Bluetooth driverji
Bluetooth driverji
SmeskoSnezak ::
MUSE M-950 BT
BTHENUM\{00001800-0000-1000-8000-00805f9b34fb}_VID&000104e8_PID&8080
BTHENUM\{00001800-0000-1000-8000-00805f9b34fb}_LOCALMFG&0045
BTHENUM\{e23b00bc-217c-453b-9c08-fc44577136fe}_VID&000104e8_PID&8080
BTHENUM\{00001801-0000-1000-8000-00805f9b34fb}_VID&000104e8_PID&8080
ne nqjde se driverjev za tole... prosimo za pomoc
@ Pusti soncu v srce... @
nsa_ag3nt ::
Za katero napravo jih potrebuješ ?
https://gizmodo.com/c/goodbye-big-five
_Denny_ ::
Kolikor se spomnim s časov Viste/7, ko sem se igral z bt stvarmi, nisi za slušalke in podobno nikoli rabil driverov...pri 8 in 10 je verjetno isto. Po pairanju v Playback nastavitvah izbereš bt zadevo in je to to.
Z navodil za drug Muse zvočnik:
• On some devices such as computers, once paired you must select
the unit from the Bluetooth menu and choose “Use as Audio Device
(stereo)” or similar.
• Pairing remains intact when the unit and/or your Bluetooth device
is taken out of communication range. An active connection will be
re-established when your Bluetooth device returns within range.
• When the unit is turned on again, it will automatically try to reconnect
with the most recently paired Bluetooth device.
SmeskoSnezak ::
nsa_ag3nt je izjavil:
MUSE M-950 BT...
Windows masina je 7 Pro.
Saj je zadeva zacela zacuda spilat, sam vseeno grdo zgleda da falijo zgornji driverji. Ce je posledica, da naprava neha cudezno delovat in treba "popravlat" zadeve, se raje vidi, da se najde vse te smotane bt driverje.
Riff ::
SmeskoSnezak ::
Masina je Dell Optiplex 3010, al neke takega... pozabo sedaj. Zakaj pa nima MUSE na spletni strani vseh driverjev za te svoje zvocnike?
C#, OBD2 in branje iz porta
Oddelek: Programiranje
192078 (1695) detroit
BigBang notebook dva finalista
365077 (3929) D3m
Win XP SP2 in Blutooth
82441 (2286) jast
nokia 6600
Oddelek: Mobilne tehnologije
112357 (1874) Goldee
BlueTooth težva
91153 (1070) [_MW_]
