Normiran s.p. vprašanja... ?
velikBrokoli ::
Siva cona :)) pa vse imaš jasno pokrito z zakoni, jao eni ste res genijalci..
matic492 ::
Kakšna siva cona, kaj ti sanjaš.
To da te ne ujamejo, ne pomeni da je siva cona.
Siva cona je samo, če narediš to v Bosni ali Kajmanskih otokih, ki te podatke ne bojo posredovali FURSu.
sunsun ::
Daj malo preveri "slovenska" podjetja. 1s googlanja https://www.hiska24.si/blog/novice/ali-...
  • spremenilo: sunsun ()
matic492 ::
Ne vem kaj ma tole veze... govorimo o obdavčitvi, oni pa pišejo nekaj o enostavnosti poslovanja.
Nikjer nisem napisal, da ne smeš odpreti podjetja v Estoniji. Ampak iz davčnega vidika nima smisla, ker boš plačal isti davek na promet, kot če imaš DOO v Sloveniji.
  • spremenilo: matic492 ()
sunsun ::
Seveda ga. Zato šo pa šli v Estonijo odpirat. Daj zbudi se.
matic492 ::
Potem kršijo zakon (morali bi doplačat razliko v Sloveniji).
Evo 1s googlanja:
https://learn.e-resident.gov.ee/hc/en-u...
Corporate tax residency
Estonia has a simple rule which says that a company is a tax resident in Estonia if it is incorporated under Estonian laws. If you have registered your Estonian OÜ, then this means your company is an Estonian tax resident and subject to tax in Estonia.
However, some countries have different rules for deciding if a company is tax resident. It is common that in addition to the place of incorporation, the place of effective management triggers tax residence. f you run your company from a country with such rules, then the company might end up having dual tax residence – this happens when two states believe that the company is tax resident in their jurisdiction and will want to tax the company’s profits.
In case business activities of this company are carried out elsewhere or the company is managed from outside of Estonia, the income received in a foreign state will be taxed in this foreign state and Estonia will ensure avoidance of double taxation. At the Estonian Government website you can find a list of all Conventions for the avoidance of double taxation.
In slovenija ta pravila IMA.
sunsun ::
might
Brezveze se prepucavamo. Itak bo vsak naredil optimizacijo po svoje. Vlada, ki misli, da bo privabila visokotehnološki kader v Slo ga bo pa dejansko izgubila zaradi tega.
matic492 ::
Ja res se brezveze prepucavamo, ker je zakon jasen :)
Kanban ::
sunsun je izjavil:
matic492 je izjavil:
https://www.fu.gov.si/poslovni_dogodki_...
To je siva cona in kolikor vem se na veliko koristi od precej večjih podjetij kot smo mi siromaki. Lahko lepiš zakone tukaj kolikor hočeš.
Večja podjetja si brez problema privoščijo to izpeljati na pravi in povsem legalen način. Odvisno seveda od tega s čim se ukvarjajo, kako poteka poslovanje, koga zaposlujejo etc.
  • spremenilo: Kanban ()
velikBrokoli ::
Zakaj bi potem sploh kdorkoli odpiral podjetje v Sloveniji, če ga pa itak lahko v Estoniji/ na Hrvaškem in plačuješ nižje davke, hkrati pa živiš v Sloveniji?
Eni ste res vrhunski davčni optimizatorji.
alkor ::
Kadar zavezanec rezident Slovenije opravlja posle izven Slovenije, se lahko takšna dejavnost šteje po domači zakonodaji tuje države za poslovno enoto in s tem obdavčljivo v tujini. Pri ugotavljanju dohodkov oziroma dobička takšne stalne poslovne enote za davčne namene gostujoče države se upoštevajo in uporabljajo davčna pravila tuje države in pravila relevantne mednarodne pogodbe o izogibanju dvojnega obdavčevanja, kadar je ta sklenjena.
Kaj to pomeni v "davcni praksi"?
Placujes samo tam kjer je podjetje?
LP, a
matic492 ::
To samo pomeni da nisi dvojno obdavčen... Če plačaš v Estoniji 20%, ne boš plačal še 22% v Sloveniji, ampak samo 2%.
Pa a nismo šli to že skozi ene 4x?
Dejstvo je tako v Estoniji se ti splača odpret firmo če boš se preselil v Estonijo... potem boš na boljšem...
Najbrž je razlika med s.p. (kjer bi se moral ti fizično preseliti v tujino) in d.o.o. (ki je pač kot poslovni subjekt odprta v tujini in tudi deluje tam), problem pri slednji lahko nastane, tako kot je že zapisano zgoraj, če je ves menedžment iz Slovenije oz. posluje izključno v Sloveniji.
matic492 ::
Je jasno napisano.. če je poslovodja davčni rezident Slovenije oziroma se "poslovodstvo" nahaja v Sloveniji.
Siva cona, ki jo izkorišča Snežič in podobni je pa, da najdejo bosanca, ki je direktor tvoje firme na papirju in ti se potem zgovarjaš da si samo lastnik, ne pa poslovodja, da ta bosanc dela vse. Ti pa dobiš kartico od firme in hodiš po keš na bankomat, ko ga rabiš.
