Forum » Zvok in slika » Kateri 55" in večji LCD televizor?
leiito ::
55" XE90 je v MediaWorld Italia €1.999, pa niso najcenejši.
Te meritve sverilnosti za Q7 so nenavadne, ker potem tivi s ceno €3.500-€4.000 ni UHD Premium.
Gatsu ::
Sej spodaj pod opisom piše kako so kupili potem še en tv in so bile meritve praktično enako "slabe" nakar so vse te meritve potrdili še Samsungovi ljudje. Zdej a gre za tovarniško napako ali pa golo zavajanje potrošnikov na staro slavo bomo pa še videli tekom leta. Zaenkrat je X900E od 2017 modelov zasluženo best buy.
We have contacted Samsung, and they say that our unit is out of spec due to the relatively low peak brightness measurements. We will continue to investigate and update the review as we obtain more information.
Update 03/10/2017: We've ordered another unit. We will test it, verify the results and update the review.
Update 03/15/2017: We bought another Q7F from Amazon and measured the viewing angle, contrast and brightness of this new TV. All of these results are in the same ballpark as our original findings.
Update 03/17/2017: We invited Samsung's engineers to our lab in Montreal. They confirmed the validity of our measurements of peak brightness on our two units using their equipment. They commented that peak brightness measurements are lower than specification, the Q7 should reach 1000 nits while viewing HDR in Movie mode. They are investigating the issue.
andrej69 ::
Kot sem že napisal, ni vse v nitsih kar se tiče prikazovanja 4K- HDR slike:) Bolj pomebno je, da ima televizor FALD.
- spremenil: andrej69 ()
Gatsu ::
Sony A1 Oled pride v Evropo drugi mesec za 3999€ (55) ter 5499€ (65). www.flatpanelshd.com ima že slab teden tv na testu, tako da bo verjetno še ta teden objavljen.
andrej69 ::
Tukaj so cene za Sony televizorje 2017.
651 : 5499 EUR
55AE1 : 3999 EUR
D-759405: 5.999 EUR
D-659305: 3.699 EUR
D-559305: 2.699 EUR
759005: 4.999 EUR
659005: 2.799 EUR
559005: 1.999 EUR
499005: 1.599 EUR
758596: 4.499 EUR
558505: 1.599 EUR
658505: 2.499 EUR
558096: 1.399 EUR
498005: 1.199 EUR
438005: 999 EUR
Še cene Philips televizorjev 2017.Nekaj modelov, še bo na voljo kasneje v tem letu.Kot recimo model 8602UHD Premium, in z QD tehnologijo.
559002 3.199 UR
65U7502 2.499 UR
55U7502 1.699 UR
49U7502 1.399 UR
55U6482 1.399 UR
49U6482 1.099 UR
65U6412 1.799 UR
55U6412 1.149 UR
49U6412 949 UR
43U6412 849 UR
651 : 5499 EUR
55AE1 : 3999 EUR
D-759405: 5.999 EUR
D-659305: 3.699 EUR
D-559305: 2.699 EUR
759005: 4.999 EUR
659005: 2.799 EUR
559005: 1.999 EUR
499005: 1.599 EUR
758596: 4.499 EUR
558505: 1.599 EUR
658505: 2.499 EUR
558096: 1.399 EUR
498005: 1.199 EUR
438005: 999 EUR
559002 3.199 UR
65U7502 2.499 UR
55U7502 1.699 UR
49U7502 1.399 UR
55U6482 1.399 UR
49U6482 1.099 UR
65U6412 1.799 UR
55U6412 1.149 UR
49U6412 949 UR
43U6412 849 UR
leiito ::
leiito ::
ampak ko bereš reviewje, bi si res mislil, da je vse v luminanci. Pocket-lint o novih Philipsih:
"...7502 is the flagship model..it doesn't quite match the high brightness levels of the 9002, with maximum brightness of 400nit, but it has a similar design aesthetic, with a brushed aluminium open desktop stand and bezel."
"...6482...It has 400nit brightness, HDR10 and HLG support and a Micro Dimming Pro backlight, which dims areas to match the on-screen action in order to provide better contrast."
"6412...Almost everything you find on the 6482 is also on the 6412 although its brightness is lower, being rated at 350nit, so bright areas will look visibly dimmer than on any of the sets above."
Po napisanem sodeč bojo svetle scene torej pri 350 nitih "visibly dimmer" kot pri 400, kaj bo potem šele 400 nitov v primerjavi z npr. Sonyjevih 700 nits na xe900, 7x bolj "visibly dimmer"?
andrej69 ::
Seveda je razlika, med temi modeli ki zmorejo večjo svetilnost in modeli ki nimajo tako velike svetilnosti.
