javascript napaka!
javascript napaka!
kretze ::
zdravo kaj ve kdo kje je napaka v tej kodi??
<!DOCTYPE html>
<head>
<title>charchter 5 example 2 </title>
<script type="text/javascript">
function checkchartype(chatToCheck)
	var returnvalue=0;
	var charcode=chatToCheck.charCodeAt(0);
	if(charcode>="A".charCodeAt(0)&&charcode<="Z".charCodeAt(0))
		returnvalue="U";
	else if(charcode>="a".charCodeAt(0)&&charcode<="z".charCodeAt(0))
		returnvalue="L";
	else if(charcode>="0".charCodeAt(0)&&charcode<="9".charCodeAt(0))
		returnvalue="N";
</script>
</head>
<body>
var mystring=prompt("eneter some text","2");
switch(checkchartype(mystring))
	case "U":
	document.write("first charachter was uppercase ");
	break;
	case "L":
	documnet.write("first charachter was lowwer case");
	break;
	case "N":
	document.write("first charachter was a number ");
	break;
	default:
	document.write("first charchter was not a charahcter or a number ");
</script>
</body>
</html>
Timmah ::
charchter --> character
case "L":
documnet --> document
donde esta francesca
  • spremenil: Timmah ()
kretze ::
ej kaj ve kdo zakaj mi včasih v chromu ko grem pod f12 pa tam pod console ne prikaže nobenih errorjev??
Nublet ::
kretze je izjavil:
Poglej da nimaš slučajno filtriranih rezultatov.
JercSI ::
Med drugim ti v funkciji checkchartype manjka na koncu return returnvalue;
Ali pa spremeni returnvalue="U"; v return "U"; itd.. na koncu pa dodaš return 0;
[javaScript] Preverjanje formata zapisa EMŠO
Oddelek: Programiranje
133471 (3091) win64
[C#] Pravice za spreminjanje in restore baze
51413 (1233) nuclear
Pomoč pri Flash MX 2004
Oddelek: Programska oprema
91356 (1248) Vesoljc
read integer v javi
91740 (1641) kopernik
novi java problemi
51570 (1430) StratOS
