Forum » Strojna oprema » NVIDIA Ampere (2020)
m0LN4r ::
Je ze kje kak review, ki pokaze da 10gb GDDR6X od 3080 ni dovolj?
https://ref.trade.re/38mvdvxm
Trade Republic 38MVDVXM
Watch Dogs Legion system requirements 4K Ultra Settings - GPU RAM: 11GB z in brez RTX
Pač od kar imajo več rama, dajejo razvijalci kvalitetnejše texture in bolj dodelane modele...
Godfall needs 12GB memory for 4K gameplay with UltraHD textures
Da če nočeš imeti občutne FPS drope... ja rabiš več mkot 10GB VRAM-a pri 4K
Warzone, consuming around 10.5GB of VRAM on 4k.
Da , kdor je kupoval RTX po cenah, ki je NV vedala da bodo kupovali... no prihajajo modeli z več VRAM*a
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
Furbo ::
Zanimivo da misliš, da samo minimalaci uporabljajo status normiranca. Slabo si se pozanimal ti tole. Al pa pač nimaš pojma. Kakorkoli.
Ja par ljudi poznam, ki jim je to za zraven, kjer operejo res lep denar za kako 'svetovanje' z malo davki.
Ampak oni ne jamrajo za 100€ pri grafi, tko da..
i5-13600K, Noctua NH-D15, STRIX Z790-F, 32GB DDR5, 2TB Samsung 990PRO,
Toughpower GF3 1000W, RTX3070, ALIENWARE AW3423DWF, Dell S2722QC
Bwaze6 ::
Doom Eternal na 4K in teksture do konca prav tako potrebuje 9GB:
The Hardware unboxed review of the 3080 confirmed that the massive FPS increase with the 3080 that led Nvidia to use it at 4k with 'Nightmare' (max) settings and conclude up to 100% fps increase at 4k (Hardware Unboxed confirmed 109%) was entirely due to a VRAM limitation.
4k Ultra Nightmare
2080 - 88
3080 - 189
In the video he confirms that game running at 4k with absolute max settings used 9gb of VRAM on the 3080 (more than the 2080 has), and before 'ALLOCATED VERSUS USED' comes into play, he said that all he did was turn the 'ULTRA NIGHTMARE' texture pool size setting to 'ULTRA' (1 lower than max), and it dropped the VRAM usage on the 2080 to 7gb, and the FPS difference lowered to 70% instead of 109%.
mahone ::
Using a GeForce RTX 3090, which has 24 GB of VRAM, we measured the game's memory usage at the highest setting.
At Ultra settings, the VRAM requirements are definitely high. Even at 1080p, we measured more than 6 GB allocated. Surprisingly, performance results for NVIDIA cards with less than 6 GB are still fine, unlike AMD Radeon cards, which take a huge performance hit.
- spremenil: mahone ()
Ultra-System Requirement - 3840x2160 (4K), Ultra Preset DX12 Imaš srečo, na uradni strani piše 10GB
Seba22 ::
Hopper bo verjetno tsmc 5nm, vmes očitno zmeša plane livarna, zato pa lahko vrnejo naslednjo generacijo z bigger splash.
Počakaj raje na 20GB modele ali koliko pač bodo se bolj splača za moje pojme 10gb za 2020 je pač sramotno ponuditi sploh pa za tako ceno ko se dan danes prodajajo
Bo verjetno treba kar na Super varijante na tsmc 7nm počakat, če ti radeonke ne dišijo in ti je Hopper oziroma next gen predaleč.
Bo pomoje kr prej tole pod pogojem da to z amd rdna 2 drži res da nebo to še 7nm tsmc(to še itak nič ni potrjeno),ampak te obstoječe z več rama ali pa kašna 3080ti kot se nekaj omenja zadnje čase
Asus ROG B650E|Ryzen 7800X3D|DDR5 32GB|NVMe SSD 3TB|EKWB AIO 360|RTX 4080
Dell Alienware 27" 1440p GSYNC Ultimate|CAN-AM Renegade 1000cc 2022
- spremenil: Seba22 ()
Senior Dev ::
Začelo se je prvo jokanje po redditih okoli premalo memorije na precenjenih 3080. Zdaj želijo nazaj svojo ledvico in bi radi vrnili kartico...
Pa kaj jamrajo, saj jo lahko za 50% višjo ceno prodajo. Hja, če niso že kupil od skalperjev. Sam je treba pohitet, ker bodo kmalu začeli obirati z novi verzijami:D
- spremenil: Magic1 ()
klinker ::
Joj meho, kake ti pokas ven sej ne trobi o low endu, ampak 3060 in ja, 6GB je premalo za tako zmogljivo karto, tako kot je 8GB totalen joke na 3070, sploh za te nategunske cene.
In 3060 bo level med 2070s -2080 kar je ze mid tier trenutno. Moja 1070 je ze entry level
Ti omenjas 1060 in 1050. Si padu z lune al kaj?
