Forum » Programiranje » SMS z Arduinom, Nexmo in Twitter
Oldi ::
Tole sem nakvač¨kal, pa ne gre, na konzoli dobim:
connecting...
disconnecting.
SMSa pa ni, na dashbordu se ne zgodi nič
Eni pravijo, da Nexmo zahteva https, drugi, da to ni res. Prek Chrome s pobrisanim s ne gre.
Probal sem prek Twiterja, a so mi nov račun zablokirali predno sem uspel poslati prvi SMS (avtomatizirani account ni dovoljen). Ali je komu uspelo pretentati Twitter
connecting...
disconnecting.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x43 };
IPAddress ip(192, 168, 1, 43);
EthernetClient client;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Ethernet.begin(mac, ip);
delay(1000);
Serial.println("connecting...");
//Tole je ukaz, ki poslje SMS, seveda s spremenjenimi podatki "https://rest.nexmo.com/sms/json?api_key=Optional[e894]&api_secret=a0e93&from=NEXMO&to=38631234567&text=Welcome+to+Nexmo"
if (client.connect("rest.nexmo.com", 80)) {
client.println("GET /sms/json?api_key=Optional[e894]&api_secret=a0e93&from=NEXMO&to=38631234567&text=Tu+Arduino+kurilnica");
//client.println("GET to=38631234567&text=Tu+Arduino+kurilnica");
client.println("Host: rest.nexmo.com");
client.println("Accept: application/json");
client.println("Connection: close"); //probal sem tudi brez te vrstice
client.println(); //obvezno ena prazna vrstica
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
if (client.connected())
client.stop();
void loop() {
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
while (true);
}Probal sem prek Twiterja, a so mi nov račun zablokirali predno sem uspel poslati prvi SMS (avtomatizirani account ni dovoljen). Ali je komu uspelo pretentati Twitter
Oldi ::
V firefoxu mi ob vnosu http://rest.nexmo.com/sms/json?api_key=...........330&text=Welcome+to+Nexmo najprej javi
Firefox can't find the file at http://rest.nexmo.com/sms/json?api_key=...........330&text=Welcome+to+Nexmo.
Check the file name for capitalization or other typing errors.
Check to see if the file was moved, renamed or deleted.
Nato dodam s in mi sprejme fajl s tole vsebino
"message-count": "1",
"messages": [{
"status": "4",
"error-text": "Bad Credentials"
Sem jih vprašal v support centru in mi odgovorijo:
Thanks for contacting us about this - you need to remove the word Optional in the API key parameter and the parentheses around the API key itself and it should work.
In res, brez Optional in [] dobim SMS tudi brez s-ja
Svašta, zakaj vraga imajo potem ta Optional in [] v curl-ju in zakaj je prvič stvar delala, poslal sem 2 testna SMS-a in ziher nisem brisal Optional ????
"messages": [{
"status": "4",
| » | SIM800L modul in Arduino NanoOddelek: Elektrotehnika in elektronika | 3844 (2657) | domenc |
| » | Kdo se spozna na ESP8266 in Arduino?Oddelek: Pomoč in nasveti | 3475 (3053) | chiiiii |
| » | Arduino(slave) + ESP8266(master) preko I2CjaOddelek: Elektrotehnika in elektronika | 1384 (1237) | teoo |
| » | Arduino in luči (strani: 1 2 )Oddelek: Elektrotehnika in elektronika | 14778 (12404) | FX6300B |
| » | Arduino "leteče luči"Oddelek: Elektrotehnika in elektronika | 3708 (2585) | zrataj4201 |
