Forum » Strojna oprema » AMD Vega GPU
AMD Vega GPU
Predator X je izjavil:
Vidš, to mi negre v glavo... zakaj 2 koraka nazaj?
Zelo dober odgovor na ponekod slabši, ponekod boljši performance Vege: optimizacije.
NVIDIA's approach like for many other things seems to be "hold my beer", they implement what will be applicable to most applications and is 100% safe to manage by their compiler and driver, AMD's approach seems to be "how about do it our way".
In the best case scenario you likely to be able to save more bandwidth and possibly a few more cycles with AMD's approach, but as it requires you to use intrinsic shaders so you would need to own it. NVIDIA's approach is primarily designed to reduce bandwidth by caching (the cache is also compressed) and the load on the rasterizer and shaders (if a tile hasn't changed from frame X to frame X+1 or from Pass N to pass N+1 they can effectively load it from cache without any processing), but likely would result in lower best case scenarios, but also fewer no-go's and doesn't require developers to do squat.
Če se bo kak developer odločil, da poudari dobre plati vege, je situacija takšna, da je Vega 56 blizu GTX 1080, Vega 64 pa na pol poti do 1080Ti.
Obvezno se omeni, da G-Sync stane 200$ več.
Predator X ::
jah...
Senitel naj bi delal za zelene, pa vseeno nima reštekta in se "malce posmehuje" na forumih.
Uglavm RX VEGA je "doomed".
Zanimivi rezultati
http://www.3dmark.com/compare/aot/22612...
Zanimivi rezultati
- predlagal izbris: SuperVeloce ()
Brane22 ::
Opensource driverji so baje ok. To je dovoljšna motivacija za nakup. Čakam samo kako slimmed down, po možnost pasivno hlajeno izvedbo. Idealno v apu package.
My thoughts exactly. Mulariji se trga, rudarjem je "meh", ima kup computing powerja in še neizkoriščenih bombončkov,
linux driverji so dozoreli. Overkill za dnevno uporabo, tam bo APU s HBM2 genau taprava stvar.
Za kak GPU computing ali bolj zahteven CAD bi pa kaka ločena kartica prav prišla.
Ni videti da bodo cene norele, škar je še en +.
On a journey of life I chose a psycho path...
Spc ::
Sem ravnokar za test sprobal firestrike GPU score:
Vega 56: 6384 točk (Windows 10 CU)
ASUS Dual nVIDIA GTX 1070: 6593 točk (Windows Server 2016)
6593 pik dobim z tovarniško navito gtx 1070 z najnovejšim driverjem v firestrike normal.
malo navita 1070ka zgleda vseeno prehiti vego 56, kar je zanimivo.
D3m0r4l1z3d ::
Vprašanje zdaj ali bo aib vega56 kaj ocjana, da oc 1070 naseka.
RejZoR ::
To je pa izjemno nizko? Jezst dobim na naviti GTX 980 okoli 6800 pik (Firestrike Extreme). V navadnem Firestriku pa preko 8000.
Spc ::
Ja, sem zamenjal benchmarka, mislil sem TimeSpy in ne firestrike. (preveč dlcjev).
2min 46sekund
- spremenil: Spc ()
D3m0r4l1z3d ::
Grey, kje si zdaj. Napovedoval si 2x boljšo situacijo od zdajšnje. Bo mogoče skozi mesece Vega pridobila na performancu zadosti in izgubila primerno na ceni, da se bodo tvoje napovedi uresničile?
RejZoR ::
Že tko so na meji konkurenčnega, zdej bi pa še višal cene? A jim crowdsourcamo termometre, da si zmerijo vročino, ker jo ziher imajo... Ko si v njihovi situaciji lahko na višanje cene kar pozabiš, če hočeš kaj prodat. Res ne razumem kaj čarajo.
AMD nima nič s tem. Trgovcem zmanjkuje zaloge in višajo cene (tipično za požeruhe, saj vedno počnejo enako).
D3m0r4l1z3d ::
Stock varijant za min. 650eur jim zmanjkuje? Veliko fanboyev tam zunaj.
Cveto ::
AMD ima precej s tem:
http://wccftech.com/amds-rx-vega-64s-49...
http://www.guru3d.com/news-story/radeon...
https://www.techpowerup.com/236177/amds...
AMD je torej sam priznal da so bile launch cene pofejkane. Škoda, Vega56 je zgledala solidno v rangu 400-450 eur, za 500+ pa ni konkurenčna.
Hehe, tole je pa zanimivo.
Ampak, če prodajo po taki ceni je to dobra poteza (jaz jih podpiram).
Že večkrat sem omenil, da AMD ni Karitas.
