Forum » Loža » Venezuela ima dva predsednika
Truga ::
glede na to kaksne lovske postas tu, v iran in v izrael threadih je po pravici povedano edina moznost da si navaden bootlicker.Ja, to da je zemlja okrogla je priblizno tako neizpodbitno kot to da ti tule propagiras imperialisticne talking pointe, ki ti ga je prek NYT serviral ameriski state dept.
Možno.
Ampak ti jih še vedno nisi sposoben z ničemer izpodbijati.
Možnosti sta dve:
1. Si popolnoma nesposoben, saj ne znaš izpodbiti niti očitne propagande.
2. Gre za resnico, ne propagando.
Se lahko izjasniš kaj od tega je res?
Dobro, če sem pošten je res še ena možnost:
3. Drži oboje.
Truga ::
Ma, tud ce misli da je vse kar je govori res, moras bit res top psihopat in bootlicker da lizes rit ameriskim in izraelskim rezimom.
Pa še ena možnost: Ti lažeš.
Tudi to je možno.
V tem primeru moraš dokazati, da se referendum o reformi Irana ni zgodil.
1953 Iranian parliamentary dissolution referendum @ Wikipedia
Veliko sreče.
The balloting was not secret and there were two separate voting booths, i.e. the opponents of Mossadegh had to cast their vote in a separate tent.
Temu pravimo demokracija severnokorejskega stila. Kakšna izguba za demokratični svet je bil tale Mossadegh, res.
Katere pa?
A da je Mossadegh izvedel neustavni referendum o razpustitvi parlamenta in se proglasil za absolutnega vodjo države?
V pomoč:
https://fran.si/133/sskj2-slovar-sloven...
- spremenil: Smrekar1 ()
> Yeah, the amount of exceedingly stupid shit that the libs demand you treat like literal articles of faith is just
absurd, and it kills any chance at a real discussion because apparently thread consensus trumps objective reality.
> Like, the libs would have us believe that things in Venezuela literally are as bad as they can possibly be so no matter
what the US does it's justified by default, which is absurd enough in itself, and they would also have us believe that
the opposition has overwhelming public support and that Maduro is so weak that he doesn't dare do anything to the
opposition leaders.
> And then you look at objective reality and note that in this country where the government is supposedly extremely weak
and unpopular and where the people supposedly have literally nothing to lose, the opposition can't even get a coup off
the ground even with the full backing of the imperial core states and you realize what a crock of bullshit the lib
consensus actually is.
> smrekar.txt
About sums it up.
https://foreignpolicy.com/2017/06/20/64...
opposition leaders.
> smrekar.txt
About sums it up.
V tem primeru moraš dokazati, da se referendum o reformi Irana ni zgodil.Ne. Dokazati moram, da je CIA organizirala državni udar, kar lahko trivialno storim:
- spremenilo: jype ()
Imaš prav, sreče rado zmanjka! Pri pameti je pa tako, da je najbolj pravično razdeljena po celem svetu! Skoraj vsak misli, da je ima dovolj!
Pomni: Trditev je, da v Iranu ne bi bilo sranja, če ne bi CIA vrgla DEMOKRATIČNEGA voditelja Mossadegha.
Problem je samo v tem, da je bil Mossadegh demokratičen ene toliko kot Kugo Chavez.
Pomni: Trditev je, da v Iranu ne bi bilo sranja, če ne bi CIA vrgla DEMOKRATIČNEGA voditelja Mossadegha.Ne. Trditev je, da bi bilo sranje znatno manjše, ker to dokazujejo vsi primeri, ko ZDA niso sponzorirale destabilizacije države s financiranjem skrajnežev.
Problem je samo v tem, da je bil Mossadegh demokratičen ene toliko kot Kugo Chavez.Skratka, bistveno bolj demokratičen, kot katerikoli diktator, ki ga ZDA finančno podpirajo, da lahko kapitalisti z lovkami pri oblasteh ZDA v zameno za kršenje človekovih pravic neovirano izkoriščajo naravna bogastva tistih držav.
Razumem in se strinjam s tabo, da so ZDA vir večine konfliktov in geopolitičnih težav v 21. stoletju.
Recimo Venezuela?
Ups.
Če ti ni jasno kaj je tu narobe je problem v tebi.
ZaphodBB ::
Ruski bot v polnem zagonu.
- predlagalo izbris: Truga ()
jernejl ::
Na srečo imajo do diktature v Venezueli manjšo toleranco.Predvidevam, da takoj za tem sledi rušenje diktatorja in demokratične volitve v Savdovi ArabijiKako točno je to povezano z Venezuelo? Spet poskus preusmeritve pozornosti drugam? Tako kot že ves čas poskušate diskreditirati Venezuelskega predsednika, samo zato, ker so ga priznali Islandci, ali kdo že.![]()
Zato ker regime change poskušajo izvesti ZDA, ki mirno tolerirajo diktaturo v SA.
