Htc One M7... Pomoč
Htc One M7... Pomoč
Beki89 ::
Pri htc m7 se pojavila napaka resetiranja. Telefons se ne zaćene normalno več
Torej zazene in pokaže HTC Logo , zavibrira in se ugasne in se potem ponavlja znova in znova dokler se ne izprazni baterija...
Prosim za pomoč
Telefon ni več v garanciji..
shadeX ::
Se je to pojavilo samo od sebe ali si kaj delal sam, da se je to začelo dogajati?
Beki89 ::
Je od sestre, Sigurno nic ni delala
AC_DC ::
Tako ?
Beri komentarje spodaj:
Quang La Ha 2 months ago
this is the fix for this problem. To solve this, I think the best way is to return the phone to its stock (factory state). open HTC website to look for the stock ROM of your phone, and download the ROM, HTC calls the ROM RUU, and you need to download the *.exe. The link to download ROM is http://www.htc.com/us/support/rom-downl... Be careful to select the exact ROM for your phone. When the phone turns off it self, just press and hold volume down, the phone shall enter recovery mode, just like the beginning of this video. Then press volume down to highlight "FASTBOOT" and press Power button once to enter Fastboot mode. Connect the phone to your computer, using USB cable. Double click the downloaded ROM, and follow instruction. the phone shall be restored to its factory state
ali
Hamood Ehsan 7 months ago
Just get the sim and the sd card out and try again !
http://forum.xda-developers.com/showthr...
  • spremenilo: AC_DC ()
Beki89 ::
Fora je k se resetira non stop in zazna kot napako ko zeli instalirat
Geekbuying garancija
456636 (4988) N0t0ri0us
Počasno polnjenje (Galaxy S5)
Oddelek: Mobilne tehnologije
195551 (5205) gusto
Samsung galaxy note BRICK
204573 (4060) CaqKa
HTC Legend (strani: 1 2 3 4 5 )
20328269 (20098) CaqKa
HTC Tattoo (strani: 1 2 )
5028622 (25985) PeternelG
