Forum » Omrežja in internet » Težave - internet
Težave - internet
megy ::
Na laptopu mi na eni lokaciji ne dela internet - ne wifi, ne preko kabla. Do danes je delovala OK. Tam internet na drugih napravah dela (wifi na telefonu, tablici).
Doma mi dela vse normalno in ok.
Sem brez idej, kaj bi lahko bil razlog za to.... pomoč.... hvala
megy ::
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\admin>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : admin-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : 00-24-D7-11-85-B5
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel(R) 82577LM Gigabit Network Connecti
on
Physical Address. . . . . . . . . : D8-D3-85-25-90-86
DHCP Enabled. . . . . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
Physical Address. . . . . . . . . : 00-24-D7-11-85-B4
Link-local IPv6 Address . . . . . : fe80::dd83:82ef:e6e7:fbff%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.99(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 1. januar 1980 0:01:11
Lease Expires . . . . . . . . . . : 20. januar 2016 17:39:27
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 301999319
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-70-B3-81-00-24-D7-11-85-B4
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-27-13-C1-AB-95
Tunnel adapter isatap.amis.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.{1E40B8E1-0E64-4323-A908-0D5747356E17}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
C:\Users\admin>
on
C:\Users\admin>
AC_DC ::
Vidim da se uspešno povežeš preko wifi, prenosnik dobi ok ip.
Kaj javi "nslookup" in kaj "ping slo-tech.com" (iz konzole) ?
O kakšni lokaciji je govora ?
- spremenilo: AC_DC ()
megy ::
v pisarni na drugi lokaciji. do sedaj mi je vedno delal preko wifija
dane ni delal več... ni mi jasno zakaj...
doma mi dela vse ok
doma mi dela vse ok
Gapi ::
Če je router na 192.168.1.254 bi moralo delat če pa ni imaš pa nekaj narobe nastavljeno. Router ima ponavadi IP 192.168.xx.1 Kako ti kaže prehod ali gateway na drugih napravah?
No person is rich enough,to buy back his past.
megy ::
C:\Users\admin>nslookup
Default Server: dsldevice.lan
Address: 192.168.1.254
> ping slo-tech.com
Server: slo-tech.com
Addresses: 2001:67c:2730:1::2
91.236.1.130
*** slo-tech.com can't find ping: No response from server
sedaj sem doma in tukaj mi dela vse ok....
kaj predlagate da naredim v pisarni, da bo spet delalo?
> ping slo-tech.com
91.236.1.130
- spremenila: megy ()
Gapi ::
Lease Obtained. . . . . . . . . . : 1. januar 1980 0:01:11 Pa nekje je ura narobe...
megy ::
> ping slo-tech.com
91.236.1.130
> ping 192.168.1.254
Server: [192.168.1.254]
*** 192.168.1.254 can't find ping: Non-existent domain
datum je narobe, ker imam zanič baterijo in ko ga ugasnem se mi zresetira datum....
> ping slo-tech.com
91.236.1.130
> ping 192.168.1.254
antireal ::
Poskusi napisati "ping 192.168.1.254" brez tistega nslookup spredaj :)
- spremenilo: antireal ()
megy ::
> ping slo-tech.com
91.236.1.130
> ping 192.168.1.254
C:\Users\admin>ipconfig/release
No operation can be performed on Wireless Network Connection 2 while it has its
media disconnected.
No operation can be performed on Bluetooth Network Connection while it has its m
edia disconnected.
C:\Users\admin>ipconfig/renew
media disconnected.
No operation can be performed on Local Area Connection while it has its media di
sconnected.
edia disconnected.
Tunnel adapter isatap.{501D7B4C-4329-4AA2-8588-C3FD2EF446A8}:
on
Lease Obtained. . . . . . . . . . : 19. januar 2016 18:39:07
Lease Expires . . . . . . . . . . : 20. januar 2016 18:39:07
C:\Users\admin>
> ping slo-tech.com
91.236.1.130
> ping 192.168.1.254
media disconnected.
edia disconnected.
media disconnected.
sconnected.
edia disconnected.
on
C:\Users\admin>
antireal ::
"C:\Users\admin>nslookup" - tega ne vpisovat!!!
in napiši v konzolo samo "ping 192.168.1.254"
megy ::
media disconnected.