Bi vsaj dal v primerjavo 1060 3gb in 1060 6gb, kjer pa so razlike bile in zdaj trobis da je na 3060ki 6gb dovolj, ki je n-krat hitrejsa?
Tej Amperi so en nateg, cenovno in po kolicini rama.
Senior Dev ::
Problem je da je ledvica že v drugem človeku. Lahko kupijo edino novo ledvico, ki pa mora biti kompatibilna. Skratka začaran krog.
Skyman ::
Super verzij pomoje da ne bo... ker pri 20xx seriji ni bilo TI oznak tukaj pa S(super) ne bo vrjetno bodo še kaksno 3090TI dal z 30gb rama
Definitivno pa 3080TI bo morala biti pod 1000€ ker je ze tam 6900xt
Bo še zanimivo vidim januarja
Senior Dev ::
Vse kaže na to da bo Lisa Su naslednje leto dobila povišico plače iz 60 mio letno na 100 mio potem ko za modrimi poniža še zelene.
mahone ::
Ti nisi cist h2o?
Si sploh kaj pogledal benche?
Mavrik ::
Senior Dev je izjavil:
To me zdaj spominja na ves bruhaha okoli tistih 3.5GB/512MB na 970GTX seriji... kar na koncu ni naredilo kaj dost razlike :P
FlyingBee ::
Nekaj bo, AMD bo spet nad 30% market share prilezel.
New Sphincter Kvartet:
Senior Dev ::
Zaradi kripto norije? Nekaj se nakazuje v to smer, bi se znalo ponovit tisto ko bo folk kupoval po 16 kartic naenkrat in ne bo problem dati 2000€ za kos. Skratka norišnica.
Ti nisi cist h2o?
Imas tri igri, ki rabijo vec kot 8GB vrama... ostalo me ne zanima. V tem trenutku zagotovo nebi kupoval graficne z 10GB Vrama, ko so seveloperji dobili moznost implementacije kvalitetnih 4k tekstur..
B34ST ::
Jaz rečem da bo do 2024 max 10 slabo optimiziranih iger kjer bo na 3070 limit VRAM in ne GPU.
Včeraj sem igral AC Valhalla, porabi 6GB VRAM, je pa ravno da še zadovoljivih 70 FPS na 1440p Ultra. Tako da pri 95% iger bo prej GPU omagal pri max nastavitvah kot pa bo zmanjkalo VRAM-a. Pač takoj se je treba zavedat da to ni kartica za 1440p vse na max. In če boš moral ostale grafične nastavitve zmanjšat iz Ultra na Very High, potem ne bo tako bolelo če boš moral še kvaliteto tekstur.
Pa na tej bi blo smiselno 12GB, ampak na 6700 XT sem pa siguren da vseeno če bi imela 8GB, ker bo GPU res švoh z 2560 SP. Kaj ti čejo teksture na Ultra 4K, če boš moral dat vse ostalo na Medium-High. Ostale 16-20GB kartice bodo pa tako čez 700EUR. Tako da za 600EUR je 3070 8GB zaenkrat to to.
i5-10600K | NH-D14 | MSI MAG Z490 TOMAHAWK | F4-3200C14D-16GVR @4000C14
ASUS DUAL RTX 3070 | ADATA XPG SX8200 Pro 2TB | 870 QVO 8TB | 2x WD Blue 4TB
Corsair 600T | Corsair AX760 | G413 | G403 | HP Pavilion Gaming 32
- spremenilo: B34ST ()
AapocalypseE ::
700€+ hočejo met za 3070 in še igre, ki so že zunaj, ne more poganjat na 1440p Ultra 100fps+. Pa kak futureproof je to?!
Me res ma, da grem na 1080p nazaj.
Sramotni fpsji glede na ceno.
- spremenil: AapocalypseE ()
AapocalypseE ::
Vidiš, da še niti na 100fps ne pride.
1440p 144Hz ali več mi sploh mine kupit. Ne rabim, da bom gledal na namizju kako tekoče leti miška.
XS!D3 ::
A je kdo uspel dobit Watch Dogs: Legion in GeForce NOW poleg RTX3080 kupljene v slo. Na nVidia strani piše, da naj bi kodo zagotovil retailer, funtech pravi, da se je treba obrnit na proizvajalca.
Skyman ::
NVIDIA GeForce RTX 3080 Ti Landing in January at $999
https://www.techpowerup.com/274505/nvid...
mahone ::
AapocalypseE je izjavil:
Primerjaj benchmarke med AC:V ter WD:L
Kaj imata obe igri skupnega?
UBISHIT
meho7,
Doom ima tudi UBISHIT zadaj... Pa kitajce kot lastnike
Ne skrbi, ta tvoj jagodni izbor se bo s portanjem med Xbox in Windows kvečemu povečeval... Dejstvo je, da 10GB je sedaj minimum za 4k še malo moraš dodati, ko vklopiš DLSS2 + RT.
Žalostno je, da Nvida pravi da je RTX 8k gaming card. Kaj misliš če bodo teksture na nivoju 8k. kar seštevaj če bo 24GB VRAMa dovolj.
