Forum » Programiranje » escapeJavaScript... v JavaScript
Iščem ekvivalent funkcije org.apache.commons.lang.StringEscapeUtils.escapeJavaScript(String) a napisano v JavaScript-u.
Je skoraj neverjetno, da to ni del standarda, ampak nekako ne najdem.
Stari89 ::
escaping
I feel you. Menim, da si sposoben napisat svojo funkcijo.
JavaScript uses the \ (backslash) as an escape characters for:
\' single quote
\" double quote
\ backslash
\n new line
\r carriage return
\t tab
\b backspace
\f form feed
\v vertical tab (IE < 9 treats '\v' as 'v' instead of a vertical tab ('\x0B'). If cross-browser compatibility is a concern, use \x0B instead of \v.)
\0 null character (U+0000 NULL) (only if the next character is not a decimal digit; else it’s an octal escape sequence)
Note that the \v and \0 escapes are not allowed in JSON strings.
- spremenilo: Stari89 ()
Torej standardne funkcije ni, praviš?
| » | JavaScript v PHP-juOddelek: Izdelava spletišč | 1514 (1299) | drola |
| » | JavaScript zunaj HTMLOddelek: Izdelava spletišč | 1632 (1530) | *wolf* |
| » | [Ajax in Java] v IE6 dela, v Firefoxu neOddelek: Programiranje | 2334 (2088) | krho |
| » | Url validation - Java ScriptOddelek: Programiranje | 1983 (1867) | Trubadur |
| » | Pomoč pri MySQL in PHP...Oddelek: Programiranje | 2405 (2273) | darh |
