Ko poizkusam namestiti WinFOX 2.0 mi napise tole ?!?!
Cranchi ::
Torej ko hocem posecki po instalu mi napise tole (btW: probal sem tudi ze iz njihove strani dolpotegnit in instalirat vendar javi isti error!)
16 bit windows subsystem
C:\WINDOWA\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Shoose "close" to terminate the application
Cranchi ::
dejte pomagat prosm, nujno rabm!
Raw ::
Error Message:
Explanation:
There is a problem with either CONFIG.NT or AUTOEXEC.NT. When NTVDM starts up, it edits these files to meet the requirements of MS-DOS and 16-bit Windows. If you get this message, NTVDM was not able to make all the edits necessary to meet all of those requirements.
User Action:
Contact your system administrator.
Ful dobr user action a? :D lol
No, poglej se tale link. Mogoce ti kaj pomaga.
Imas NTje? Imas zadnje popravke - service packi...?
.raw
  • spremenil: Raw ()
Cranchi ::
nope imam XPje, ko sm probal prvic instalirat je delovalo potem sm dal cez pol ure dol in poizkusal spet instalirati on nedela!
Raw ::
Weird stuff..
Logika prav, da so krivi Winsi. Kaj tocn je narobe mi ne pade na pamet. Vseen - imas zadnje popravke? :\
Ce ti bo uspel resit, sporoc se tukaj kako.
.raw
Cranchi ::
zadnje popravke hm. ?
imam tist kar mi samo upgrejda na vsake par dni neke hotfixe itd.
Cranchi ::
huh pa sm spedenal.. in sicer tako da sm zagnal rocni instal in ne 16 bitnega (animiranega)
Grim fandango
Oddelek: Igre
82482 (1748) oo7
Sesutje po navijanju...
Oddelek: Navijanje
71527 (1303) k4vz0024
Problemi pri nalaganju iger in progamov
Oddelek: Programska oprema
51156 (1128) ToniT
DOS!
Oddelek: Igre
81497 (1223) misterno
Baldur's Gate, King's Quest
Oddelek: Igre
111262 (1123) Mavrik
