Forum » Strojna oprema » What games cause issues with 4GB VRAM?
donnieclark ::
Hello,
So, I'm saving some money and I thought that I'll buy a RX 480 for temporary use until VEGA comes out. Buying the 4GB variant will let me start gaming about a month sooner. Since I'll only be using it until VEGA comes out, should I opt for the 4GB one? Or are there games that have issues with 4GB VRAM?
Thanks.
Thanks.
- predlagal izbris: kockish ()
Sssaga ::
Check problems with GTX 970 using 3.5 GB (4 GB technically).
ROTTR for example uses 6 GB and more.
What brought you to this forum, out of all the worldly places? Just curious :)
As for your question. If you are buying only for this 2-3 month period, then VRAM should be the least of your considerations. Just look for minimizing the investment loss. I would suggest buying a second hand gpu with warranty, which you can then resell for similar amount you paid for.
ziga1990 ::
Fantje ali se vam ne zdi tale tema malo čudna, zakaj bi se prijavil na slo tech, če ne zna slovensko ko pa je na internetu vsaj nekaj odličnih računalniških forumov v angleščini?
BivšiUser2 ::
Kaj pravi lociranje IP naslova? M$, GGle,...? NSA,...?
SloTech - če nisi z nami, si persona non grata.
| » | Na katero banko nakazati denar, če zadenem na loteriji?Oddelek: Loža | 7058 (3182) | c3p0 |
| ⊘ | SpaceX reusable rockets (nova tema)Oddelek: Znanost in tehnologija | 6438 (5618) | BigWhale |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20331 (17171) | arrigo |
| » | connecting own dialling router to siol adslOddelek: Omrežja in internet | 2763 (2659) | enis |
| » | GTA3 DodoOddelek: Igre | 3627 (3154) | burekar |
