Forum » Konzole » PS5
PS5
PS5 release targets late 2018 with most powerful console GPU, says analyst
Analyst believes the PS5 release will be in 2018, and is making some bold predictions about its GPU, which will be more powerful than any other console on the market.
Sony will launch the PlayStation 5 in late 2018, according to Damian Thong, an analyst with Macquarie Research.
According to Thong’s report, not only will the PS5 release date target a 2018 window, but it will be far more powerful than anything else on the market, including the Xbox Scorpio, boasting a 10 TFLOP GPU.
Thong isn’t the only analyst to chime in on the possibility of the PS5. Just a few weeks back, Wedbush Morgan’s Michael Pachter predicted that Sony will launch its next-generation home console in 2020, around the same time that 4K TV adoption will rise significantly. However, Pachter’s release window seems far more realistic at this point; 2018 is far too premature, particularly as PS4 Pro has only just hit stores.
http://www.psu.com/news/32403/ps5-relea...
Jaz tudi mislim, da bo PS5 izšel leta 2020. Konec 2018 se mi zdi malo prehitro kaj pravite :) ?
L1nK ::
odvisno od tega, kako se bo odrezal xbox scorpio, na podlagi tega bodo padale odločitve
https://www.facebook.com/link.zhizhekian
puginho ::
Rekordna prodaja, še polno eksluziv pride, naslednje leto pa že ps5 z 10 tflop, ja hahahahahahaha jaz bi tudi bil analyst
scipascapa ::
Ne verjamem, da bo drugo leto. Prej 2019 ali kasneje. PS4 PRO opravlja svojo nalogo dobro.
Se malo, pa bo treba konzole menjat vsakih nekaj let.
Goblin ::
Močno dvomim, da prej kot 2020. PS4 je izšel leta 2013, tak ni več tak nova zadeva, spet pa ni tako star. Glede na to, da so naredili PS4 PRO in če se bo zadeva obnesla, bi lahko furali zadevo še brez problema v naslednjem desetletju.
http://www.goblin.si
Modri dirkač ::
Pa ne bodo, folk ima 4k HDR TV in hoče najboljši experience.
Če bo scorpio letos bo tudi PS5 kmalu.
Everybody lies!
Gatsu ::
Modri dirkač je izjavil:
No dej en dober razlog zakaj bi lahko Scorpio prisilu Sony v PS5 čez eno leto.
spyker123 ::
Kaj se hecate..ps4 se še ni dobro usedel, že bodo štancali ps5? še malo, pa bodo konzole kot računalniki, da jih boš menjaval na 4 leta..
BivšiUser2 ::
Saj so že, PS4 -> PS4 Pro, isto za Xbox. V tem primeru bi bilo bolje, da ukinejo konzole in nam naj prodajo licenco za OS (mišljeno Sony). Pač se naj nadaljuje po filozofiji ki jo ima SteamOS.
SloTech - če nisi z nami, si persona non grata.
YesMan ::
BivšiUser2 je izjavil:
PS4 PRO ni nobena zamenjava. Naprava je preprosto namenjena temu, da lastniki vedno bolj popularnih 4K TV-jev le imajo nek izkoristek. Če imaš 1080p TV, razloga za menjavo skoraj ni. Isto bo za Xbox Scorpio, s tem da bo ta po mojem mnenju še nudil višje FPS-je in ne samo resolucijo.
Upam, da trajanje konzolne generacije ostane enako (cca. 6 let). Upam pa tudi, da bo do od naslednje generacije naprej, delovale igre prejšnje generacije, za kar mislim da je visoka verjetnost, saj bodo najverjetneje naprej grajene na arhitekturi zelo podobni računalniški in s tem tudi na arhitekturi zdajšnjih sistemov PS4 in Xone.
dolenc ::
Glede na to, da se že za ps4 pro niso upal podirat obstoječega sistema in so raje dodal še en isti gpu, da lahko stare stvari lavfajo na polovički, ne na čisto novi zadevi, ni dvakrat za rečt, da ne bo nič iz tega :)
Tud sama implementacija x86 je bolj tko, ni nihče rekel, da je to pc.
Kakšen pa je OS, ki delujeo na PS4? Linux, morda BSD osnova?
Gatsu ::
FreeBSD derivat.
The native operating system of the PlayStation 4 is Orbis OS, which is a fork of FreeBSD version 9.0 which was released on January 12, 2012.[6][7]
- spremenil: Gatsu ()
hvala!
Berserker ::
A je 4K že dejansko tolk razširjen, da so povpraševanja po močnejšem hardwaru? Ker osebno imam občutek da smo komaj dobro začeli s trenutno generacijo in da je 4K še vedno nek eksperiment.
dolenc ::
Dvig resolucije ni eksperiment, je pa folk že z 1080p zadovoljen in vsebina še zmer ni dohitela. Sony bi pa vseen rad kak 4k tv prodal, pa so ustvarli vir vsebine, tko da zdej moreš kupt tv :P
koyotee ::
V vsakem primeru bo izšla v novembru.
