Forum » Zvok in slika » Kateri 55" in večji LCD televizor?
misek ::
hodu63, a morda daš kakšen link do sheme enega "modernega" TV-ja? Ker me firbec matra kako je sestavljen.
hodu63 ::
Izvoli
Dal sem link za Philips, ker imajo Philipsi naboljše oz. najpopolnejše servisne manuale. Konkurenca praviloma nima sheme napajalnika ali pa imajo samo blok sheme modulov. Če je Philips v čem dober so to servisni manuali (to velja za televizorje, pri akustiki in gospodinjskih aparatih ne izstopajo).
- spremenil: hodu63 ()
fpbs ::
Izvoli
Hodu, hvala za to shemo, ki sem si jo z veseljem ogledal. Žal mi ni uspelo najti tega P5 procesorja, baje da že 7 generacije.
Andrej, sedaj mi je pa jasno, zakaj si mi večkrat zapisal "da nimam pojma". Upam, da nam boš iz sheme objasnil, kje se nahaja ta namišljeni P5 procesor.
misek ::
chatgpt pravi:
The Philips P5 AI Processor is not a separate physical processor but rather a dedicated image processing engine integrated into the main processor (SoC) of Philips TVs. It is a specialized video processing unit (VPU) designed to enhance picture quality using AI-driven algorithms.
How It Works:
The P5 AI Processor is part of the TV's main chipset, which also handles general processing tasks like running the TV's operating system and apps.
It improves picture quality by optimizing contrast, sharpness, color, motion, and source quality in real time.
The "AI" part refers to machine learning algorithms that analyze and enhance content dynamically.
So, while it's often marketed as a separate processor, it is actually a software and hardware feature within the main SoC rather than an independent physical CPU/GPU.
andrej69 ::
Izvoli
Sem napisal nekaj postov nazaj kako in kaj..
hodu63 ::
Fpbs, ne napadaj no Andreja, saj si ni on izmislil teh nategov proizvajalcev. Pri Lg ni nič drugače, tudi tam je zadeva podobna. Nobenega posebnega super duper Alpha dodatnega slikovnega procesorja ni, main procesor opravi vso delo in to čisto v redu. Lg je tu v mogoče v boljšem položaju, ker kolikor vem sam izdeluje procesorje za svoje televizorje, Philips pa nima lastne proizvodnje procesorjev.
Vsi proizvajalci trdijo, da imajo njihovi aparati nek poseben procesor samo za obdelavo slike, v veliki večini pa temu ni tako.
easyrider3 ::
Kaj pa potem dela razliko v kvaliteti slike,če ne grafični procesor ali kaj že spada zraven,da obdela sliko ???
Nekaj obdeluje sliko a ne????
hodu63 ::
V televizorjih ni ločenih grafičnih procesorjev. Vse se dogaja v glavnem procesorju, katerega sestavni del je tudi gpu. Razliko dela software oz. algoritmi za obdelavo slike. Zato imata lahko npr. Philips In Sony z enakim procesorjem popolnoma različno procesiranje in s tem različen karakter slike. Proizvajalci vlagajo ogromno denarja v razvoj softwerja. V bistvu jih razvoj softwerja stane mnogo več kot razvoj hardwerja.
misek ::
Razliko dela software oz. algoritmi za obdelavo slike.Ne verjamem, da se slika procesira programsko, saj so za kaj takega tile čipi precej prešvoh. Bolj gre za strojno enoto znotraj procesorja (t.i. VPU), ki se ga krmili z različnimi nastavitvami. In glede na nastavitve dobiš pač neki rezultat. Nekdo, ki se na delovanje VPU in njegove nastavitve bolje spozna, bo dobil boljši končni rezultat.
andrej69 ::
Uporablja različne procesorje odvisno od modela do modela. To pa so LX Semicon, Realtek in Mediatek.
hodu63 ::
Vidiš, tega pa nisem vedel. Zmerom sem bil prepričan, da Lg sam razvija in proizvaja procesorje za svoje televizorje. Še posebej zato, ker na procesorjih v Lg aparatih piše Lg, na procesorjih v Philipsu pa ne piše Philips. Ampak res je, pri proizvajalcu čipa lahko naročiš, kaj bo gor natisnjeno, to se desetletja dela v avtomobilski industriji.
