Forum » Zvok in slika » prenosni zvocnik
prenosni zvocnik
krefi ::
zivjo
zanima me kater zvocnik mi priporocate nekej do 300 € uporabljal bi se na prostem
Trenutno imam si ogledujem tega https://eshop.petrol.si/sl/petrol/preno...
zanima me ce mi priporocate kaj drugega?
e3 1231v3|asus gtx 970 strix OC edition|2x8gb kingston|
cosair rm650| crucial 500gb|fractal define s
Tomson ::
Če ne potrebuješ 400W in ti ni za nosit naokoli 17kg, je JBL Xtreme z 40W in 2kg bestbuy bluetooth zvočnik v svojem cenovnem rangu ...
- spremenilo: Tomson ()
Naabo ::
Kar se tiče kakovosti zvoka je daleč najboljši v tem cenovnem razredu Audio Pro Addon T3 (ni pa 400w).
Tomson ::
Jup, T3 je res odličen, sicer 25W, "problem" je dobavljivost, v SLO ga namreč ni za dobit in pa za poslušanje zunaj je JBL Xtreme boljša opcija, je glasnejši in ima več "puncha" ...
vir: klik
I would have liked to put it against the Marshall Kilburn, but as I didn't have any at hand I simply took the JBL Xtreme instead. I think the T3 sounds quite a bit better overall with a more natural sound, nicer sweeter treble response and less artificial bass-boost. Although I must confess that for outdoor listening I definitely preferred the more bass heavy tuning of the Xtreme more, but the T3 is no slouch even outdoors, it is just that it needs a bit of higher levels to really rock, as due to the lack of loudness compensation it might appear a little tinny when played outdoors at low levels.
vir: klik
Naabo ::
Pri nas na voljo pri Intek d.o.o.. Za glasno veselico verjetno res ni, sam sem zelo zadovoljen, pa se uporablja tako notri in zunaj. Je pa seveda zvok stvar okusa.
krefi ::
pc tko mi ga bi rabil za feste na prostem pc > za feste tko s kolegi < zto more bit glasen dovolj
SaXsIm ::
Tipo da za primer link PA zvočnik na baterije, vi pa mu predlagate hifi bluetooth zvočnike. Svašta.
Priporočam, da pro audio opreme ne kupuješ na petrolu. Thomann bo recimo pravi naslov za kaj takšnega. Z Alesisom na povezavi imam nekaj izkušenj, je kar kul zadeva.
SaXsIm
Tomson ::
Ja je fino že v štartu napisat kje in predvsem kako, za kakšne namene, za kakšno glasnost se bo zvočnik uporabljal. Eno je zunanja uporaba (kjer je tudi močnejši pa recimo malo odporen bluetooth zvočnik, kot sem ga predlagal čisto ok), drugo pa je zvočnik namenjen večji glasnosti za fešte a ne, kar smo zvedeli en post nazaj ... ;)
razerznak ::
vesoljec nacist fojb
#trump2016
ups https://www.rt.com/usa/339768-us-marines-aircraft-aging/
#trump2016
| » | Kakšen bluetooth zvočnik? (strani: 1 2 3 4 )Oddelek: Zvok in slika | 57934 (15621) | Pithlit |
| » | Kateri bluetooth zvočnikOddelek: Kaj kupiti | 6390 (5947) | mirancar |
| » | Prenosni zvočnikOddelek: Zvok in slika | 10259 (9225) | Gregex |
| » | Jbl go vs Anker soundcoreOddelek: Zvok in slika | 2568 (2275) | radmannsdorf |
| » | Bluetooth zvočnikOddelek: Zvok in slika | 8445 (6548) | exp3rt |
