Forum » Programska oprema » Program .dxf v g-kodo, brezplačni
japol ::
Kateri brezplačni program omogoča pretvorbo .dxf ali pa kar .dwg v g-kodo? Po možnosti da je možna optimizacija večih kosov za čim boljši izkoristek itd. Kaj vi uporabljate?
japol ::
Hja... mišljeno je bilo, če se je kdo že ukvarjal s tem in ve kateri je najboljši. Ne pa da nameščam in testiram vse po vrsti.
toplakd ::
Poglej si še Autodesk Fusion 360.
Je zastonj za personal use in Startupe z do 100k$ prometa.
Predvidevam da imaš podjetje, glede na tvoje pretekle poste.
Zdaj pogoji uporabe za startup so malo hecno napisani (v bold pisavi)
Startup:If your entitlements have been designated as "Startup, " You may use the service if You are (i) a company generating less than $100,000 (or equivalent in other currency) per year working on a project or product that is not yet commercially available, (ii) an individual working on a project or product that is not yet commercially available and is generating less than $100,000 (or equivalent in other currency) per year, or (iii) an individual using the service on a personal basis that is not for commercial, professional or for-profit use. The term for Your Startup use will commence on the date access is granted and will end on the earlier of (a) one (1) year from the date of access; (b) the date where the company or product or project generates more than $100,000 per year, or (c) the date of notification to You from Autodesk (which may be provided (1) via email to the registered email address or (2) via notice in the administrator site or account of Your site or account, or (3) via any other manner deemed reasonable by Autodesk which involves specific notification to You (including, for example, by in-service notification functionality)).
Zdaj dokler so pogoji uporabe enaki, lahko vsako leto podaljšuješ free use.
Je pa dejstvo da se pogoji uporabe lahko tudi spremenijo in če se, boš
mogoče tudi za "startup use" moral začeti plačevati naročnino.
Program sicer deluje tudi offline, ampak na 14 dni se mora povezati v splet,
za posodobitve ipd.
Jaz zaenkrat ostajam na CamBam plus, katerega sem kupil pred leti za 108EUR in ponuja precej za ta denar.
Pa ne rabim biti z računalnikom online in datoteke so shranjene samo pri meni.
za posodobitve ipd.
- spremenil: toplakd ()
japol ::
Hvala. CamBam, to sem gledal. A ima možnost da zoptimizira več kosov itd.? Lahko objaviš sliko kakšnega takega primera?
- spremenil: japol ()
toplakd ::
Cambam ima osnovni grid nesting, kjer nastavljaš št.stopcev/vrstic in razmik med njimi.
Ti torej narediš MOP za en del, in ga potem multipliciraš na željeno št vrstic/stolpcev.
Za naprednejši multipart nesting, kateri samodejno "razmeče" dele po velikosti materiala se boš moral globje stegnit v denarnico.
| » | Mobilci in programska zaščita zanjeOddelek: Mobilne tehnologije | 5251 (4836) | Chev |
| ! | Javni razpisi iz področja Z&TOddelek: Znanost in tehnologija | 45917 (39926) | gzibret |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20336 (17176) | arrigo |
| » | Half-Life 2 problemOddelek: Igre | 2600 (2350) | Shybby |