Še malo drugačni testi "compute performance".
Glavni problem....ni še optimizacij.
https://techgage.com/article/a-look-at-...
D3m0r4l1z3d je izjavil:
Za ta denar dobis ze kaksno poceni GTX 1080 ti, ki je nedvoumno boljsa izbira. Res ne vem kaj majo eni v glavi. EDina mozna razlaga bi bil freesync monitor in zelja, da se prejsnjo investicijo izkoristi. Sam tudi v tem primeru bi raje imel graficno kartico, ki zagotavlja mnogo vec FSP.
- spremenil: D3m ()
Senitel ::
Aha mal linuxa, mal compute, mal profi workstation aplikacij... Skratka gaming na Windowsih bo RX Vega prehitela Titan XP čez ene 10 let.
Fun times continue...
Grey ::
Tale launch je fail na polni črti. V trgovinah pa mongoloidi, ki pogledajo na TFLOPS številke in si rečejo "U FAK! tega ne moremo prodajat za 399EUR. Lej Franci, kolk TFLOPSov ima. Dej, napiš ceno 700EUR. Sam res Tone, to ne more bit tako, kdo bo pol kupo GTX1080Ti, lej kolk jih še mava w skladiš."
nVidie pa zagotovo ne kupim - njihova etika mi ni všeč. Ko se bodo VR očala in oprema dovolj pocenila bom spet bolj aktivno začel gledat za grafikuljo (čim bližje MSRP). Do takrat bo laptop/tablet dovolj.
Shader = Compute ergo računska moč arhitekture je ogromna.
Vse GCN kartice pred Fury si lepo sledijo po TFLOPS performansu v igrah. Kolkor višji TFLOPS tolko več FPS in general. Fury pa ne. Fury/Vega nekaj zablokira, čeprav je GCN. Sem šel gledat arhivske teste od pamtiveka naprej. In malo pred pojavom DX10/DX11 je bilo še normalno. R9 290 je takrat prednjačila pred GTX780 Ti (si moreš mislit...ista generacija grafičnih). Potem je začel performans GCNa strmoglavljat (pojav GameWorks). AMD lahko zmeče noter 10.000 Stream Procesorjev in navije čip na 5 GHZ pa jih bo nVidia prehitela z 2 GHz in 4096 CUDA Cores. Tukaj je vmes nek funny business.
Ali so falili z driverji na polno pri Fury/Vega ali pa je krivo dolgoletno masiranje developerjev s strani TWIMTBP (in sedaj GameWorks), ki umetno limitira kartice zaradi ali dobesedno hardcodanih limiterjev ali pa načina programiranja, ki ustvarja dodatne latence v GCN arhitekturi. Lahko pa all of the above.
Pojavlja se recimo konstanta 0.7-0.8 TFLOPS vs TFLOPS od cca leta 2010 ne glede na API uporabljen v nVidia sponzoriranih igrah (za toliko so prej vodile AMD kartice v povprečju v non-TWIMTBP igrah cca 30%). Če greš gledat neodvisne igre danes, je precej več možnosti, da bo res TFLOPS vs TFLOPS držal. HD5870/5890 in kasneje HD7xxx serija so bile dolgo časa nedotakljive za nVidio GTX480/GTX580 (obe je nVidia izdala istega leta), GTX680 in GTX780 so bile za AMDjem v igrah (razen za v to posebej sprogramiranih TWIMTBP igrah).
Maxwell (GTX 9xx) serija je bila za nVidio prelomna. Takrat se je Jensen verjetno razpi*dil in precej bolj začeli delat na indoktrinaciji tržišča (isto leto se je pojavil GameWorks). In to je bil Ctrl+Alt+Del za AMD. Če imaš BlackBox stvar do katere konkurenca nima dostopa niti ne more optimizirati za to (da bi ugotovili zakaj tako bremza njihov performans), potem si zmagal ne glede na to kak hardver imaš ti in kakšnega konkurenca.
Hardversko nVidia ni bila zmožna tekmovat z AMDjem, zato so očitno šli na software route, ki je veliko bolj bistven za bottom line. Hardver je lahko dober, ampak če ga softver ni zmožen optimalno uporabljat je brez vrednosti, kup silicija. Jensen je evil. Tudi ta headline iz leta 2009 (ko se je bila bitka med GTXi in od HD5xxx naprej)...Without TWIMTBP, PC gaming would be dead. Precej ironičen stavek in bi bolj bil pravilen v smislu Without TWIMTBP, nVidia would be dead., ker jih je z vsako serijo AMD nadmudril za 20-50%.
