval AND ad00.id = adid;
		END IF;
	END IF;
END;
DELIMITER ;
  • spremenilo: HotBurek ()
[PHP]Zajem podatkov iz baze
Oddelek: Programiranje
355524 (5161) cobrica
[MySql]Sintaksa poizvedbe
62339 (2260) KernelPanic
php, napake in napake :S
Oddelek: Izdelava spletišč
171925 (1682) preem
SQL Error
141532 (1393) Lukas991
spet mysql - problemi z ... who knows what
51063 (1039) pivmik
