Intel Core 9th-gen
Intel Core 9th-gen
FlyingBee ::
raje nižjo resolucijo in več fpsjev in s tem tudi vsaj 75hz monitor
980/1060 je ok za medium in pri marsikateri igri na max, če je resolucija 1080p ali nižja, drugače pa je že problem s tako grafiko izkoristit vse kar igra in monitor ponujata
AapocalypseE ::
V mislih sem imel 1920x1080, torej pravi 1080p.
Ne gledat samo avg. fpsje, ker so low bolj pomembni.
Playing Chicken: Kentucky Fried Intel Core i9-9900KFC Processor Listed
https://www.anandtech.com/show/13967/in...
Treer ::
Vidiš - novo Vego bi rabil samo eno...:))
gddr85 ::
fried 5.5ghz 200w edition maybe? noice :))
AapocalypseE ::
Overclockers UK debuts 8PACK Orion X2- a 33,000 PC
https://www.kitguru.net/desktop-pc/matt...
  • predlagal izbris: Ahim ()
Treer ::
No, tole je resnici na ljubo pretiravanje, ampak je pa zanimivo, kako ni v niti enem truly high end buildu AMD-ja niti blizu; ne Ryznov, ne Threadripperjev in še manj Radeonov - čudno mar ne, glede na to kako so menda oh in sploh? :))
Treer ::
Haha - šaljivci v elementu danes! :))
AapocalypseE ::
Če se zavrti video na 5:01 tudi obrazloži zakaj se uporablja Intel in ne AMD.
Treer ::
Hehe - "So, why do you always go for Intel and Nvidia in your builds?"
"It simple - they're the best performing cpus, be it for single core speed or things like engineering software, where you need lots of threads and ram or lots of cuda cores..."
tole mora pa kar peči "but, but, AMD has better multi-thread performance" privržence :))
ziga1990 ::
^^pač on je kot ti fanboy
Treer ::
Sure, be it that way if that makes you feel any better :))
mahone ::
AapocalypseE je izjavil:
A to majo custom made kiste?
30k$ za gaming.
Ahahhahahahaaha.
Jaz vidim watermark "sponsored by Intel"
:D
gddr85 ::
a 9900k ni bil dost dober? :))
AapocalypseE ::
meho7, custom made je ja.
Phanteks tudi za njih naredi ohišje.
d3m in gddr, idita raje v cheap ryzen temo smetit...
ziga1990 ::
ti pa Treer pa v tej ostanita
AapocalypseE ::
Tebe sem še pozabil...
Shoo, shoo v cheap ryzen temo. Ne še tukaj nivoja zniževat.
ziga1990 ::
vidva pa tu ostanita ni potrebno da Ryzen tema na vaš nivo pade
AapocalypseE ::
Vi trije pa tam, ker to tukaj je drug svet za vas, ki ga ne razumete.
ziga1990 ::
vem vem grem v temo kjer smo odrasli notri otroci ostanite tukaj
Kako pa izgleda ta svet?
ziga1990 ::
^^ notri so otroci in ovčke
AapocalypseE ::
Rdeči pederajsli prisilite druge, da vas kurcajo in potem je tako kot je na forumu...
d3m, lepše in hitrejše.
  • predlagalo izbris: tikitoki ()
ziga1990 ::
^^ pravi se oglaša
AapocalypseE ::
Povem realno tako kot je.
ziga1990 ::
Predlagaj izbris to edino kar zaš
  • predlagalo izbris: MostWanted ()
AapocalypseE ::
Evo kdo je spet začel smetit temo?
Mater da vam j***... rdeči ku**
Za 30k bi vzel BMW in bi bilo lepše in hitreje.
Kar ostane pa v internet kafič igrice igrat.
AapocalypseE ::
Mater da vam j***... rdeči ku***
ziga1990 ::
^^tu imaš krivca za smetenje po temi zakaj ga ne predlagaš za izbris?
Ne verjamem, da bi bil kos moji mami. Ona rabi moškega ne otroka na igricah.
  • spremenil: D3m ()
AapocalypseE ::
Prizadeti folk ste nekateri res...
Normalno postam Intel build za 30k€ in zakaj vas moti?
ziga1990 ::
StreetRacer sebe ne mene saj ti smetiš temo
Motilo bi me, če fašem KERNEL_SECURITY_CHECK_FAILURE pri mašini za 30k.
AapocalypseE ::
Smetiš ti govno jedno, ker nisi sposoben normalno odgovorit na moj originalen post o omenjenem Intel buildu...
Mater mi grete na kurac rdeči, ker samo drek mešate po tem forumu.
ziga1990 ::
^^glej tvoj post o 30k Intelu ni problem samo tvoj zaveznik Treer je sprožil ti pa še vedno goniš to vojno sicer pa žaljenje ni dovoljeno bom te prijavil.
Kurac, ko nabrekne je dejansko rdeč, ko pa dodaš rinko pa rata plav.
AapocalypseE ::
Jokaj jokica.
Začenjate offtopic nonstop rdeči.
AMD ni na nivoju Intela in to vas moti...
Niti ni sposoben skupaj spravit takšnega builda, ki je zgoraj.
ziga1990 ::
Intel ni na nivoju AMDja
Intel mora spustiti cene, da bo na nivoju samo mu ne bodo delničarji dovolili. :D
ziga1990 ::
Vidiš StreetRacer dejstva ti niso vseč in predlagaš izbris ker drugega ne znaš
AapocalypseE ::
Dejstvo je, da je Intel najhitrejši in se lahko na glavo stavite rdeči...
A build za 30k$, da nismo sposobni narediti?
Mi delamo builde za 100k in več.
P.S.
Najhitrejši je relativna vrednost.
AapocalypseE ::
Zato pa gledamo tujino in ne tebe d3m...
Itak ja...
ziga1990 ::
StreetRacer se strinjam samo za intela moraš dati 30k za AMD pa 2k
Itak ja...
Kaj ima tujina veze z menoj?
Če boš rabil 100k bulid se boš obrnil na mene ali pa tujino samo glej, da boš imel support v tujini.
AapocalypseE ::
d3m, pa ti še za 30k€ builda videl nisi kaj šele sestavil...
Grem jaz, ker s takšnimi butli je brezveze debatirat.
Senitel tudi pametno naredil, da ne sodeluje več v tej greznici od foruma.
Lepo se imejte na smetišču ;)
Treer ::
D3m je izjavil:
P.S.
AMD build za 100k in več? :)) A je kaka zlata palica notri mogoče? ;((
ziga1990 ::
^seveda:D
53 / 81
Nakup CPUja 2019 (strani: 1 2 3 )
10624642 (20280) Predator X
Intel predstavil 9. generacijo Core procesorjev (strani: 1 2 )
Oddelek: Novice / Procesorji
8427002 (23419) MrStein