Toda zelo pomebno je, tudi kakšno kvaliteto zatemnevanja ima določen model televizorja, kako so postavljeni pixli, kakšna je zmogljivost samega procesorja itd..Tukaj so še specifikacije Philips modelov 2017.
andrej69 ::
Tukaj si lahko prebereš. Philips 7601 in Samsung KS8000.
Na kraju dolazimo do UHD i UHD HDR sadržaja. Sjediti metar i pol od velikog ekrana sada je potpuno normalno i količina detalja u slici to i zahtijeva. Oba modela mogu prikazati Ultra HD rezoluciju uz 1:1 mapiranje piksela, što ponajprije u statičnim kadrovima otkriva golemu količinu detalja. Tijekom ovog usporednom testa nam je stigao i Planet Earth II na UHD Blu-ray mediju što smo već nakon prvog gledanja stavili na listu referentnih materijala i do danas u nekoliko navrata pogledali na oba televizora.
Prije samog testa smo znali da je Samsungov kandidat UHD Premium certificiran, što znači da može postići svjetlinu slike preko 1000 cd/m2, kao i prikazati više od 90% DCI-P3 raspona boja unutar BT.2020 spremnika. Philipsov model, baš kao ni ranije testirani Sonyjev 55XD9305 nema spomenuti certifikat, već proizvođač navodi pojmove poput HDR Premium i Premium Color što bi trebalo pružiti "premium" HDR iskustvo. Što to točno znači u praksi?
Kako smo u uvodu naveli, gledali smo najprije isti UHD Blu-ray sadržaj na jednom, pa zatim na drugom televizoru, a tek smo neke demo snimke i testne uzorke gledali istovremeno na oba televizora. U ovom trenutku imamo samo jedan UHD BD reproduktor pa druge opcije ni nemamo. Ono što smo prilikom takvog gledanja uočili jest kako Samsungov model pruža očekivano dobro iskustvo uz dinamičnu sliku i duboke boje. Iste te performanse smo vidjeli kod 49KS7002, 49KS7502, pa i 49KS9002 modela. Od svih UHD Blu-ray naslova koje imamo u kolekciji najviše smo vremena proveli gledajući Planet Earth II i to ne samo zato što je jedini naslov koji dolazi na 2 diska.
Naslovi poput ovog bi se trebali gledati pod obavezno na ovako velikom ekranu koji ujedno može i prikazati sve one ljepote koje su tako savršeno snimljene i pohranjene na kompaktni disk. Samsungov model odrađuje posao onoliko dobro koliko može s obzirom na LCD tehnologiju koju koristi i činjenicu da je sadržaj sniman u 24 sličice po sekundi pa u pokretima se mnoštvo detalja izgubi. Boje su dobre, nijanse bez prigovora, a HDR efekti jasno vidljivi. Jedini detalj koji bismo voljeli da je bolje riješen jest kontrast slike - jednostavno nakon što jednom vidite kako izgleda HDR slika na OLED TV-u to zauvijek ostaje u sjećanju. Je li Philips u tom pogledu bolji?
Philipsov kandidat definitivno odrađuje bolji posao kada je kontrast HDR slike u pitanju iz jednostavnog razloga jer ima sofisticiranije LED pozadinsko osvjetljenje. Preciznije zatamnjenje slike gdje je to potrebno pruža realističniju crnu boju, a kada je crna boja dobra i ostale boje se jasnije ističu. Iako je pri A/B usporedbi jasno vidljiv veći raspon boja kod Samsungovog modela, u praksi se ta razlika nije tako očito vidjela i zapravo smo bili pozitivno iznenađeni prikazom boja kod WCG (Wide Color Gamut) sadržaja. Što se HDR efekata tiče, oni nisu onako jarki kao kod Samsungovog modela, no ponovno tijekom gledanja sadržaja nisu bili onako prigušeni kako bi se moglo očekivati. Jedan od razloga je i taj što Samsungov model nema jednaku jaku svjetlinu konstantno već ju varira i to do vrijednosti nižih od vršne Philipsove. S druge strane, Philips je tu konzistentniji i zadržava istu svjetlinu čak i ako je HDR efekt dulji period na ekranu (mi smo testirali u trajanju od jedne minute).
