Forum » Programiranje » [JavaScript] Spreminjanje zunanje spremenljivke
Tineee ::
Pozdravljeni
Zanima me, če je možno sledeče.
Rad bi spreminjal spremenljivko "color" v datoteki Virus.js:8 iz datoteke PlayerCommands.js. V PlayerCommands.js:51 se začne moja funkcija, kjer uporabnik vpiše barvo. Ta del deluje in pri izpisu na konzolo (PlayerCommands.js:72) vidim barvo, ki jo je uporabnik vnesel. Sedaj bi pa rad to vrednost skopiral v spremenljivko v datoteki Virus.js:8.
Skopiral sem začetke kode iz obeh dokumentov in pa moj del kode v PlayerCommands.js. Dokumenta se nahajata v različnih direktorijih.
Upam, da je vprašanje razumljivo napisano, ker nisem programer.
Virus.js
PlayerCommands.js
Virus.js
var Cell = require('./Cell');
function Virus() {
Cell.apply(this, Array.prototype.slice.call(arguments));
this.cellType = 2;
this.isSpiked = true;
this.isMotherCell = false; // Not to confuse bots
this.color = {
r: 0x33,
g: 0xff,
b: 0x33
module.exports = Virus;
Virus.prototype = new Cell();
// Main Functions
Virus.prototype.canEat = function(cell) {
// cannot eat if virusMaxAmount is reached
if (this.gameServer.nodesVirus.length < this.gameServer.config.virusMaxAmount)
return cell.cellType == 3; // virus can eat ejected mass only
Virus.prototype.onEat = function(prey) {
// Called to eat prey cell
this.setSize(Math.sqrt(this.radius + prey.radius));
if (this._size >= this.gameServer.config.virusMaxSize) {
this.setSize(this.gameServer.config.virusMinSize); // Reset mass
this.gameServer.shootVirus(this, prey.boostDirection.angle());
PlayerCommands.js
var Logger = require('./Logger');
var UserRoleEnum = require("../enum/UserRoleEnum");
function PlayerCommand(gameServer, playerTracker) {
this.gameServer = gameServer;
this.playerTracker = playerTracker;
module.exports = PlayerCommand;
PlayerCommand.prototype.writeLine = function (text) {
this.gameServer.sendChatMessage(null, this.playerTracker, text);
PlayerCommand.prototype.executeCommandLine = function (commandLine) {
if (!commandLine) return;
// Splits the string
var args = commandLine.split(" ");
// Process the first string value
var first = args[0].toLowerCase();
// Get command function
var execute = playerCommands[first];
if (typeof execute != 'undefined') {
execute.bind(this)(args);
} else {
this.writeLine("ERROR: Unknown command, type /help for command list");
PlayerCommand.prototype.userLogin = function (ip, password) {
if (!password) return null;
password = password.trim();
for (var i = 0; i < this.gameServer.userList.length; i++) {
var user = this.gameServer.userList[i];
if (user.password != password)
continue;
if (user.ip && user.ip != ip && user.ip != "*") // * - means any IP
continue;
return user;
return null;
var playerCommands = {
id: function (args) {
this.writeLine("Your PlayerID is " + this.playerTracker.pID);
vcolor: function (args) {
// Get colors
var color = {
r: 0,
g: 0,
b: 0
if (isNaN(args[1]) || isNaN(args[2]) || isNaN(args[3])) {
this.writeLine("ERROR: missing color argument!");
return;
color.r = Math.max(Math.min(parseInt(args[1]), 255), 0);
color.g = Math.max(Math.min(parseInt(args[2]), 255), 0);
color.b = Math.max(Math.min(parseInt(args[3]), 255), 0);
console.log(color.r + " " + color.g + " " + color.b );
this.writeLine("Vcolor set to " + this.playerTracker._name + " to " + color.r + " " + color.g + " " + color.b);
- spremenilo: Tineee ()
swdev ::
Najprej exportaj objekt/funkcijo (v PlayerCommands.js), ki jo želiš uporabiti drugje. Nato pa ta objekt/funkcijo importaj v Virus.js.
Več o tem (Javascript ES6): https://hackernoon.com/import-export-de...
Tineee ::
Malo sem dopolnil kodo.
swdev
Hvala za pomoč, vendar enostavno kodo bi še znal spreminjati (kar sem že tudi naredil), tukaj je pa moja funkcija znotraj spremenljivke "var playerCommands" in ne vem kako nasloviti samo to mojo funkcijo. In tudi ne vem kako nasloviti spremenljivko, ki jo želim spreminjati.
V glavnem, prosim če je za koga zadeva zelo enostavna, če bi lahko napisal rešitev, ker jaz lahko cel teden študiram javo script pa ne bom ugotovil zadeve.
Hvala
P.S.
Ne učim se programiranja. Koda ni moja. To je samo stvar, ki bi jo rad dodal temu programu.
swdev
Hvala
P.S.
swdev ::
Ena dummy delujoča rešitev:
Virus.js
https://es6console.com/jeyj6w2g/
PlayerCommands.js
https://es6console.com/jeyj7kro/
Na tem primeru se ti vrednost colorja iz PlayerCommand prepiše v color v Virus.
Virus.js
PlayerCommands.js
- spremenilo: swdev ()
Tineee ::
Najlepša hvala za trud, ampak zadeva očitno ni tako enostavna kot sem upal
Ko zaženem program mi javi sledečo napako: slika
V izpisu omenja to datoteko:
index.js
Rešeno
index.js
module.exports = {
Cell: require('./Cell'),
PlayerCell: require('./PlayerCell'),
Food: require('./Food'),
Virus: require('./Virus'),
MotherCell: require('./MotherCell'),
EjectedMass: require('./EjectedMass'),
Rešeno
| » | [javaScript] Preverjanje formata zapisa EMŠOOddelek: Programiranje | 3463 (3083) | win64 |
| » | Razvrščanje števil v c#Oddelek: Programiranje | 1790 (1710) | urosp |
| » | JavascriptOddelek: Programiranje | 1466 (1279) | amacar |
| » | [Visual C#] TableAdapterOddelek: Programiranje | 1552 (1428) | detroit |
| » | Valve & STEAM & On-Line gaming (strani: 1 2 )Oddelek: Igre | 9946 (8368) | Tilen |