edia disconnected.
media disconnected.
sconnected.
edia disconnected.
on
C:\Users\admin>
evo je sedaj ok?
media disconnected.
edia disconnected.
media disconnected.
sconnected.
edia disconnected.
on
C:\Users\admin>
evo je sedaj ok?
megy ::
C:\Users\admin>ping 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.1.254:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 2ms, Average = 1ms
C:\Users\admin>
C:\Users\admin>
Gapi ::
>cmd > run as Administrator > tracert www.slo-tech.com
antireal ::
super..do ruterja pride promet..
zdej pa napis še "ping 91.236.1.130" da pogledaš ali prideš do interneta
megy ::
C:\Users\admin>ping 91.236.1.130
Pinging 91.236.1.130 with 32 bytes of data:
Reply from 91.236.1.130: bytes=32 time=28ms TTL=61
Reply from 91.236.1.130: bytes=32 time=30ms TTL=61
Reply from 91.236.1.130: bytes=32 time=27ms TTL=61
Reply from 91.236.1.130: bytes=32 time=29ms TTL=61
Ping statistics for 91.236.1.130:
Minimum = 27ms, Maximum = 30ms, Average = 28ms
C:\Users\admin>
C:\Users\admin>
AC_DC ::
Na 192.168.1.254 je Thomson GW (modem+router).
Daj prvo nastavi uro pravilno.
Pomoje so dns-ji krivec.
Control Panel\Network and Internet\Network Connections
wiif kartica, properties, tcp ip v4, use the following dns servers:
vpiši 8.8.8.8. in 208.67.222.222.
megy ::
AC DC... nardil kot si napisal --- nastavil dns serverja
p. s. sedaj dostopam od doma (ne od lokacije-pisarne, kjer imam težave).
C:\Users\admin>ping slo-tech.com
Pinging slo-tech.com [91.236.1.130] with 32 bytes of data:
Reply from 91.236.1.130: bytes=32 time=31ms TTL=61
Reply from 91.236.1.130: bytes=32 time=32ms TTL=61
Reply from 91.236.1.130: bytes=32 time=44ms TTL=61
Minimum = 31ms, Maximum = 44ms, Average = 34ms
C:\Users\admin>
C:\Users\admin>
antireal ::
Tole zgleda vse ok.
Težko ti bomo pomagali če si sedaj na lokaciji kjer ti internet deluje. Te korake moraš opraviti na lokaciji kjer ti internet ne deluje in ugotoviš, kje se promet ustavi.
megy ::
ok. bom jutri vse te korake ponovil (hudič je le, ker nimam interneta...)....
mogoče se komu sanja, kaj bi lahko bil razlog
a je možno, da je modem?
ali je kaj z računalnikom?
ko dam na laptopu tipko za vklop wifija mi vklopi bluetooth... (to dela samo v pisarni, doma mi vse dela ok)
antireal ::
Očitno je z računalnikom vse vredu, če doma deluje. Verjetno je problem v routerju ali modemu v pisarni.
megy ::
zdravo, da se navežem ponovno na zgornjo temo.
zadnjič priklopil spet računalnik na lokaciji in je delalo
odpiralo mi je v mozzili, v cromu pa ne
danes ista težava. kot da ne najde wifi-ja, ko pritisnem tipko na laptopu za wifi mi vklopi bluetooth.
do danes pa je vse delalo bp.
kje hu... bi lahko bil problem?
megy ::
Ne dela nic. Javi mi wireless capability is turnd off
Na laptopu imam wifi vkloplen, spodaj desno pa mi ga ne kaže
| » | VMware Player - DNS server zmešanOddelek: Programska oprema | 7025 (6594) | AndrejO |
| » | povezava preko switcha ne dela (siol modem -> switch -> laptop)Oddelek: Pomoč in nasveti | 6250 (5754) | BorutK-73 |
| » | Zaradi mreže se mi tresejo možganiOddelek: Pomoč in nasveti | 3743 (2759) | Cervantes |
| » | Problem z internetomOddelek: Pomoč in nasveti | 3836 (3387) | RuskiSnajper |
| » | Problem router/mordemOddelek: Omrežja in internet | 3216 (2903) | gorenjc |
