Problem v windows 8.1
lukalukov ::
Pozdravljeni!
Računalnik bo rad nagradil na Win10 vendar mi piše da Win8.1 ni aktiviran, kadar ga želim aktivirat mi javi napako 0xC004F074. Na http://atechjourney.com/how-to-fix-acti... je edina rešitev, ki ne zahteve CD-Key-a ,da v terminalu napišem ukaz sfc/scannow. Ko konča mi izpiše to:
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
Kako naj to popravim?
solatko ::
Pirata moraš znat zrihtat
Delo krepa človeka
Po kloniranju sistema sfc javlja "Windows Resource Protection found corrupt files but
Oddelek: Operacijski sistemi
61120 (932) k4vz0024
Win 7 - rabim prostor na SSD
142411 (2196) Cveto
[Win 7 in tudi 10] CPU 100% vendar različni procesi
132403 (2063) solatko
Sfc javi napako - kako jo odpraviti?
101196 (1073) k4vz0024
Izšel prvi servisni paket za Windows 7 (strani: 1 2 )
7731977 (28230) jest10