fpbs ::
In kam po lestvici zmogljivosti spada NovaTek NT72676 ?
hodu63 ::
Po pravici povedano pojma nimam. Mogoče bi Andrej vedel. Tako na oko so kar zmogljivi, televizorji s Titan sistemom, ki jih praviloma poganjajo Novatek procesorji so kar odzivni.
fpbs ::
Če se prav spomnim, je LX Semicon hčerinsko podjetje LGeja, specializirano za razvoj in proizvodnjo polprevodnikov.
fpbs ::
Sem dobil odgovor:
"NovaTek NT72676 je SoC (System-on-Chip), ki se uporablja predvsem v pametnih televizorjih srednjega razreda. Tukaj je nekaj ključnih značilnosti, ki določajo njegovo zmogljivost:
Procesorska arhitektura: NT72676 temelji na štirijedrnem procesorju ARM Cortex-A73, ki deluje pri frekvenci do 1,5 GHz. To omogoča solidno zmogljivost za obdelavo slike in osnovne pametne funkcije.
Grafična zmogljivost: Vključuje Mali-G52 GPU, ki podpira 4K ločljivost in barvni prostor DCI-P3, kar omogoča živahne barve in dobro kakovost slike.
Ciljni trg: NT72676 je zasnovan za televizorje srednjega razreda, kjer ponuja dobro ravnovesje med zmogljivostjo in stroškovno učinkovitostjo. Ni pa primerljiv z vrhunskimi SoC-ji, kot so MediaTek MT9618 ali LG α9, ki so namenjeni premijskim modelom.
Na splošno NT72676 spada v srednji razred SoC-jev za pametne televizorje, kjer ponuja solidno zmogljivost za vsakodnevno uporabo, vendar ne dosega vrhunskih zmogljivosti, ki jih zahtevajo napredne funkcije ali intenzivne aplikacije".
Danes je vse softver.
Glede zmogljivost: že pred desetletji je navaden CPU znal marsikaj na videju sprocesirati.
Kot en poenostavljen primer: poglej, kateri CPU je znal v živo kodirati MPEG.
simone ::
Kaj pa predlagate za nakup v trgovinah big bang ali pa harvey norman?Izbire nekaj je kaj se splača kupit v rangu do 700 evrov?
Pred 10 dnevi sem ti dal predloge. Pa nisi nič komentiral. A si jih pogledal? Če ni odziva, potem je težko še karkoli svetovati.
Seveda sem pogledal.Mene konkretno zanima philips,samsung ali pa lg, drugega niti ne gledam mogoče tlc ampak ne poznam nekako te znamke in tudi kvalitete ne.Gledam v trgovinah big bang in harvey norman izbire je veliko.Nekje do 700e bi kupil.Kaj moram pri nakupu gledat vem da je teh tehnologij velik (katera tehnologija je najboljša) pa operacijski sistem najraje bi imel android tv za ostale ne vem kako se obnesejo,pa frekvenca osveževanja itd...Mene zanima kateri aparat bi bil do te cene najboljši nakup v teh dveh trgovinah ker izbire je kar nekaj tv se pa kupuje za daljše obdobje....
fpbs ::
In kaj ti pri tem predlaganem modelu ni všeč? https://www.ceneje.si/Izdelek/48719013/...
Drugače, pa najboljša tehnologija je OLED, samo boš moral dodat še 300€. Ne vem, zakaj hočeš kupovat ravno v teh dveh trgovinah, zakaj hočeš Android. LGejev WebOs je priznan, kot uporabniku najbolj prijazen, najhitrejši, brez štekanja...LGejeva telekomanda z miško in mikrofonom je daleč najbolj uporabna.
