Forum » Igre » Contract Wars-Ping
Contract Wars-Ping
metsis ::
Lep pozdrav
Imam naloženo igro Contract Wars, igram jo preko spleta.
Problem je, da je Ping previsok in ni možno igrati?
Je kaj za narediti?
Hvala
Je kaj za narediti?
Hvala
How to reduce ping/computer lag :
- Don't push your computer system limits just because you wan't some good graphics , just set the graphic settings to what your computer can handle.
- Select a server which the pings are lower.
- Bigger maps = more lag , if your computer can't handle certain maps , then try not to play them too often.
- Browsers to use? I use google chrome to play , but however if you wan't the best/suitable browsers to play with , ask the developers. ( It was firefox before , not sure if they changed it. )
- Close un-used tabs/system on your computer.
- This doesn't really affect lags much , but remember to update your unity web player often!
- Seriously , do not use Internet Explorer to play Contract Wars , don't...
https://www.facebook.com/71991364470020...
Contract Wars - How to reduce lag
| » | Lost planet: extreme condition, da prihaja na PCOddelek: Igre | 1871 (1667) | Calligula |
| » | Encarta prek MSNja (strani: 1 2 )Oddelek: Novice / --Nerazporejeno-- | 13035 (10519) | Dragi |
| » | Iptables in C&C GeneralsOddelek: Igre | 2516 (2285) | Tito |
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2450 (2214) | Arthur |
| » | Program za web server?Oddelek: Omrežja in internet | 2871 (2730) | Hojne |
