Forum » Strojna oprema » Intel Core 9th-gen
Intel Core 9th-gen
FlyingBee ::
Novi Core i, Core ii?
Core II, to bo, to.
Core II, to bo, to.
Vuli ::
Dolgo so fural monopol.
Naj ne jamrajo in začnejo ryzen kupovati, da bo amd imel razlog za zakup proizvodnih zmogljivosti se pri Samsung.
Bwaze6 ::
Intel Announces Core i9-9900KS, World's Best Processor for Gaming Made Better
Torej:
- 5 Ghz all core frekvenca ni garantirana ("up to"?
- tudi nizka base frekvenca 4 GHz ni garantirana ("up to")?
- TDP je seveda podan na base 4 GHz frekvenci
- "Compatible with existing Z390 motherboards" - seveda, saj je le overclockan 9900K
- "Up to 35% more frames per second compared with a 3-year-old PC" - hm, kaj je bil najhitrejši gaming procesor leta 2016? Štirijedrni Intel i7 6700K iz 2015, ki za 9900K v gamingu zaostaja manj kot 20% tudi v najbolj CPU zahtevnih igrah
- 1 leto garancije namesto treh?
- overclocking? Seriously?
Key Features and Capabilities:
Up to 5.00 GHz all-core turbo frequency; up to 4.00 GHz base frequency, which allow games to run faster when they scale across more cores for higher frame rates
Eight cores, 16 threads, 127 W TDP, 16 MB Intel Smart Cache, and up to 40 platform PCIe lanes
Up to 27% faster mega-tasking when you simultaneously game, stream and record compared with a 3-year-old PC
Up to 17% faster 4K video editing compared with the previous generation and up to 78% faster compared with a 3-year-old PC
One-year warranty
Overclock confidently with new and enhanced features like Intel Performance Maximizer, which makes it easy to dynamically and reliably custom-tune the unlocked processor based on the processor's individual performance DNA
Torej:
Nothing to see here.. Sicer cena tudi ni nič višja. MSRP 513$. Dokler bo imel Intel težave s proizvodnjo tako ali tako nima smisla.. Gledaš zaloge v nemških trgovinah in polovice procov ni na spregled. Zato jasno niti cen ne morejo spustit in bodo posledično do nadaljnega na stranskem tiru.
to je skor bolj bedn poskus kot amdjov fx9590
- spremenil: iloveboobz ()
600W 78DB opecka z neznano ceno, verjetno prej 2x ceno tr-ja.
Cene nima, ker bo auction. Torej mora mama od Treera založiti aro za udeležbo nato mu pa še kupiti proc. :P
- spremenil: D3m ()
klinker ::
600W je cel sistem.
in
Zre pa sigurno ene 350W zadeva
we were able to observe a peak power consumption of the system at 600W
in
Unfortunately we could not measure the chip power directly due to some quirks of how Intel manages the power readouts in software.
Ja ok, pumpa kuri.
The Intel Core i9-9990XE Review: All 14 Cores at 5.0 GHz
Jesus thats a lot of TDP. :)
Med branjem je mojo pozornost pritegnilo tudi tole:
It should be noted that Intel’s recent updates regarding Spectre, Meltdown, and ZombieLoad may have an effect on performance. Based on data we’ve seen at Intel, the mitigations hurt the newest hardware the least (compared to say, Broadwell). The system provided by ICC does not have firmware mitigations in place, however we did use an OS version that had some of the software implemented fixes. ICC was clear that some of its customers, while concerned about these issues, just want the fastest system possible based on the way they use these systems
Bwaze6 ::
S temi varnostnimi popravki je že taka zmeda...
Tudi i9 9900KS ima v hardveru nekaj več teh popeavkov kot 9900K, posledično ima slabši IPC, kot so ugotovili na Tom's Hardware:
Our Core i9-9900KS processor comes with the R0 stepping (Stepping 13), which stands in contrast to our -9900K model with the P0 stepping. These in-silicon fixes have been rumored to have some impact on IPC, so we ran a few quick tests.
We set a static 5 GHz clock rate and dialed memory to the respective processors' supported frequency for the following tests:
As we can see, several workloads show some IPC regression, albeit mostly minor ones.
FlyingBee ::
Ko se ravno približuje 1. november, bi bil res že čas, da najmanj upokojijo starčka Core i ali pa kar six feet under. Idealno bi bilo, da bi zdaj kar z novo generacijo prišli, vendar ne bo šlo in bo ga treba v hospicu gledat.
