Forum » Sedem umetnosti » Highlander (Reboot)
Highlander (Reboot)
‘Highlander’ Reboot Gets Moving After ‘Colony’ Writer Ryan Condal Hands In Script
EXCLUSIVE: It’s been a long time in the works but the reboot of classic warrior franchise Highlander is moving forward. I hear that Colony writer Ryan Condal has delivered a script to Lionsgate and pre-production is set to start later this year.
The studio has been handed a script for the project, which has been in development for nearly ten years after Summit Entertainment acquired the rights in 2008. It is a new take on the feature, which was originally released in 1986, starring Christopher Lambert and Sean Connery, and telling the story of an immortal Scottish swordsman who can only be killed by decapitation. It will be directed by John Wick helmer Chad Stahelski and is set to be produced by Neal H. Moritz.
http://deadline.com/2018/03/highlander-...
IMDB: http://www.imdb.com/title/tt1235529/?re...
Režiser novega Higlanderja bo režiser John Wicka to bi znalo biti zanimivo :)
Pa seveda R rating.
Highlander Music Video: Queen - Gimme the Prize
vostok_1 ::
yup
There will be chutes!
It came from the lab.
2019bosuper ::
Morda bi Hollywood rabil reboot, oziroma bi jih bi bilo treba zamenjati s kakšno verzijo iz alternativnega vesolja.
vostok_1 ::
"There can be only 20 (movies)!"
Kot kaže nekaj bo :)
You brought up Highlander earlier and it's also the first film you're going to direct that's not in the John Wick franchise. You already mentioned how busy you are developing projects, but how are things going with Highlander right now? It's unlike anything you've done before.
CS: We're in heavy development mode on Highlander. Tweaking the scripts, writing, conceptualizing sequences, how we're going to do everything. We probably have a lot more in-person kind of things, but it hasn't slowed down our development process at all.
https://discussingfilm.net/2020/06/24/c...
Gagatronix ::
Se en reboot za katerega ni nihce prosil in katerega nihce noce. (Hollywood execi ne stejejo)
Kurzweil ::
Sej vidim, da je tega že 5 delov
Ne vem točno katerega sem gledal... verjetno prvega, in potem še polovico enega,... zadeva je bila smešna,...
Glede na to, da je original shite, jim mogoče celo uspe, da bo to eden iz promila rebootov, resetov, prequelov, sequelov, drek,... ki bi dejansko boljši
Drugače pa so že pred mano napisali... zgleda bodo idioti prav iz vsega posneli neke reboota
yayo ::
original Highlander je bil evropska produkcija (čeprav po ameriškem scenariju) in so ga veliki ameriški medij v glavnem popljuvali, ker ni bil narejen po Hollywoodskem kopitu. Tv serija katero so po njem posneli je bila, kolikor se spomnem, še ok, nadaljevanja prvega filma pa čisti poden. Verjetno so američani odkupili IP za zelo malo denarja. Zna pa presenetiti.
Gagatronix ::
Jaz se spomnim tistega, v katerem je Sean Connery igral egipcana iz spanije s skotskim naglasom ali kako je ze bila konvolutirana tista zgodba.
Priporočam, da pogledate Highlander (japonski animirani film iz leta 2007):
Super zadeva.
Super zadeva.
Horas ::
Gagatronix je izjavil:
govor za sebe. treba z cajtom naprej.
saj u bistvu NIHČE ni prosil za NOBEN film!!! u bistvu nihče ne ve kaj hoče dokler se mu to ne ponudi.
- spremenil: Horas ()
Hennry Cavill v pogovorih za glavno vlogo v filmu Highlander. Režiser filma pa je režiser filmov John Wick.
Gagatronix ::
A en dober in stirje zanic filmi niso bili dovolj glasen signal da naj nehajo pretepati tega mrtvega konja ?
Horas ::
cavill bi bil kar pravšni.
Highlander Reboot začnejo snemati drugo leto.
Highlander reboot filming with Henry Cavill will begin in 2022
https://www.joblo.com/highlander-henry-...
