Forum » Strojna oprema » RAM za GA-MA790XT-UD4P
Matko ::
Kje si to našel? V navodilih namreč ne piše.
Na parih forumih, pišejo, da jim deluje 2x 8GB.
Han ::
https://www.gigabyte.com/Motherboard/GA...
1. 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory (Note 1)
2. Dual channel memory architecture
3. Support for DDR3 1666(OC)/1333/1066 MHz memory modules
Matko ::
tule ni opcije 2x8GB
http://www.crucial.com/usa/en/compatibl...
http://www.overclock.net/forum/11-amd-m...
https://forums.anandtech.com/threads/ca...
Zato bi rad dobil informacije iz prve roke.
Got 2 x 8GB installed and they worked!
Solved. The problem was the new RAM modules I had bought. For some reason they seemingly work fine, registering in windows with no detectable faults, but they wouldn't allow me into BIOS. I put the old ones back in and now it's fine. I still find this odd. The new modules were hyper fury x series 1866, 2x8GB modules. From what I read before buying them it seemed they automatically downgrade to 1666 and work. The hyper x series was listed as compatible and Gigabyte support knew which ones I was using and didn't raise it as a potential issue. Live and learn.
| » | Nakup plošče z novimi socketi AM3Oddelek: Kaj kupiti | 1143 (1031) | x45 |
| » | Katera Matična plošča je boljša in zakaj???Oddelek: Kaj kupiti | 1136 (1028) | popcorn |
| » | OsebniOddelek: Kaj kupiti | 4076 (3722) | snooze77 |
| » | Nov računalnik (strani: 1 2 )Oddelek: Kaj kupiti | 8343 (5631) | Mitja358 |
| » | Katera plata za AMD Phenom II 955 (940) in Intel Core2Quad 9550?Oddelek: Kaj kupiti | 2430 (2082) | klinker |