Anney ::
Včeri sem kliknil 55PML8709/12 za v spalnico. Za pornče bo ok.
andrej69 ::
Odličen izbor ti je sedaj za takšno ceno ta Philips MINI LED:)
https://www.bigbang.si/philips-thextra-...
fpbs ::
Sem dobil odgovor:
S tega lahko sklepamo, da je ta namišljeni Philipsov procesor, ki ne obstaja, "P5 Perfect Picture Engine Gen 7" povsem povprečni procesor z vgrajeno povprečno grafiko.
Bravo Philips, bravo Andrej, ki si držal štango, za vrhunski nateg! Mogoče pa Andrej tega sploh ni vedel? Vprašanje, ča je sploh kdaj videl shemo.
easyrider3 ::
Najbolj važno je kakšno sliko bo prikazal TV zdaj ali je v njem ekstra procesor ali krompir,kumare je vseeno važno,da je slika dobra.
damirj79 ::
Najbolj prijazen uporabniku? Dvomim. Home screen zgornja polovica!!!!! slike je samo slika, ne moreš je niti spremeniti, niti je zmanjšati!!!! Potem imaš v sredini trak s fukcijami (home office, music, game, sports itd) katerega namena sploh ne morem ugotoviti in niti ga ne moreš spremeniti ali brisati!!!! potem pod tem je trak z aplikacijami, mešano s sistemskimi aplikacijami in itak da sistemakih ne moreš zbrisat!!!!
In potem imaš še v spodnji tretjini "top picka for you", ki ga itak ne moreš zbrisat.
Aja to da občasno webos zmrzne in pomaga samo izklop iz elektrike je treba tudi povedat. Enako kot android.
Netflix se na lg oled b3 zaganja tako na očke 2x dlje, kot na čipšit hisense android tv 40", ki ga T-2 prodaja za 180€. Ps to je edini Hisense AndroidTV dobavljiv v EU.
Mimogrede daljinec z miško nima možnosti izklopa miške. Malo ga preveč potreseš in se pojavi kazalec, med gledanjem filma. Vrhunsko doživetje. Priporočam.
fpbs ::
Jaz imam C8. Sedaj bo že sedmo leto, pa me na njemu nič ne moti. Slika je še vedno kot prvi dan. Do sedaj mi še ni nikdar zaštekal. Miška mi je zelo uporabna, in še nikdar nisem pomislil, da bi jo izklučil. Danes zagotovo nebi kupil TVeja brez miške.
Nikonja ::
Jaz sem na C9 in ne vem če se mi 2 krat v 6ih letih zgodilo da WebOS zmrzne. Netflix se odpira, do menija za izbiro profila (zdaj merjeno) 3,1 sek, rees predolgo. Edina aplikacija katera je počasna je Plex ampak preživim ker ni spet tolk hudo.
Miška pa je zakon posebej za tipkat... naslednji tv bo ziher spet LG
damirj79 ::
Glede slike nimam pripomb. Jasno je slika čisto OK. Motijo me detajli z uporabniške izkušnje, o kateri si pisal in se tvojim mnenjem ne strinjam in še razložil sem zakaj ne.
ampak da smo točni, tako izgleda slika na WebOS:
In ta home screen je obupen. Da bi se ga dalo vsaj customizirat, pa se ne da. Tisti avtič čez 1/2 ekrana je smešen, da ne rečem beden.
damirj79 ::
Dolgo, ne predolgo, stvar debate. Jaz pišem o tem, da se tu gor dela reklama, da je Android počasen in obupen in ne vem kaj še vse, ampak na čipšit Hisense Android TV (pojma nimam kateri model točno, mogoče 40A4H), ki mimogrede, če nisem še napisal, stane 180€, se Netflix odpre 2x hitreje. Youtube enako. Pač nekej ne štima v razlagi, kaj je hitro in dobro.
rini ::
Ssmsung 55 q80d pri Makspro
gregor ::
Kaj na LG WebOS se morate še vedno vsakič znova prijaviti v YT Premium?
Pre meni je tako že kakšen mesec, morda dva...
Prej me je več let vrglo direktno na glavno YT stran.
Ali pa imam samo jaz to težavo. Pa sem že poizkušal z odjavami in prijavami na prenosniku, telefonu, tablici, TV. Nič ne pomaga.