Horas ::
to pa res, nekaj je na njem z meči
Govorice ampak če držijo potem bodo Hemsworti pobrali vse vloge Henriju Cavillu
Exclusive: Henry Cavill Dropped From Highlander, Chris Hemsworth Eyed For Replacement
https://www.giantfreakinrobot.com/ent/e...
yayo ::
Bah, Chris ima mišice ampak kot igralec nima nekega razpona. Nisem ga videl v veliko vlogah ampak meni povsod deluje kot en avstralski surfer-fotomodel, ki se je znašel v filmu bolj slučajno.
bambam20 ::
BaTeMaN ::
Pa saj tu pa tam kak reboot celo rata.... ne vem naprimer Dune, Dredd, 3:10 to Yuma, 007 Casino Royale, Nolanovi Batmmani, ... morda pa ne bo totalno zanič :)
less then zero
- spremenil: BaTeMaN ()
Henry Cavill's Highlander Reboot Could Be the Start of a New Franchise
https://www.ign.com/articles/henry-cavi...
Lionsgate Moving Forward With Henry Cavill & Chad Stahelski 'Highlander' Reboot As Action-Fantasy Pic Heads To AFM To Enliven A Strike-Hit Market
https://deadline.com/2023/10/henry-cavi...
Proračun filma +100 mio $ in mogoče začnejo snemati že drugo leto.
BaTeMaN ::
Ded je vpet v sedem novih projektih.
Ryan J. Condal je producent reboota, kar je za moje pojme odlično.
less then zero
Originalni film sploh ni bil slab, tiste čase mi je celo nekaj let bil najboljši film, seveda takratni starosti primerno. 2. del že zelo švoh, enako serija (ko živi v Parizu na neki barki, če se prav spomnim).
Za reboot kaj dosti upanja nimam, stavim da bo CGI-bore-fest.
Henry Cavill Reveals Training Will Begin 'In Earnest' for Highlander Reboot
Henry Cavill Says Sword Training for 'Highlander' Tops Earlier Work: "You Haven't Seen Anything Yet"
https://www.hollywoodreporter.com/movie...
yayo ::
tule si bo dal duška, ker je imel v Witcherju občutek, da je razočaral. Med snemanjem prve epizode prve sezone, ko je videl kako zanič so bile mečevalske koreografije je pripeljal na set svojega mečevalskega mojstra, oziroma kar celo ekipo. Mojster, ki je tudi Henryev kolega mu je koreografiral sceno v Blavikenu, ko pokolje bando razbojnice Renfri in na koncu še njo samo. Dejansko je tista scena navdušila gledalce za celo serijo, ker je itak vse ostalo bilo en velik nonsens. In po tisti epizodi ni bilo več ene same borilne scene na takem nivoju, ker je koreograf vskočil samo za tisto specifično sceno.. Kaskaderka, ki se je mečevala s Henryem kot Renfri pa je drugače Lucy Cork, ena od bivših Cavillovih deklet katero je spoznal na setu Mission Impossible. Človek se pač žrtvuje za svoje delo...
- spremenil: yayo ()
Highlander je res dobra vloga za Cavilla, po moje zna biti dobro. Meni izmed boljših franšiz, še Queen so naredili main theme song za ta film
- spremenil: LeQuack ()
Režiser filma Highlander bo režiser vseh 4 filmov John Wick. Kar se tiče same akcije bo verjetno kar brutalno.
Res je edina res dobra mečevalska scena je bila v prvi epizodi.
- spremenil: oo7 ()
Film Highlander začnejo snemati drugo leto januarja na Škotskem.
Chad Stahelski Wants 'Highlander' to Present a New Style of Sword Fighting
- spremenil: oo7 ()
BuDi79 ::
| » | Tom Hardy - Bond James Bond - 007 (strani: 1 2 3 )Oddelek: Sedem umetnosti | 32093 (11123) | Invictus |
| » | Man of Steel 2 (strani: 1 2 )Oddelek: Sedem umetnosti | 10443 (6254) | oo7 |
| » | The Justice League Part One & Part Two (strani: 1 2 3 4 )Oddelek: Sedem umetnosti | 46852 (27045) | mahone |
| » | The Batman Beyond - filmOddelek: Sedem umetnosti | 2851 (2221) | oo7 |
| » | Mož iz agencije U.N.C.L.E.Oddelek: Sedem umetnosti | 4213 (3262) | oo7 |
