Forum » Konzole » PS5
PS5
kitl76 ::
Pa še malo, ker na začetku bo težko dobiti. Jaz računam, da bom tole imel nekje marec 2021.
The PS5 will include a disc drive for physical games and 4K Blu-rays.
PS5 discs will have a capacity of 100 GB.
Game installation is mandatory, but the console will allow you to just install a multiplayer campaign, for example, or install the entire game and then delete the single-player portion once you're done.
The controller "doesn't have a name yet," but contains an improved speaker, USB-C connectivity, and a larger-capacity battery.
"There is ray-tracing acceleration in the GPU hardware," says Mark Cerny, lead system architect.
The new UI will allow you to see more details on what you can play at any time, as well as more on what your friends are doing.
Bluepoint Games, the studio behind remakes such as Shadow of the Colossus and Uncharted: The Nathan Drake Collection, is working on a PS5 game that it says is a "big" one.
PS5 backwards compatibility is still being worked on as Sony investigate "complete compatibility"
https://www.gamesradar.com/ps5-backward...
- spremenil: oo7 ()
IvoJan ::
Ne zgleda slabo :)
Kaj vi pravite ?
tezko verjamem da bi sony naredil tako odvratno konzolo
Zato, ker je to vibrator za moške.
Na sredino gre falus nakar imaš play(yourself), stop (playing), fast forward (jerk), reverse (jerk) in eject (cum).
- spremenil: D3m ()
chucki ::
Processor
PlayStation 5 8-Core AMD Ryzen Zen 2 CPU
Xbox Scarlett 1.6GHz AMD Ryzen Zen 2 CPU
Graphics
PlayStation 5 AMD Radeon Navi GPU
Xbox Scarlett AMD Arcturus GPU
RAM
PlayStation 5 unknown
Xbox Scarlett 16GB GDDR6 SDRAM
Storage
PlayStation 5 SSD
Xbox Scarlett 1TB SSD
Optical Drive
PlayStation 5 Yes (4K Blu-ray)
Xbox Scarlett Yes
Max Output Resolution
PlayStation 5 8K
Xbox Scarlett 8K
Max Frame Rate
PlayStation 5 120 fps
Xbox Scarlett 120 fps
Release Date
PlayStation 5 Holiday 2020
Xbox Scarlett Holiday 2020
VR Support
PlayStation 5 Yes
Xbox Scarlett unknown
Graphics
RAM
Storage
PlayStation 5 SSD
Optical Drive
Xbox Scarlett Yes
PlayStation 5 8K
Xbox Scarlett 8K
Max Frame Rate
Release Date
VR Support
PlayStation 5 Yes
filip007 ::
M$ ima denar, tako lahko vloži več v razvoj in še subvencionira konzolo, to se bojim.
Prenosnik, konzola, TV, PC upokojen.
PlayStation 5 May Natively Play Older PlayStation Games; Console Is About The Past And The Future - Rumor
https://wccftech.com/playstation-5-nati...
Kot kaže bo tudi PS6 in PS7 on PS8 in PS9 in PS10 :)
Sony Interactive Entertainment trademarks PS6, PS7, PS8, PS9, and PS10 in JapanSony secures short names for potential future PlayStations.
This sort of trademark security is a regular occurrence for Sony. Here is a history of “PS” trademarks in Japan:
“PS” (trademarked in 2000, released in 1994)
“PS2” (trademarked in 1999, released in 2000)
“PS3” (trademarked in 2005, released in 2006)
“PS4” (trademarked in 2006, released in 2013)
“PS5” (trademarked in 2006, released in 2020)
https://gematsu.com/2019/10/sony-intera...
Reaper ::
Tako ja, pa brisati sejve od starih iger, da si lahko nekaj novega shranil. Ene igre so vzele en blok, ene več in si se potem igral kombinacije :)
Je pa fajn, za PS1 in PS2 so prodajali fake kartice tako bodo tudi tu najbrž, če pride do tega, fake SSD-ji oz. SSD-ji tretjih proizvajalcev, ker original Sony nosilci sigurno premium ceno.
yayo ::
to je Game development kit katerega dobijo razvijatelji iger, da se naučijo delati, oziroma da na njemu delajo in testirajo igre za PS5, le gamepadi na sliki so verjetno taki, kot jih bomo vsi uporabljali.
Ja, pa še brezžično polnjenje kontrolerja bi lahko omogočal na ohišju.
yayo ::
Reaper ::
Jaz se ne obremenjujem z izgledom, samo da bo notranjost zmogljiva pa je lahko takšen kot je development kit :)
The PlayStation 5 should have a lifecycle of six to seven years and include a PS4 Pro-like upgrade in the middle, according to Sony exec Masayasu Ito.
Se pravi naj bi bila tudi PRO verzija ćez 3-4 leta.
filip007 ::
Pa Gran Turismo 7, 20. november.
Sploh raje počakati malo, da se stvari umirijo vse skupaj, ne bom stal v vrsti.
- spremenil: filip007 ()
Kayzon ::
A ljudje dejansko verjamejo da bo v konzoli za 500€ graficna zmogljivosti 2800TI,ki kosta 1500€
springfield ::
A ljudje dejansko verjamejo da bo v konzoli za 500€ graficna zmogljivosti 2800TI,ki kosta 1500€![]()
Ti dejansko verjames, da nVidio stane izdelava te graficne 1000€? Sony je na zacetku za vsak prodan PS4 placal AMDju $100 in je bil AMD v profitu. Velikem. Prodalo se je ze vec kot 100m konzol. Poleg tega je ta performance misljen za Xbox, ki pa vsi dvomijo, da bo 500€. In se 2080 Ti bo stara 2 leti, ko pride nova generacija konzol - procesi so se najbrz kaj pocenili v tem casu.
Bomo videli, ko prideta konzoli ven, a je ta performance povsem dosegljiv.
Govori se, da naj bi imel Ps5 backward compatibility za PS1, PS2, PS3, in PS4.
PlayStation 5 backward compatibility will reportedly work with all generations
https://www.digitaltrends.com/gaming/pl...
filip007 ::
To me ne zanima toliko, treba je gledati naprej, seveda zbiratelji iger bodo hoteli svoje.
PH03N1X ::
Ima konkurenca v tej generacijo bck. cmp. samo kaj ko so x let stare igre (ne vse) precenjene, ranga 20€-30€. Isto bo za PS5, sicer pa me čudi, da je to taka boom novica ker imam PS2 igro na PS4