Dodajmo cijeloj priči kako Philips ima tzv. Perfect Contrast kontrolu uz koju je moguće podesiti "tone mapping", odnosno "highlight rollout". Radi se o prikazu detalja u najsvijetlijim dijelovima slike, a koje zaslon fizički nije u stanju prikazati. Isključen Perfect Contrast će prikazati sadržaj onako kako je masteriran, dakle svi detalji će biti sabijeni u prostor koji zaslon može prikazati. Aktivacijom navedene kontrole slika će dobiti na dinamičnosti no dio detalja će izostati - koliki dio ovisi o tome jeste li odabrali minimalnu, srednju ili maksimalnu vrijednost. Preporučamo da sami pogledate nekoliko scena i pronađete opciju koja vam najbolje odgovara. Zanimljivo da Samsungov model nema takvu kontrolu, a ono što smo probali s Dynamic Contrast opcijom bilo je preintenzivno i nije donijelo bolji rezultat.
commissar ::
hej, kako bi jaz preveril kalibracijo mojega 65pus7601 philipsa?
Ne vem ali je za rahel zelen odtenek, ki se pojavi, ko so obrazi na zaslonu zatemnjeni kriv slaba kvaliteta filma ali slab TV.
leiito ::
Priporočene oz. kalbirirane nastavitve za 7601 najdeš na netu, kot za veliko večino tivijev, npr:
https://www.avforums.com/video/philips-...
http://www.supportforum.philips.com/en/...
A to Philips sam objavlja? Če ja, je pohvalna transparentnost, sicer proizvajalci neradi jasno povejo že ali je zaslon 50 ali 100 Hz, kaj šele svetilnost (ja vem, nits niso vse) z največjimi črkami pa razne PQI indekse.
- spremenil: leiito ()
L1nK ::
obstaja 49 inch ustreznica philipsu 65pus7601, se pravi premium certified, nad 1000 nit hdr, dober input lag in upscaling ostalih vsebin? je tale ali kateri drugi http://www.philips.si/c-p/49PUS7181_12/... ? 50" je maksimalno, kar bi vzel
https://www.facebook.com/link.zhizhekian
- spremenil: L1nK ()
andrej69 ::
Philips ničesar ne skriva, kakor tudi Sony ne. Ostali proizvajalci že malo skrivajo te podatke.
andrej69 ::
Tale model Philipsa 7181 se ne more primerjat z modelom 7601, čeprav je kvaliteten televizor.V rangu Philipsa 7601, bi bil Samsung KS7000 ali KS 8000.Ali Sony model XD9305.
Za Philips model 7181, si lahko pogledaš teste.
https://www.avforums.com/review/philips...
http://www.hdtv.com.pl/forum/philips/12...
commissar ::
To sem že seveda naredil, pravtako sem se sam hecal in testiral cel teden. vendar slike v nekaterih (toplih) prizorih izgledajo takole.
uporabljene so nastavitve iz https://www.avforums.com/video/philips-...
Primerjano s PC monitorjem, kjer je barva veliko bolj naravna, kljub backlight bleedu:
Nimam več ideje kako tole odpraviti, bi prosil za pomoc.
Ker takole TV za 2000 EUR res ne sme zgledati!
- spremenil: commissar ()
commissar ::
errhec ::
@ commissar meni se zdi slika na PC monitorju, kot da se je preveč izostavila sončenju v solariju.
Tudi svetilke v ozadju na PC monitorju so zelo rumene. Meni se zdi naravnejša slika na TV-ju, je pa težko ocenjevati preko slik.
dd
andrej69 ::
Tako kot je že errhec dejal.Slika izgleda dobro na tv-ju.Na monitorju je že preveč kričeča..Izgleda , da imaš rad bolj močne barve.Drugače je slika vrhunska, na tem televizorju.
commissar ::
@errhec, @andrej69.
Ja vem, na monitorju ima toplejse nastavljeno, ker vecalimanj gledam v belo ozadje.
Ampak na TVju nima tista zelena okrog oci, pod brado in po laseh kaj delati. To je cisti kiks.
Tega se ne vidi ne na monitorju, ne na ipadu ne na telefonu.
razumem, da je slika prevec živa na monitorju, ampak meni ta zelena povsem ubije izkusnjo gledanja fima.
V gibanju izgleda se hujse, ko se te zeleni odtenki premikajo po obrazu, glede na osvetlitev scene.
commissar ::
Probaj še kakšen drug izvor - film.
Sem probal ze vse. Bom pa popoldne oz. zvecer poslikal ta prizor v vseh moznih nastavitveh.
Je pa zanimivo da koza postane taksna samo v toplih prizorih. V primeru da je scena modra je slika ok. Oz vsaj jaz ne najdem taksne ocitne napake.
commissar ::
Torej, vprasanje. Taka slika ni v redu, ne? To ni zaradi VA panela? Noben primerljiv TV nima takih problemov?
