a mi je crknu disk al ne
gendale2018 ::
par dni nazaj mi na enem od diskov scrub javi napako pri branju ene od datotek, prav tako mi smart javi napako pri branju
poženem oboje še enkrat, ista napaka/ista datoteka
dam disk ven iz arraya in na njemu poženem badblocks (pisanje in branje) in po treh prehodih še ni nobene napake, lih tko smart že dvakrat ni javil nobene napake)
kaj zdj, a dela al ne >:D
smartctl -a /dev/sdd
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.17.2-1-gendale-ng-4.17.2] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
LU WWN Device Id: 5 0014ee 2b76ab503
Firmware Version: 82.00A82
User Capacity:    3 000 592 982 016 bytes [3,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Sep  2 10:40:48 2018 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (39120) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 393) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       8
  3 Spin_Up_Time            0x0027   179   178   021    Pre-fail  Always       -       6025
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       403
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   075   075   000    Old_age   Always       -       18267
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       399
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       163
193 Load_Cycle_Count        0x0032   195   195   000    Old_age   Always       -       17547
194 Temperature_Celsius     0x0022   113   096   000    Old_age   Always       -       37
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       1
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     18266         -
# 2  Extended offline    Completed without error       00%     18228         -
# 3  Extended offline    Completed: read failure       10%     18165         2041566904
# 4  Extended offline    Aborted by host               50%     18153         -
# 5  Extended offline    Completed: read failure       90%     18144         2041566904
# 6  Extended offline    Completed without error       00%     18012         -
# 7  Extended offline    Completed without error       00%     17367         -
# 8  Extended offline    Completed without error       00%     17201         -
# 9  Extended offline    Completed without error       00%     16733         -
#10  Extended offline    Completed without error       00%     16457         -
#11  Extended offline    Completed without error       00%     16423         -
#12  Extended offline    Completed without error       00%     16325         -
#13  Extended offline    Completed without error       00%     16168         -
#14  Extended offline    Completed without error       00%     16032         -
#15  Extended offline    Completed without error       00%     15674         -
#16  Extended offline    Completed without error       00%     14656         -
#17  Extended offline    Completed without error       00%     13904         -
#18  Extended offline    Completed without error       00%     13751         -
#19  Extended offline    Completed without error       00%     13183         -
#20  Extended offline    Completed without error       00%     12949         -
#21  Extended offline    Completed without error       00%     12709         -
2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 1
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
ja sam mali poštar, kurac mi je oštar
čuvajte se žene, bit ćete jebene
Riff ::
ponavad se pogleda disk z CrystalDiskInfo pa boš videl stanje diska
Miha 333 ::
Verjetno je disk interno remapiral slabe sektorje, zato zdaj ni več napak. Če v nekem času ne bo novih napak, je disk načeloma lahko OK.
Ja, če je badblocks prepisal slab sektor, več ni slab (ali se je remapiral).
Ker sta oba "5 Reallocated_Sector_Ct" in "196 Reallocated_Event_Count" nič, je verjetno prva možnost (prepis).
"imeti na oku"
Če bo začel vedno pogosteje to imeti, je za stran vržt (ali uporabit tam, kjer ne bo škoda podatkov). Sicer pa bo OK.
gendale2018 ::
ne bom zdj šel krast oken samo zarad tega :|
@Miha_333 & MrStein:
mi je že na misel prišlo da je kaj takega ampak sem mislil, da bi pol Reallocated.. bil več kot nič
nisem se pa spomnil da bi ga lahko samo prepisal in bi delalo brez da se števec poveča
no bomo videli kaj bo :)
filip007 ::
Če imaš Linux, potem program Diski in desno zgoraj tri črtice, podatki SMART.
Zero games, zero talk.
A je kar dvema uspelo spregledati, da so SMART podatki že v prvem sporočilu?
filip007 ::
Ja že samo so nepregledni.:))
gendale2018 ::
filip007 je izjavil:
ok zares.. sej zdj smo prišli do tega da zaenkrat zgleda ok, verjetno pa ni glih za imet gor česa zelo pomembnega :)
Riff ::
ja aj če dela zdj bp pol je dobr, če je pakj pomemnga gor si pa nekam skopiraj
filip007 ::
KDE nima tega programa, lahko ga pa namestiš.
pixelzgaming ::
Morda je samo nekaj narobe s tisto datoteko. Jo je možno odpreti / uporabljati brez problema?
PC: Ryzen 7 3700X | 32GB DDR4 | 500GB NVMe | 10TB HDD | RX 6800 XT | Linux
Server: i7 4770 | 32 GB DDR3 | 256GB SSD | 16 + 6 TB HDD | CasaOS
Phone: Realme GT7 | Redmi Note 15 Pro+ 5G | Honor 200 | Motorola Moto G05
gendale2018 ::
pixelzgaming je izjavil:
ne, datoteke ni šlo odpret/kopirat
:P
filip007 ::
Najbolje, da gor odpreš Ubuntu Live, pa daj slikco od programa Diski/Smart podatki, tam se vidi vse.
linux + dm-crypt luks težave z odklepom particije ob bootu
Oddelek: Operacijski sistemi
141431 (1190) gendale2018
HDD napake - uveljavitev garancije?
194400 (3639) bijoloh
Po 2 PB zapisanih podatkov tretjina SSD-jev še deluje (strani: 1 2 )
Oddelek: Novice / Diski
6535725 (29599) Laybach
[Debian] end_request i/o error
71051 (856) čuhalev
[Linux - Grub] OS se mi noče naložiti
191954 (1669) kriko1
