Novice » Procesorji » Bristol Ridge in Stoney Ridge sta tu
iloveboobz je izjavil:
sj stoney ne podpira več kot enga kanala
What??
LINK!!!!
The baseline platform will be Stoney Ridge, featuring one Excavator module for two threads and support for up to DDR4-2133 in single channel operation.
http://www.anandtech.com/show/10362/amd...
here's an idea... Kaj bo bi amd spakiral stoney ridge za AM1 socket ? Da bodo ti dobil še vsaj kak upgrejd :)
http://www.notebookcheck.net/Bristol-Ri...
So sad
On average, Bristol Ridge places itself ahead of Carrizo and the HD Graphics 520 IGP by 10 to 15%.
or example, in "Diablo III", the CPU and GPU clock speeds start at 1800 and 550 MHz respectively. As the game runs, the speeds drop to 1100 to 1200 (CPU) and 380 to 420 MHz (GPU).
So sad
pač tole je ena velika žalost. ajde če bi stvar stala max 400e pa da bi mel noter 35W verzijo...
Saj verjetno bo 400EUR brez Win seveda odvisno od zahteve.
Lep spec.
AMD A10-9600P
2x 4 GB DDR4-1866
Radeon R5 (integrated) + Radeon R7 M440 (dedicated), Driver 16.101.1311.1001
256 GB SSD (SanDisk Z400s, M.2 2280)
15.6 inch Full HD Display (1920 x 1080 pixels), TN Panel, matte
Windows 10 64-Bit
Lep spec.
AMD A10-9600P
2x 4 GB DDR4-1866
Windows 10 64-Bit
- spremenil: D3m ()
kurc pa taki specsi, če so v praksi porazni...
9730P+1080P+120GB SSD+fhd za cca 400e bi bil kr solid deal.
Tole za 600e si pa lahk nekam zataknejo.
recimo tole za 470e pihne ta hp grdo v performancih
http://geizhals.eu/asus-k555ub-xo227d-s...
ma pa res šakrt ekran in sam hdd.
- spremenil: iloveboobz ()
Jaz bi odstranil R7 M440, Win10. SSD bi pa zamenjal z cenejšim in smo pod 400€ brez problema.
to govorim jst že skos, pa se nič ne premika. Sj ne da amd apu laptop obstajajo že since forever.
http://geizhals.eu/acer-aspire-e5-553-t...
evo much better.
WIN10 delete
1tb switch za 120g ssd
9730P namest 9600 turda...
evo much better.
WIN10 delete
Opa, dobra cena.
Kaj bi AMD lahko delal hude konkurence pri 300-400€.
Wow.
Se vidi, da je že veliko SoC, da veliko kondijev niti ne rabijo.
- spremenil: D3m ()
A12-9800 je TDP 65W napram TDP 95W Godaveri
Kako je pa glede SW gonilnikov in programi, ki verjetno še ne podpirajo sistema, ker nekateri scori so čudni?
Vidim naj bi uporabili ASUS A320M-C, ki pa ne obstaja na Asus strani?
- spremenil: D3m ()
to se očitno ne odraža na dejanski porabi.
Kako je pa glede SW gonilnikov in programi, ki verjetbno še ne podpirajo sistema, ker nekateri scori so čudni?
izgovori..
oem..
Zakaj izgovori?
Zbiriši vse gonilnike in delaj samo z generičnimi.
Kaj se je pa potlej tukaj zgodilo?
http://www.guru3d.com/news-story/socket...
če v dobrem letu niso mogl skup našvasat enih driverjov, potem je to svojevrstna sramota..
Nekaj bremza A12-9800 v tem testu napram Guru3D.
Kakšna je možnost, da je power funkcija ponesreči vklopljena?
PredatorX ::
Kje je pa summit ridge tema?
nekaj novic na wccftech - SR (SummitRidge) SR3, SR5, SR7 Pod 200$ sploh nebi bil.
Bo kdo ustvaril temo za summit?
Sej maš zen temo
PredatorX ::
Sej maš zen temo
Zen je jedro
- mene zanima samo desktop AM4.
Daj ti naredi, ker imaš že izkušnje pri RX temi.
Sem ustvaril, heh zdej pa nevem ali bi ga ubavil ali ne... bomo počakal do poletja. ZEN+ zna bit tud kull zadeva na temle ivyju bom pa že preživel.
- spremenilo: PredatorX ()
| » | Ryzen bo za štiri leta (strani: 1 2 3 )Oddelek: Novice / Procesorji | 39646 (34783) | FireSnake |
| » | Summit Ridge (AM4, ZEN core)Oddelek: Strojna oprema | 3731 (2785) | D3m |
| » | Bristol Ridge in Stoney Ridge sta tu (strani: 1 2 3 )Oddelek: Novice / Procesorji | 24643 (20559) | D3m |
| » | CES: AMD-jevi procesorji Zen z enotnim podnožjem AM4 (strani: 1 2 )Oddelek: Novice / Procesorji | 23146 (18934) | D3m |