Ce predpostavljamo, da se tega ne bo dalo popraviti z nastavitvami.
Gatsu ::
Jaz vem rešitev. Neseš nazaj. Dodaš 600EUR in imaš Sony 65XE9005 :) OZ ne trenutno imajo v electronic4you OLED 65B6 za samo 2600EUR!!!! Če imaš šanso kupit na firmo je to samo 2000EUR
- spremenil: Gatsu ()
commissar ::
andrej69 ::
@commissar
Če gledaš SD ali HD vsebine moraš nastavit na ISF Day, če pa gledaš HDR vsebine pa moraš nastavit na ISF Night. Poskusi tudi z opcijo Perfect Contrast. Še zanimivost, recimo Samsung ima težave z zeleno barvo, Philips pa z modro barvo.Ti pa si dejal, da pri prikazovanju modrih scen ni težav.Tako, da tukaj nekaj ne gre skupaj.
commissar ::
Poskusil tudi z ISF day, in ni razlike, razen da je slika pac svetlejsa.
Kaj to pomeni, da ima Samsung tezave z zeleno, pilips pa z modro?
Pri meni ni problem z nobeno od teh barv, ampak je da se koža, v prizorih s toplejsimi barvami, pobarva zeleno, kot je razvidno na sliki.
Ljudje s temnejso poltjo oz. črnci so bolj dovzetni za zeleno barvo.
Bom zvecer prilepil vec slik z razlicnimi nastavitvami.
Poskusil sem tudi perfect contrast. Zeleno obarvana koza je prisotna.
Se enkrat bi vprasal... tole ni normalno delovanje TVja, ne?
leiito ::
Ja, ce tole ne bo se dalo zrihtati bo treba kar menjati.
Ni to B6, neka starejši LG model nizjega ranga je, €2.499 za 65 inč, best buy ever.
Tisto zelenilo na Philipsu zihr ni normalno, 7601 sicer ne bi bil tako dobro ocenjen. Če so dejansko objektivni, nekatere ocene, tudi na rtings, človeku vzbudijo dvom.
L1nK ::
a sony XBR49X900E ter BRAVIA XE90 (X90E) 4K Ultra HD HDR TV sta enaka teveja? za različne trge
leiito ::
Kako ni? Evo ti link! Pa Mediamarkt.at ima tudi to ceno.
Res je, sori, za slowence ponujajo nekaj drugega, moaš Osterreich kliknt. €2.600 je pa že zelo mamljivo.
jp
cosmicsuper ::
Navdušujem se sicer za nakup LG oled C6 (55inčev), vendar zaenkrat zaradi cene še ne pride v poštev. Bi pa potreboval nov TV, imam namreč vsaj 5 let staro Panasonicovo 42 inčno plazmo. Slika je še vedno O.K. (novejših TV pač še nisem gledal in če ne veš ne boli). Mi je pa postala premajhna...
Najprej sem se ogreval za Samsunga 55 serija 7000 (cca 1200€), nato hisense 7000... bi si pa precej želel 3D, zato je želja C6... no potem pa sem prišel na idejo, da za vmesno obdobje (največ 2 leti) nabavim kakšen 1080p TV s 3D, trenutno se nagibam k Sony KDL-55W809C pri Maks pro 775€.
Prosim za vaša mnenja, ali je nakup 1080p TVja danes nesmisel ali pač ne. Ali obstaja še kakšen TV za podobno ceno s solidnim 3D....Gledam večinoma filme in nanizanke v 1080p oz. 720p, po TVju (Siolbox) pa kakšen šport..Bi pa rad preizkusil 3D, dokler ne umre. Playstation, netfilx,ipd ne uporabljam...4K je še v razvoju in me trenutno še ne zanima preveč.....
HVALA
HVALA
leiito ::
Ob abnormalnih padcih cen LG OLEDov se poraja nekaj vprašanj, če ima kdo morda smiselen odgovor. Zakaj padajo cene tako zelo samo pri LGju in niti ne za vse modele, ampak samo za OLEDe? Je to znak, da se slabo prodajajo? Ali razprodajajo zadnje zaloge in jih ne bo več v prodaji? Valjda ne bo čez dva meseca 55" B6 €1.499, 65" B6 pa €2.399, kdo bo potem kupoval letošnje modele za 2x višjo ceno? Poskuša LG približati OLED tehnologijo masam ali je morda agresivna cenovna politika usmerjena proti konkurenci? Kakšne so nabavne cene trgovcev, da lahko dajejo take popuste? Gotovo jih mora LG odobriti, predvidevam da vsaj grosistom LG reče oz. dovoli, da tako zelo znižajo cene in jih ustrezno kompenzira, ne dobivajo valjda prodajalci LGjev tako poceni, da je marža 100% in še več.
