Forum » Programiranje » javascript napaka!
javascript napaka!
kretze ::
zdravo kaj ve kdo kje je napaka v tej kodi??
<!DOCTYPE html>
<head>
<title>charchter 5 example 2 </title>
<script type="text/javascript">
function checkchartype(chatToCheck)
var returnvalue=0;
var charcode=chatToCheck.charCodeAt(0);
if(charcode>="A".charCodeAt(0)&&charcode<="Z".charCodeAt(0))
returnvalue="U";
else if(charcode>="a".charCodeAt(0)&&charcode<="z".charCodeAt(0))
returnvalue="L";
else if(charcode>="0".charCodeAt(0)&&charcode<="9".charCodeAt(0))
returnvalue="N";
</script>
</head>
<body>
var mystring=prompt("eneter some text","2");
switch(checkchartype(mystring))
case "U":
document.write("first charachter was uppercase ");
break;
case "L":
documnet.write("first charachter was lowwer case");
break;
case "N":
document.write("first charachter was a number ");
break;
default:
document.write("first charchter was not a charahcter or a number ");
</script>
</body>
</html>
Timmah ::
charchter --> character
case "L":
documnet --> document
case "L":
donde esta francesca
- spremenil: Timmah ()
kretze ::
ej kaj ve kdo zakaj mi včasih v chromu ko grem pod f12 pa tam pod console ne prikaže nobenih errorjev??
Nublet ::
JercSI ::
Med drugim ti v funkciji checkchartype manjka na koncu return returnvalue;
Ali pa spremeni returnvalue="U"; v return "U"; itd.. na koncu pa dodaš return 0;
| » | [javaScript] Preverjanje formata zapisa EMŠOOddelek: Programiranje | 3474 (3094) | win64 |
| » | [C#] Pravice za spreminjanje in restore bazeOddelek: Programiranje | 1414 (1234) | nuclear |
| » | Pomoč pri Flash MX 2004Oddelek: Programska oprema | 1356 (1248) | Vesoljc |
| » | read integer v javiOddelek: Programiranje | 1740 (1641) | kopernik |
| » | novi java problemiOddelek: Programiranje | 1570 (1430) | StratOS |