Pri večjih firmah se da to skrit v legit poslovanje... če imaš pa ti dohodke na nivoju normiranca in prestaviš vse nekam, pa tega ne moreš ravno skrit in se zgovarjat na take zadeve.
Direktor gradbene firme, ki dela 10 miljonov prometa letno, pa lahko ustanovi firmo v bosni in gor nakaže 100 jurjev vsako leto za "poslovno svetovanje", pa se bo izgubilo v ostalih stroških in je večja verjetnost, da se ne bo FURS vpičil v to.
alkor ::
Posluje izkjucno izven Slovenije. Torej v tem primeru je to opcija? (govorim za doo)
LP, a
matic492 ::
Eno je davek na dobiček podjetja drugo pa izplačilo tebi (dividende).
Če bi bil Elon musk slovenc, bi Tesla plačevala normalno davke v ZDA. Izplačilo dobička, bi pa bilo obdavčeno po naših zakonih, ker je on slovenc. Ker Tesla dejansko posluje v ZDA, dobiček podjetja ne bi bil obdavčen po naše (posluje izključno izven slovenije).
Če pa ti odpreš firmo v estoniji, zato da se greš gor one-man band programiranje, pa ne boš nikdar in nikakor dokazal, da posluješ izven slovenije. In boš plačal slovenski davek na dobiček + na izplačila.
alkor ::
Nisem programer in imam dokazila za poslovanje izven slo.
LP, a
matic492 ::
Če živiš v sloveniji več kot 180 dni na leto oziroma "imaš interese" - torej recimo otroke, stanovanje/hišo, ženo itd", si davčni rezident slovenije in se ne boš izognil temu.
Vprašajte štajerce, ki delajo čez mejo v avstrijii, ko dobijo od FURSa pošto, naj doplačajo par jurjev dohodnine...
Kanban ::
alkor je izjavil:
Kje izven slovenije?
Sicer pa je to v bistvu irelevantno. Če si ti (edini poslovodja) davčni rezident Slovenije, bo davčni rezident Slovenije tudi tvoje podjetje, ne glede na to kje si ga odprl. Ker ti vodiš podjetje in delaš poslovne odločitve vedno, ne samo takrat, ko si v tujini.
Če pa si že sedaj več kot pol leta recimo v Nemčiji, pa bi že sedaj Nemčija lahko razmišljala o tem, da si morda pa njihov davčni rezident (ti osebno). In sprožila presojo, kjer se upošteva število dni, ekonomske in družinske vezi etc.
ViperR ::
Zaposliš nekoga iz HR pa se rešiš težave zaradi rezidenstva?
Kanban ::
Kot direktorja. In upaš, da se kdo ne vpiči v to, da je direktor samo na papirju. Pa 20k letno mu daš bruto bruto plačo. Potem pa ugotoviš, da je dražje kot če bi imel še naprej doma normiranca.
matic492 ::
Ali pa vidi kolko maš prometa in se te odloči nategnit in spizdi z dnarjem, ti pa nič ne morš ker je direktor :)
Sej sm že napisal parkrat, nismo dovolj high level da se gremo davčne optimizacije... moraš level up-at še malo v kapitalizmu, da se lahko greš takšne zadeve.
Ja tega se jaz ne bi šel ne :D
ViperR ::
Pa je obvezno, da je direktor? Sej denar lahko verjetno kam preneseš, da nima dostopa?
matic492 ::
Ja, ker ti moraš dokazat da nisi poslovodja, da on vodi podjetje, ti si pa samo lastnik.
Pa te račune smo že delali.. se ne splača, ker si ti obdavčen na izplačilo dobička po slovenskih 25%, pa še stroške imaš s podjetjem na hrvaškem.
Splačalo se ti bi MOGOČE okoli 150k in višje, nikakor pa ne pri manjših cifrah.
Kanban ::
25k za direktorja in stroške, 13k za davek na dobiček, 28k za dividende. In si na istem kot če imaš pri nas legit normiranca.
Pat_MaGroin ::
Za manj kot 200k/letno se ti ne splača selit. Case closed :D.
Če pa ima kdo raje Dalmacijo kot Šenčur, je pa selitev no-brainer :D.
Fora bosne je v tem, da slovenski furs ne ve nič o tem kolk dobička imaš in ali si si ga izplačal. Kar se tiče bosne, si njihov rezident, dol imaš začasno prebivališče, dol greš na banko in dvigneš. Kaj ima furs s tem? Dokler ne ve za to...
Bosanski furs se pa ne bo ukvarjal s tem ali ti res dol živiš ali ne, oni vzamejo svoj davek, in vse kar plačaš je za njih čisti plus, ker če bi imel firmo v Sloveniji, ne bi plačal njim nič. Tako pa plačaš nek sicer nizek davek, bosansko računovodstvo, itd. Nekaj je.
ViperR ::
Kanban je izjavil:
A se ne morš dogovorit z direktorjem, da si dazdelita keš? Zakaj tako visok strošek, plačaš minimalca?
Dividend nimaš po 2 letih?
matic492 ::
Utk je izjavil:
Ja sej pravim, ker oni še niso v EU nimajo avtomatskega poročanja pa teh zadev, zato jih Snežič & company izkoriščajo.
