RAM za GA-MA790XT-UD4P
Matko ::
Uporablja kdo GA-MA790XT-UD4P?
Ali podpira mu 2x 8GB rama?
Han ::
Glede na specifikacije podpira največ 4GB/režo. Lahko imaš 4×4GB.
Matko ::
Kje si to našel? V navodilih namreč ne piše.
Na parih forumih, pišejo, da jim deluje 2x 8GB.
Han ::
https://www.gigabyte.com/Motherboard/GA...
1. 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory (Note 1)
2. Dual channel memory architecture
3. Support for DDR3 1666(OC)/1333/1066 MHz memory modules
Matko ::
tule ni opcije 2x8GB
http://www.crucial.com/usa/en/compatibl...
Got 2 x 8GB installed and they worked!
http://www.overclock.net/forum/11-amd-m...
Solved. The problem was the new RAM modules I had bought. For some reason they seemingly work fine, registering in windows with no detectable faults, but they wouldn't allow me into BIOS. I put the old ones back in and now it's fine. I still find this odd. The new modules were hyper fury x series 1866, 2x8GB modules. From what I read before buying them it seemed they automatically downgrade to 1666 and work. The hyper x series was listed as compatible and Gigabyte support knew which ones I was using and didn't raise it as a potential issue. Live and learn.
https://forums.anandtech.com/threads/ca...
Zato bi rad dobil informacije iz prve roke.
Nakup plošče z novimi socketi AM3
51143 (1031) x45
Katera Matična plošča je boljša in zakaj???
51136 (1028) popcorn
Osebni
274076 (3722) snooze77
Nov računalnik (strani: 1 2 )
818343 (5631) Mitja358
Katera plata za AMD Phenom II 955 (940) in Intel Core2Quad 9550?
282430 (2082) klinker