L1nK ::
če bi rad preizkusil 3d, pojdi raje v ustrezen kino na par predvajanj, ne pa da boš kupoval nov tv zato. počakaj še malo, da oledi še padejo v ceni, če so za tvoj žep še predragi. jaz sem tudi od 2009 na 42" pany plazmi in mi je še vedno cool TV, verjetno sd vsebin ne bo nikjer tako dobro kazalo, kot na njej. pa bom spet bentil. al pa nad črnimi barvami in bleedingom pri kakšnem LCDju za okrog 1000EUR. to je nekak moja meja spreejmljivega za TV. nisem nek filmski molj.
Gatsu ::
cosmicsuper je izjavil:
HVALA
Imo bo ta Sony za tvoje potrebe in glede na želje po preizkusu 3D zelo dobra izbira.
roCkY ::
Zmanjšaj razdaljo gledanja pa bo še za en čas. Pana plazm še nima smisla menjat za trenutne LED/OLED.
fpbs ::
Ta Sony ima aktivno 3D. To zagotovo ne boš gledal. Poišči nekaj s pasivno 3D.
commissar ::
@commissar
Ne, v navodilih pise da se za HDR posebne nastavitve (verjetno vidne sele ko zacnes predvajati HDR) Iz navodil:
The styles for HDR content are...
• HDR Personal
• HDR Vivid
• HDR Natural
• HDR Standard
• HDR Movie
• HDR Photo
• ISF Day
• ISF Night
• HDR Game
http://download.p4c.philips.com/files/6...
stran 49
Koliko stane pa kje pa bi se dalo dobiti profesionalno kalibracijo?
A ta kalibracija je avtomatska, ali se je treba tudi s temi meniji zajebavat?
A ima taksno kalibriranje vecji nabor nastavitev (torej ce lahko spremenijo nekaj kar jaz ne)?
hvala
andrej69 ::
@commissar
Katero opcijo si imel vklopljeno, ko si shranil sliko kjer se vidi zelena barva.?
commissar ::
@andrej69
imel sem isf night, po navodilih iz tukaj: https://www.avforums.com/video/philips-...
potem sem vceraj probal se po tistem videu, ki si ga ti poslal:
Je bolje, ampak se se vedno vidi zelena po sencah.
http://imgur.com/e2Zuo8N
Sem pa potem naredil se factory reset, ter probal isf night, isf day ter je povsod zelena.
http://imgur.com/lavQN0u
http://imgur.com/V1KBU1I
Ce zelim da se ta prizor vidi normalno, potem moram toliko zbit zeleno in modro da je skoraj vse rdece.
Spreminjal sem tudi perfect contrast in ni bilo spremembe
Gatsu ::
Če si kupil preko spleta potem imaš 14 dni šanso za prekinitev pogodbe brez razloga. Drugače pa pač reklamiraj...
mihco ::
Kje so ti abnormalni padci?
Lahko linkate te akcijske cene oledov?
leiito ::
Zgoraj je nekdo linkal electronic4you, 65" B6 je €2.600 v Celovcu, 55" je pa pri Italijanih €1.650, dostavijo v Slovenia, unboxed pa še enga tazelenga manj.
Daelexus ::
Kupujem 60/65 ks7000 in me zanima katere italijanske spletne trgovine dostavljajo v slo.
Hvala.
Hvala.
Blazz ::
očitno pač slika ni vrhunska pri commissarjevem tvju... vidim pa da še nisi opustil hvalospevanja philipsa v čisto vsakem drugem stavku... na koncu pa se vedno najdejo končni kupci, ki demantirajo philipsovo "kakovost"...
car100 ::
Če se še jaz navežem z konkretnimi slikami stestirano na mojem philipsu 55pus6501 glede commissarjevega primera:
Moje mnenje je,da je velik problem že iz vira vsebine velika kompresija in zato velike izgube na račun kvalitete slike, na mojem tvju so nastavitve v večini original nastavljene mogoče za eno stopnoj več game in pa upscaling in ostale napredne funkcije do konca kar se tiče barv je na originalnih nastavitvah. Druga slika je posneta iz boljšega vira in je razlika zelo opazna večja barvitost in boljši kontrasti (z enakimi nastavitvami tvja). Kr se slike tiče jaz menim da če je vir kvaliteten ga Philips vsekakor odlično pokaže, Vsaj jaz nimam pripomb.
- spremenil: car100 ()