RX Vega je za podjetje, ki deluje z neprimerljivo manjšim budgetom v primerjavi z obema konkurentoma odličen dosežek. Ampak se pa vidi, da so hoteli preveč naenkrat zagrist, ker nekatere stvari še vedno niso aktivirane v driverjih.
AntiAliasing jim dela težave (Dirt 4 je ena redkih iger, kjer Vega 56 doseže TFLOPS vs TFLOPS, 90% GTX1080Ti tako kot mora biti in ta je non-nVidia igra in pazi to, DX11 igra - overhead much, not at all?), Primitive Shader Discarding ni enablan, DSBR je tudi šele "Beta varianta" v driverjih...RX Vega Release driver je rushed zadeva. Do Božiča verjetno bo že. Toliko časa so rabili tudi za Ryzen, da so ga do konca spolirali.
Kdor ne more čakat, naj kupi kar želi. TFLOPS vs TFLOPS je Vega56 @ 90% GTX1080Ti in performans, ki je dokazano praktično dosegljiv in za 399EUR je to odličen nakup, hell še za 450EUR je dober nakup. S tem rezultatom sem pomirjen zato, ker je to ponoven dokaz, da se kartice lahko primerja po TFLOPS (in kadar ne drži je razlog neoptimalno programiranje). Računska moč je računska moč (tudi v mGPU ali MCM). Na slabše rezultate v DX11/GameWorks igrah se pa sploh oziral ne bom, ker so to precej pristranski rezultati (in stari) in razumljivo, da tam dosti slabše delujejo AMD kartice. Le poglejte GameWorks skropucalo Agents of Mayhem.
Odštevam do Infinity Vega Nano - 20 TFLOPS, 300W TDP.
- spremenilo: Grey ()
RejZoR ::
O tem da AMD ni Karitas smo govorili, ko je folk fantaziral o GTX 1080Ti performansu za 400€. Da pa prodajaš GTX 1080 performance po GTX 1080Ti cenah pa je čisti absurd.
Vedno rad podpiram underdog firme (npr primer Ryzen je en tak kjer je produkt res super), ampak tole je pa čisto nategovanje. Kdor podpira to je neumen. Izdelek (RX Vega) sicer ni čista katastrofa, zadeva ima nekaj potenciala in performance je tam ko jo postaviš ob bok GTX 1080. Ampak če naviješ ceno, potem jo postavljaš ob bok GTX 1080Ti, kjer pa načeloma povsem popuši razen če gre za špil, ki na veliko favorizira AMD.
Fun times continue...![]()
"Magic driverjev ni" je tvoje prepričanje?
Evo, zdaj ko je AMD mrtef, Nvidia Volta gaming GPUs are not in the 'foreseeable future'
Če bi AMD zagrozil, bi mogoče ugledali Volto že Q1 2018, zdaj pa se lahko samo obrišemo pod nosom. Če bo late Q2 2018, smo lahko še kako veseli. Zna bit kar Q3.
Da o cenah sploh ne govorimo. AMD ni premaknil letvice navzdol niti za milimeter.
Skratka, pripravite se...
Zato se lahko zahvalitmo tudi debilkotom, ki ne bodo kupili in podprli konkurence, tudi, ko je prava izbira. Oz. tistim, ki imajo izjave tipa, ne bom kupil AMD, pa nej izda karkoli.
MaliJanez ::
Torej smo po tvojem vsi debilkoti, ki nočemo nič od AMD, ker je šrot? Ne vidim nič prave izbire, grafična istih zmogljivosti, kot sem že mel 1 leto nazaj, za ceno najmočnejše, ki sem jo kupil 2 tedna nazaj..lol
Predator X ::
"debilko kot si ti" tako razmišlja, poglej kaj se je zgodilo intelu.#Glue technologies
Ja, sej mogoče boljše, da vsa že tako omejena sredstva vložijo v cpu-je, gpu market pa opustijo, saj tako ali tako vedno bolj spominja na zeleni monopol. Pri cpu-jih je napredek počasnejši in vsaj lahko konkurirajo za silo.
Ko v retrospektivi pomisliš na tale teaser trailer izpred osmih mesecev:
Največji hype ever. Na koncu pa ...
Predator X ::
Kako zeleni monopol? Pa kaj ti nabijaš?
Ja tale trailer in sama vega. Dobr res je v gamingu slabša, ampak za kaj drugega pa prinaša veliko veliko novosti.
MaliJanez ::
Nvidia je dosti boljša in prevladuje na tržišču, to je mislo.
Kaj ti ni jasno?
To sem že par postov višje podal FFS.
Vega je občutljiva na AA.