Moraš pa tudi računat, da te bojo potem stranke spraševale zakaj si jim izdal račun iz bosne in zakaj morajo nakazovat v bosno.
Si pa vseeno 100% v prekršku, samo v primeru ko ni avtomatskih poročanj in sodelovanja med državami je velika verjetnost da te bo FURS pustil na miru, ker ni računice da te lovijo sploh.
edit: Ima pa tudi bosna aplikacijo za pridružitev EU.. tako da ne bo več dolgo to.
Avtomatskega poročanja res ni, kaj pa če te kdo prijavi in izvedejo nadzor. Če dajo poizvedbo samo zate, bi jim bosanci dali podatke?
matic492 ::
V to se jaz nisem spuščal, tako da nimam pojma, bi pa sigurno našli nekaj, za kar ti lahko napišejo kazen.
Npr.: razloži zakaj nimaš prijavljenih v sloveniji, pa se voziš v novi bemfli in imaš stanovanje. Če ne moreš (oz. nočeš) dokazati izvora premoženja je obdavčeno 70%.
amacar ::
70% obdavcitev vec ne obstaja, je po dohodninski lestvici.
ViperR ::
Meni se zdi da mal preveč komplicirate. Pa se prijaviš kot davčni rezident na HR in maš tam stalno prebivališče pa je. Kakor da bo kdo vedu kje ti dejansko si. Jaz še svojih sosedov 3x na leto ne vidim, kaj šele da bi furs vedu. Plačevanje pa itak vse kartično oz kak kripto kartica pa si neizsledljiv.
matic492 ::
Otrok pa prijavljen v vrtec v Sloveniji ne "Ja veste ga vozim iz Međimurja v Maribor vsak dan"
velikBrokoli ::
ViperR je izjavil:
Valda, tko simple je.
Najprej rabiš na Hrvaškem najeti/kupiti nepremičnino, kar je seveda zastonj, ane?
Potem v Sloveniji ne smeš imeti ekonomskih vezi (šola, vrtec, partner, služba partnerja, familija, ne smeš imeti stalnega prebivališča in še in še), da odjaviš davčno rezidenstvo.
Pa hkrati pozabljate, da je breme dokazovanja na vas, FURS vam bom upalil kazen, vi boste pa potem z odvetnikom dokazovali, da ste živeli na Hrvaškem.
Sliši se zelo preprosto.
Pa kar ni nepomembno, tudi k zdravniku moraš potem na hrvaškem.
velikBrokoli ::
Saj to pa itak veliko Slovencev počne, ker je naše zdravstvo v razsulu :))
K zobarju že, ne vem pa kako je z bolnišničnim zdravljenjem. Upam, da smo tu še vedno pred njimi. Res pa glede odhodov kirurgov vprašanje.
Kot da ne bi imeli (neporočenih) mater "samohranilk":))
  • spremenil: Gregor P ()
matic492 ::
Jah tam je malo bolj kompleksno dokazovanje, pa tudi koliko sploh profitirajo, par sto evrov na leto mogoče.
eEdbM ::
Pa vi, ki se imate resen namen selit v Dalmacijo (verjetno juzno), bi vse nepremicnine prav prodali ali 'razporedili' v zaupanja vrednem sorodstvu - recimo polnoletnim otrokom, ki se se solajo, kot nekaksno predcasno dediscino - s katero gospodarijo po obcasnih priporocilih?
  • spremenilo: eEdbM ()
ViperR ::
velikBrokoli je izjavil:
ViperR je izjavil:
A nimajo slovenci dol vikendov kokr hočeš. Si pač daš stalni naslov tam. Familjo ma čist usak tuki, kaj rabiš tle dokazovat? Zdravstvo pač plačaš neko evropsko zavarovanje. Za vikend se odpelješ dol, skočiš v morje, greš v trgovino in tankaš in imaš za dokazovanje. Verjetno tud ne rabis vsako leto dokazovat, ko gre enkrat čez.
eEdbM je izjavil:
Zakaj ne bi smel imeti nepremičnin v "tujini"?
eEdbM ::
delavec44 je izjavil:
Vprasam pac, da sem "in" :)
mm&r ::
Sem nekje zasledil, da si je Dončič kupil stanovanje v Schellenburgu, a torej pomeni, da je davčni rezident RS in , da potem čez njegove zaslužke upali najprej IRS in potem še Durs naše davke?
matic492 ::
Zdaj se delate butaste, stvar pač ni definirana z samo eno stvarjo, kot je lastništvo nepremičnine, ampak je dokazovanje tvoja stvar... na odločitev vpliva ogromno faktorjev.
Dejstvo pa je, da če si lastnik nepremičnine v Sloveniji, in trdiš da je prazno oziroma prideš 3x na leto tja živet, boš moral to dokazovat, in razen če si se zaprl v stanovanje, bodo hitro našli sosede, ki so te vidli.
devdems ::
Boštjančič, kaj pa vi tukaj?
Pa dejansko furs to hodi okrog sprasevat... Se nisem videl primera
193 / 351