Saj verjamem, da ti je težko razumeti in potegniti vzporednice a ti zagotavljam, da bi se ob enakem delovanju ZDA do SA, režim v Rijadu sesedel v enem mesecu.Predlagam, da o Riadu odpreš posebno temo, če te tamkajšnja situacija tako zelo žuli.
Torej, Venezuela-->ZDA-->SA = licemernost par excellenceOh ne, licemeren si zgolj ti, ker se ti zdi, da če je nekje drugje diktatura, potem je prav, da je tudi v Venezueli.![]()
- spremenil: jernejl ()
Recimo Venezuela?Ja, recimo Venezuela. Če ZDA ne bi obilno financirale terorizma, izvajale gospodarske blokade in se temeljito trudile z vsemi sredstvi destabilizirati države, ki jo vodi že itak štorast diktator, bi Venezuela danes bila precej bolj demokratična.
Ruski bot v polnem zagonu.Odkar ruski oligarhi obvladujejo ameriško izvršno oblast itak pričakujemo, da boste to počeli, tako da nismo presenečeni.
Predlagam, da o Riadu odpreš posebno temo, če te tamkajšnja situacija tako zelo žuli.Kar ti daj, tebe skrbijo diktature, ki ignorirajo človekove pravice.
Če ti ni jasno kaj je tu narobe je problem v tebi.Ne, problem je v tem, da si ti nasedel propagandi, zato ne razumeš, da Mosadek ni bil diktator.
Kolikor vem nisem jaz tisti, ki meša Venezuelo, Kubo in Iran.Tako je - ti si tisti, ki ne vidi očitnih vzporednic.
No, vsekakor si se odzval kot nekdo, ki o tematiki res nima blage veze. K sreči sem že vajen.Če haluciniraš izključno na podlagi obilne imperialistične propagande, ne moreš niti ponesreči halucinirati ničesar smiselnega, zato razumem tvojo stisko.
- predlagal izbris: Smrekar1 ()
Na, smrekar, predlagaj izbris:
https://twitter.com/means_tv/status/112...
Zgrešil si forum, humor imamo v loži. Video na začetku jasno pove, da gre za "spoof", t.j. šalo.
Smrekar vrže gorečo smrekco preko meje v Venezuelo in zakriči: "Venezuela gori! Hitro, posredujte!"
Aha.
https://www.unhcr.org/venezuela-emergen...
In 15% prebivalcev je zbežalo iz države, kjer se cedita med in mleko.
Video je dolgočasen: Bolton razlaga, da morajo voditelji lagati ljudstvu, ki mu vladajo, da lahko izpeljejo svojo imperialistično agendo.
Truga ::
https://www.vox.com/policy-and-politics...
Sen. Lindsey Graham (R-SC), a close ally of President Donald Trump, suggested the president take a tough stance in dealing with the ongoing Venezuelan crisis: A US invasion similar to the one executed by Ronald Reagan in Grenada back in 1983.
"Trump said rightly, Maduro's not the legitimate leader of Venezuela. The entire region supports the Trump approach, that Guaidó is the legitimate leader," Graham said on Fox News Sunday. "I would do exactly what Reagan did. I would give Cuba the ultimatum to get out of Venezuela. If they don't, I would let the Venezuelan military know, you've got to choose between democracy and Maduro. And if you choose Maduro and Cuba, we're coming after you. This is in our backyard."
reheated cold war propaganda, lmao
7tom1ja ::
Na nas leži naloga, da naprej razvijamo našo samoupravno socialistično družbo,
da jo gradimo na revolucionarnih temeljih, temeljih marksizma.
Brigada AVNOJ 77;Komisar Ivan Janša
Božja batina je izjavil:
Maduro še naprej maltretira svoje ljudstvo. Žalostno
Jp, če bi takšne sankcije nabili Nemčiji, bi tudi Merklova 'maltretirala' svoje ljudstvo.
ZaphodBB ::
Zakaj je pa ljudstvo maltretiral že pred sankcijami? Ker jih je slutil?
jernejl ::
Če bi Nemčija imela toliko nafte, kot je ima Venezuela, bi bili vsi Nemci bogati upokojenci.Božja batina je izjavil:
| » | Venezuela (strani: 1 2 )Oddelek: Loža | 9004 (5322) | marS |
| » | Kaj se dogaja v Venezueli?Oddelek: Problemi človeštva | 5444 (4397) | Smrekar1 |
