napaka v c++
napaka v c++
kretze ::
Zdravo majstri kaj ve kdo zakaj mi ta program ne deluje pravilno??
class gradebook
private:
	string courseName;
	int acount;
	int bcount;
	int cCount;
	int dcount;
	int fcount;
public:
	gradebook(string name)
		if (name.length() <= 25)
			courseName = name;
		else
			courseName = name.substr(0, 25);
			cout << "name\"" << name << "\ exceeds maximum lenght (25).\n"
				<< "limiting coursename to first 25 charchters.\n" << endl;
		acount = 0;
		bcount = 0;
		cCount = 0;
		dcount = 0;
		fcount = 0;
	string getcoursename()
		return courseName;
	void dipslaymassage()
		cout << "welcome to the gradebook for\n" << getcoursename() << "!\n";
	void inputgrades()
		int grade;
		cout << "enter the letter grades" << endl
			<< "enter the EOF charachter to end ";
		while ((grade = cin.get()) != EOF)
			switch (grade)
			case 'A':
			case 'a':
				++acount;
				break;
			case 'B':
			case 'b':
				++bcount;
				break;
			case 'C':
			case 'c':
				++cCount;
				break;
			case 'D':
			case 'd':
				++dcount;
				break;
			case 'F':
			case 'f':
				++fcount;
				break;
			case'\n':
			case'\t':
			case' ':
			default:
				cout << "incorect letter grade enter "
					 << "enter a new grade ";
				break;
	void displaygradereport()
		cout << "\n\nNumber of student who recived each letter grade: "
			<< "\nA" << acount
			<< "\nB" << bcount
			<< "\nC" << cCount
			<< "\nD" << dcount
			<< "\nF" << fcount
			<< endl;
int main()
	gradebook gb("c++ programming ");
	gb.dipslaymassage();
	gb.inputgrades();
	gb.displaygradereport();
St753 ::
Bi lahko bil malo bolj specifičen? Kaj ti ne dela? Kje imaš include statemente in zakaj manjka del main funkcije?
kretze ::
int main pa include vse mam kot je treba sem samo kodo skopiral...ja ko vtippkam kako oceno mi vedno piše incorect
St753 ::
Ne vem na kakšen način si ti mislil vnest na tipkovnici EOF? Zamenjaj z drugim veljavnim znakom (poglej si ASCII Chart). Poleg tega cin.get() pričakuje character, tako da nima smisla, da uprabljaš int (pazi tudi pri vnosu številk: 0 != '0'). Naslednji problem je pa v tem, da sprejme cin.get() samo en znak in ko klikneš enter za vnos, gre ta v buffer. Pri naslednjem klicu cin.get() se enter prebere iz bufferja in potem gre to v switch, kjer prideš na default case, zato izpiše incorrect. To lahko preveriš tudi tako, da dodaš cout k enem izmed veljavnih znakov, poleg tega lahko dodaš še case za enter. O vnosu si poglej tukaj: http://www.learncpp.com/cpp-tutorial/5-...
Zate pride v poštev cin.ignore() na koncu while loopa.
St753 je izjavil:
Verjetno kot ctrl-D (oziroma ctrl-Z na "retard OS").
St753 je izjavil:
get() vrača int. Torej je tip int smiseln.
Java skeniranje map in podmap
Oddelek: Programiranje
61634 (1523) nightrage
[Java] While zanka
263166 (2749) kunigunda
[C] struct in int[] (strani: 1 2 )
6510000 (9073) MrBrdo
[c] Enaki datoteki
71401 (1261) Spura
Vodenje videoteke v C++
52195 (2015) Tutankhamun