Bwaze6 ::
Eh, Intel na primer v EU še vedno obvladuje 86%+ trga sestavljenih računalnikov - se pravi vseh pisarniških računalnikov, enostavnih mašinc za domače browsanje, in vseh gamerskih računalnikov za tiste, ki se v otroštvu niso igrali z lego kockami in ne znajo sami računalnika skupaj dat...
Dokaj dobro za zombi Skylake iz leta 2015...
Vuli ::
der8auer je dobro navil 9900ks, enih 200W pri 6ghz
- spremenil: Vuli ()
An paper ....
da ga intel zmaga!
Yugo zmaga zetorja na avtocesti.
Pa je to pomembno? Ni.
Enako je zgoraj: test v igrah. Na take teste (k sreči) padajo le FPS drkađije.
Bwaze6 ::
Intel Core i9-9900KS Up To 5.2 GHz All-Core OC CPU Available on Silicon Lottery For $1199.99 US, 5.1 GHz For $749.99 US
Le 3% procesorjev lahko doseže 4% overclock... 4% - namesto 60 FPS s tem overclockom (na custom vodnem hlajenju, seveda) stvar poleti na osupljivih... 62.4 FPS!
In vse to za ubogih 1200 dolarjev, pa še en cent nazaj dobite!
Silicon Lottery Reveals That Only Top 3% Intel Core i9-9900KS CPUs Can Hit 5.2 GHz
zuzelka ::
Ta silikonska loterija je en sam nateg s %. Že za 9900K so trdili da ne gre nikamor, po forumih pa vsi furajo na 5GHz.
Ne vem ali so oni pri vsakem nakupu izgubili na silikonski loteriji, ali pa namerno zavajajo da lahko nabijajo cene.
Tisti cent je marketinški mind fuck, ki ga uporabljamo, da stranka prej vidi in se posledično opogumi z nakupom 11xx.99, kot pa če uporabimo 12xx.00
Bwaze6 ::
Eh, na forumih se pohvalijo predvsem tisti, ki so z namenom overclockanja procesor tudi kupili - koliko od njih pove, da so povprečen procesor lepo poslali nazaj na Amazon ali Newegg, ter vzeli novega?
A to tudi počne folk?
Zanimivo ... očitno imajo preveč časa
FlyingBee ::
Mighty Intel bo moral Price War začet še na drugih frontah, procenti market share mu lepo uhajajo.
FlyingBee ::
Idealna situacija za Intel, se kakšno leto ali dve in AMD bo postajal vse bolj požrešen, ubogi Intel pa se bo raji začel smiliti. Na njihovem 7nm pa bo enkrat že še kaj zraslo in kako se bomo lahko uprli, da ne podpremo ubogega Intela z denarnico.
edi45 ::
za the best performance v igrah je še vedno zmagovalec intel z 9700k/9900k, cenovno pa je tu tu z ryzen 7 in 9, odvisno kje kupiš. Tudi plate so cenejše za intel.
Ti si kar pripoveduj...
Horas ::
si ne rabi ker že ve. on vam govori. ovce
- predlagal izbris: rdecaluc ()
Lej jo ovčko, ki beka. :)
Zelo drag zmagovalec za katerega rabiš še posebej cooler.
- spremenil: D3m ()
Horas ::
za pooryzena pa ne rabiš?? spet se sprenevedaš demček.
Bwaze6 ::
Intel Recalls Boxed Xeon E-2274G Processors Due to Inadequate Stock Cooler Effectiveness
To mora biti pa resno kiksnjeno, da so dejansko vpoklic izdelka izvedli - za 88W TDP štirijedrni procesor so prilagali preslaboten tovarniški hladilnik. Predvidevam, da je morala stvar throttlat že na base frekvenci, turbo itak ni garantiran...
Neumni kitajci jim bodo morda še verjeli.
Zanimivo je, da je članek napisan brez sarkazma.
Avtor se je res dobro nazaj držal. Kake cvetke, neverjetno.
Ti, siroče, sploh razumeš angleško? Ukolokor da, si dovolj funkcionalno pisemn, da razumeš napisano?
Glede na tvoje pisanje sumim, da eno od zgornjega (zate) ne drži.
saj je precej boljši p/p
- spremenilo: FireSnake ()
| » | Nakup CPUja 2019 (strani: 1 2 3 )Oddelek: Kaj kupiti | 24578 (20216) | Predator X |
| » | Intel predstavil 9. generacijo Core procesorjev (strani: 1 2 )Oddelek: Novice / Procesorji | 26897 (23314) | MrStein |