FlyingBee ::
Pretiravaš, kot za FuryX s 4gb pa je zadeva prej zastarela kot premalo vrama. Naslednje leto bodo že refreshi.
mahone ::
meho7,
Doom ima Vulkan api
Saj gremo lahko 3-4 leta nazaj
Ghost Recond wildlands - najhitrejis gpu takrat
ter Mafia 3
Senior Dev ::
Kako je pri konzolah? 60 fps na 2160p in 120 fps na 1440p? Ali to ne pije vode v praksi?
meho7,
Doom ima Vulkan api
ter Mafia 3
Sej geš lahko v leto 2000, ali pa kakšno Riva tnt... Da boš nekaj dokazal. Karkoli iz jagodnega izbora na martinovo.
mahone ::
Sem ti podal vec kot dovolj dokazov. Drgac si pa malo preberi kaksno sranje je Ubisoft povzrocil s securom ter starforceom.
Nima nobene veze s temo, koliko spomina zaradi "kvalitetnih" tekstur pokuri VRAMA igra. Sorry Nvidia je rekla 8K grafična. 8K teksture, no zračunaj če je 24 GB Vrama dovolj.
B34ST ::
Ta teden je celo bila ena 3080 na zalogi v CU, ampak AORUS za 1020€. Se pravi v dveh mesecih nič. Jaz rečem da bo zaloga šele junija, cene pa padle na 800-900€.
Bedna scena. 3070 prešvoh, 3090 predraga, 3080 ne obstaja, skalperji pa naj jo imajo.
Sej se zadeve spreminjajo na bolje.. Za 3090 in 3070 je že kar nekaj zaloge in cene počasi padajo proti MSRP cenam. 3080 bo pa kmalu. Konec novembra/začetek decembra bodo vse na zalogi, ko bo še AMD priskočil na pomoč.. Ampak takrat zna bit Big Navi best buy zaradi 16Gb rama.. Se zna zgodit, da bodo nekaj časa na voljo le Nvidia kartice, medtem ko bodo Navija razgrabili.
FlyingBee ::
Lol, pa bo spet nvidia imela boljšo prodajo.
Wrop ::
Normalno. The more you buy, the more you save. Tega AMD ne ponuja, zato pa ima manjšo prodajo.
Vprašanje.
AMD bo delal na običnem N7 RDNA2.
Zaloge bi znal imeti.
|HP EliteBook|R5 6650U|
- spremenil: D3m ()
Jok, brate!
Še za ryzena bodo potrebovali par tednov, da bo zaloga. Pa je ravno tako delan na običnem N7 procesu... Za RDNA2 bo zagotovo večje povpraševanje, pa še čipi so večji oz. so manjši yieldi.
TSMC bo švical. xD
Glede na to, da je N7 bi morali bruhati količine.
- spremenil: D3m ()
Vsekakor jim bo precej lažje kot je bilo Nvidiji.. Ta je namreč v teh dveh mesecih že "nahranila" tisti najbolj lačen delež trga.
Vprašanje edino, kako se bodo otresli rudarjev, če so govorice o izjemni kripto zmogljivosti NAVI2 kartic resnične?
Bwaze6 ::
Polno člankov in posameznikov (tudi tule) očitno prav navija za kriptorudarjenje. Zakaj že? A rabimo še kak rondo v Kranju okrasit s simboliko ekstremne sebičnosti?
Bitcoin (in večina preostalih nepomembnih kriptovalut) je zdajle vredna približno toliko kot junija 2019, januarja 2020, avgusta 2020, vmes pa so bile seveda tudi doline. Zaenkrat še nič ne kaže na nek ekstremen porast v obliki kriptonorije ob koncu leta 2017. Seveda pa je to "self fulfilling prophecy", valuta sama je brez vrednosti, željena je izključno toliko, kolikor ljudje verjamejo, da se bo njena vrednost dvigovala, ne spuščala.
Kaj dobrega je PC srenji kriptorudarjenje prineslo? Več kot pol leta so bile cene strojne opreme popolnoma nerealne. Tudi po zlomu vrednosti kriptovalut so previsoke cene vztrajale še mesece, prodajalci zgleda kar niso mogli verjeti, da je konec zlatih časov...
Jaz nisem dobil občutka, da bi kdorkoli navijal za rudarjenje.. Prav nasprotno. Vsi se tega bojijo. Vsekakor gamerji. Kdo neki bi si želel, da bi cene grafičnih poskočile X2 za dlje časa?
AapocalypseE ::
NVIDIA GeForce RTX 3060 gets 12GB memory, RTX 3060 Ti comes with 8GB
https://videocardz.com/newz/nvidia-gefo...
Senior Dev ::
Gre dejansko za zlorabo strojne opreme posredno ali neposredno za namene pranja denarja, financiranja terorizma in ostalih nečednih poslov, za kar se povečini uporablja Bitcoin ali katero od 12.000 izmišljenih virtualnih valut.
Bwaze6 ::
To nima nobenega smisla.
Veliko neumnosti za samo dve vrstici.