Nikonja ::
lubej1 ::
scipascapa je izjavil:
da
https://www.makspro.si/oled-tv-sprejemn...
ima kdo izkušnje z to trgovino?
sem jim poslal email in je bilo vse tiho
neprofesionalno
očitno bo potreben telefonski klic oz...??
damirj79 ::
da
neprofesionalno
Ja jaz sem imel isto izkušnjo. Sem nato vzel kar v Merkurju in sicer preko opcije "izenači ceno" kjer sem navedel ravno povezavo do artikla te trgovine. Niso mi sicer dali čisto enake cene, 20€ je bila višja, ampak potem v Merkurju če imaš kartico in vsaj zlati razred, dobiš še par % vrednosti nakupa dodatnega bonusa za naslednji nakup. Ker je bilo bonusa za 40€, nisem niti dosti študiral...
Sharp999 ::
Prosim za pomoč. Iščem en 55 in en 65 inch televizor. Uporabljal ga bom za domačo uporabo (nisem preveč zahteven uporabnik) za normalno gledanje tv-ja, včasih tudi kakšnega filma.
Kateri TV mi priporočate, glede na zahteve:
-Iščem OLED
-Znamka mi niti ni pomembna
-Po možnosti ambilight
-Ni potrebno da je SMART TV (lahko pa tudi)
Hvala.
-Iščem OLED
Hvala.
andrej69 ::
-Iščem OLED
Hvala.
A res potrebuješ OLED za tvoje potrebe gledanja..?
knap ::
da
neprofesionalno
ista zgodba pri meni, poslal 2x email, vse tiho je bilo, nato poklical in se zmenil
vsekakor ni dober takšen pristop prodajalca, ampak za razliko v ceni sem pač moral malo potrpeti..., če se prav spomnim je šlo za 180 EUR
morda imajo preveč naročil in jim je vseeno...
Sharp999 ::
-Iščem OLED
Hvala.
Seveda.
andrej69 ::
Sharp999 ::
Tukaj imaš nekaj modelov.
https://www.bigbang.si/philips-oled-4k-...
https://www.makspro.si/avdio-in-video/t...
https://www.bigbang.si/samsung-oled-4k-...
Hvala...Katerega mi priporočate, po čem se razlikujejo,...?
andrej69 ::
Razlikujejo se po obdelavi slike, OS-u, zvoku itd.. Priporočam enega izmed Philips modelov, če hočeš imeti Ambilight. Ali pa Lg C4.
Malo si poglej teste za omenjene modele, ali pa pojdi v kakšno prodajalno pa poglej v živo te modele.
fpbs ::
-Iščem OLED
S kakšne razdalje se bo pa gledalo s tem dvema televizorjema? Kaj nebi bilo bolje, da se najprej odločiš za enega, za drugega se pa odločiš malo kasneje? Ali ti je poleg kvalitete pomembna tudi cena?
Sharp999 ::
-Iščem OLED
Kupil bom 2 ker ga mislim imeti v jedilnici in dnevni sobi posebej. Razdalja je tam kjer bo 55inch od 2,5m - 3,9m. Tam kjer bo 65inch je pa tudi cca 3m razdalja. Cena mi ni tako važna za 55inch do cca 1300€ recimo....65 pa vem da je dražji..
fpbs ::
Glede na razdaljo gledanja, predlagam, da najprej vzameš diagonalo 65", potem se boš pa odločil za drugi TV, ali bo diagonala 55", 65", ali pa morda 77".
Predlagam ti ta dva modela:
gregor ::
o tem sem govoril:
to okno se pojavi ob vsakem zagonu YT aplikacije na TV
ali vse vas ostale vrže direktno na YT stran, brez tega okna...?
hvala
easyrider3 ::
Nimam LG TV ampak na Samsung,Sony,Hisense,TCL in Philips televizorjih mi Youtube deluje tako kot treba brez vsakič prijavljanja.
Pritisneš za Youtube in si direkt notri.
Isto je na prenosniku ali telefonih
- spremenil: easyrider3 ()