Rear DVD collector!
JTD power!
JTD power!
Tole je čisti bullshit. V ps4 pro ni še en gpu zatanknjen, ampak gre kr lepo za polaris osnovo (gcn4 namesto gcn2), ki pa ima res 2x več shader enot. Seveda se ob igranju ps4 iger izklopi polovica shader enot in downclocka na 800Mhz.
Še vedno pa ni to crossfire varjanta dveh 1152SP gpujev, kot so to nekateri sanjal pred izidom
AnWar ::
Ko pride PS5 takoj kupim. ( Zelo zadovoljen z ps4 pro, igram na 1080p / 60 fps ( Ter kupujem samo igre ki delujejo na 60 fps, 30 fps igre preskocim.
Moje mnenje : PS5 2020, prej ne...
[Asus ROG Strix SCAR III]
dolenc ::
Sej nisem reku, da je crossfire(mogoče sem se res mal slabo izrazu), je pa podvojen in tud polni polaris ni, da se ja ne bi kaj podrlo, kar je bilo bistvo izjave.
Lepo bi blo, če bi v naslednji konzoli določil standard 60fps, pol bi mogoče še bla za kupet :)
Konzole so vedno slabša izbira, samo da bodo na 4 leta izhajale, pa bo smeh... že zdaj je zasičeno, pa še kar štancajo, pohlep nima meja... namesto tega naj delajo vrhunske igre.
iloveboobz je izjavil:
sj delajo :)
No ja, od vseh iger ki so na PSu je samo tale Horizon zanimiv.... če odmislim Fifo/NBA vse ostale igre raje igram na vrhunskem PCju, sploh streljačine in RTS...
seveda je polni polaris10. Poglej specse; oba mata 2304SP in oba podpirata GCN4 ISA, tko da ni samo podvojen shader count.
sj delajo :)
Last of Us in pa Uncharted si pa spregledal.
Gatsu ::
sj delajo :)
Kaj se pol sploh sekiraš glede "gnilih" konzol, ko pa imaš VRHUNSKI PC?
AnWar ::
Nioh, automata, pa se in se...tok da kr hop na PC pa srečno mato .
Gatsu ::
Pa dej lepo vas prosim ne linkat tega debila Pachterja. Tip vsakič ko ga o tem vprašajo drugo letnico omenja in nasploh je tako mimo vsekal zadnji dve leti kar se tiče konzol in iger da se folk sam ša norca iz njega dela po forumih.
PS4 Will Probably Reach 100 Million In 2019, PS5 And Next Xbox Tentatively Coming In 2021 - IDC Analyst
https://gamingbolt.com/ps4-will-probabl...
First PlayStation 5 Rumors Point To 8-Core Zen CPU and Navi GPU; Lots of Devkits Already Out
https://wccftech.com/playstation-5-rumo...
Despite New Rumors, PlayStation 5 In 2018 Does Not Make Sense (Though 2019 Does)
https://www.forbes.com/sites/insertcoin...
Mene zanima koliko prej razvijalci iger dobijo nove konzole. Po moje Naughty dog in podobni, ki delajo ekskluzive za Playstation, da že imajo delujoč PS5.
Nekaj se govori, da naj bi PS5 napovedli 2019 in potem naj bi izšel 2020 torej je možno, da je TLOU 2 že PS5 naslov.
dev kiti par let prej, sicer se finese delajo naknadno, tako da tudi devi nevedo 100%, kaksen bo final hw.
dolenc ::
Vem, da je bil primer razvijalcev, ki so naredili Killzone shadowfall in so bili prepričani da bo ps4 imel 4gb rama, tako da ga špil toliko skuri. Potem pa je izšel z 8gb, kljub temu, da je to Sony-financed studio.
Čakajte, zdajšnja generacija konzole (razen Switcha) so stare koliko 4, 5 let? Oziroma niti toliko ne, saj je vmes prišel PS4 Pro in Xbox 1 X ... To bi zmoralo zdržat še nekaj let.
filip007 ::
AMD razvija Navi GPU samo za to, mogoče bodo še uporabili HBM, potem bo lahko konzola že ob štartu pol manjša.
HP prenosnik, Xbox SX in Hisense Qled.
PS - 1994
PS2- 2000
PS3- 2006
PS4- 2013
PS5-???
Če bo PS5 2020 potem je to 6-7 let po PS4.
A na PS4 Pro si pozabil?
Ker takšne variante v preteklosti še sploh ni bilo. Nadgradnje so praviloma bile v Slim različicah konzol, ki pa uradno niso bile hitrejše od izvirnika (samo manjše in energijsko varčnejše, ter seveda cenejše za izdelavo).