- spremenil: D3m ()
Torej smo po tvojem vsi debilkoti, ki nočemo nič od AMD, ker je šrot? Ne vidim nič prave izbire, grafična istih zmogljivosti, kot sem že mel 1 leto nazaj, za ceno najmočnejše, ki sem jo kupil 2 tedna nazaj..lol![]()
Ce si nepismen, ti ne morem pomagati. Lahko pa pocasi preberes, mogoce bos dojel.
Predator X ::
Kaj ti ni jasno?
Ni mi jasn zakaj so potem 4K benchmarki slabi. Sej za 4K se ne uporablja AA... ali pač?
- spremenilo: Predator X ()
Cveto ::
V testih se. Če se testira najhujše možne nastavitve, je treba dati tudi AA do konca. Koliko je to realno ali potrebno je pa druga stvar.
RejZoR ::
Opustili GPU? Halo? Ravno v tem je težek biznis dandanes. Compute clustri so kjer se obračajo enormni denarji, torej AMD Instinct kartice za serverje. Roko na srce, Vega čip je bil delan za tisto in tam pa dejansko štejejo samo Teraflopsi in nič drugega. Tam ni texture in shaderji pa DX11 in Vulkan. Tam je sam surov compute. Težava Vege je najbolj v tem, da so praktično samo oklestili kartico za industrijsko rabo in jo dal consumerjem. NVIDIA se je očitno naučila s Fermijem, AMD upam da z Vego...
SuperVeloce ::
Problem ni samo metati denar v razvoj (kar bi Intel sicer verjetno lahko), prava ekipa in izkušnje veliko pomenijo, nenazadnje pa bi imeli ogromne probleme s patenti, ko bi dejansko želeli razviti vodilno arhitekturo. Tisto, kar je trenutno na CPUjih, pač ni primerno...
Grey ::
https://www.computerbase.de/2017-08/rad...
Some weird stuff going on.
Kako ljubim ta Computerbase Durchfall...oni morajo tak mastn denar fa*at od nVidie, Kristus... Kako je možno, da je sedaj Fury X toliko pod GTX1070 v Doom Vulkan? Praktično ekvivalenten z RX480/580? Še piše ne na ranglisti, kater mode so uporabili. Tu na tem linku, ki si ga dal, se pa ujema s tem Grafikkarten-Jensenliste....
dolenc ::
Jaz priznam da me vega ne zanima, tko da ne jemljem tko osebo kot nekateri tukej
Me pa pri AMDju precej moti, da njihove zadnje zadeve pridejo nekaj na pol pripravljene(šalabajzaste).
Pri nvidiji sicer nekaj malega lahko še sam naviješ, načeloma pa se grafična že sama zboosta dovolj, več al manj si tam-tam kar bo dalo od sebe. Overvoltat/undervoltat se ne splača. Mogoče edin rame navit.
Pri amdju, ko pride zadeva ven, je vse v razsulu. Pri polarisu je bilo tako stanje, zdej pri vegi spet. Driverji v pre-beta. Voltaže bistveno previsoke, že sam če to znižaš zraste 5-10% zmogljivost, ker potem celo dosega svoje clocke.
Potem timingi na ramih, kako lahko nek nadebudni naključni uporabnik spleta, nastavi bolj optimalne timinge, kot jebeni amd, ki delajo na precej velikem vzorcu pri 2100mhz (original 2000mhz), amdju pa tega ne uspe in pade še tistih 5-10%. In ja razumem, da se vzame fora, ker vsi čipi niso enaki, sam če vsem deluje ... (in pri rx580 seriji so vsaj voltažo v nulo zadel za vsako kartico, tko da očitno se da)
Če pogledaš vego 56, s katero se je poigral gamer nexus, 15-20% hitrejša kartica, pri isti ali podobni porabi kot pride serijsko, s tem da pol orodij še ne deluje.
Sej pol ko se poigraš z zadevo, ki je bistveno boljša od tega kar ti je amd and co poslal. Ampak mene noben ne vpraša kolk šiba, grafe pa vsi pogledajo ob izzidu, ne štekam kako si neka velka firma lahko kej tazga prvošč.
Ne vem zakaj se tako na veliko navija Pascale? Vsi so navduseni nad tem kako lepo se navijejo. TO se ne skalda s tvojimi besedami.
D3m0r4l1z3d ::
Ubožci, toliko so jo morali našponat, da je konkurenčna z 1080, da gre OC Dream spet skozi okno.
Saj veš, free performance.
- spremenilo: D3m0r4l1z3d ()
JSt ta del ze razumem, sam pisec posta pred mojim pa sanja, da so NVIDIA grafe ze out of the box na max.
Definitinvo pa ni vec tolk hudo, k vcasih, si lahko proc tud za 50% navil in je delal bp.
Tega ni.
