Forum » Problemi človeštva » Konflikt v Siriji
Konflikt v Siriji
Matejjjjj ::
matr, ruski imperij se bo zrušil że po 3 letih vojne s prvo sosednjo državo. razkosal si jo bodo sosedi. putin bi pa kar napadal, s kom, s čim? na koncu bo krim turški. Putin je grobar Rusije, ne more nek špijun imeti kapacitete voditi svetovne vojne. če hkrati dobijo zagon vse zatirane sosede in vse manjšine bo rusija izginila. in to se bo zgodilo.
- spremenilo: Matejjjjj ()
RdecTelefon ::
"With the possible exception of the equator, everything begins somewhere."
C. S. Lewis
The combat losses of the enemy from February 24, 2022 to November 30, 2024.
https://x.com/defenceu/status/186274888...
Zdaj, če ti podatki približno držijo..
Kakšne možnosti ima vse Darth Putin:
- vzame asada k sebi v moskvo in tam skupaj prijeta vodka partije(ga pusti na cedilu)
-prašiček kim pošlje uboge svoje ljudi in havbice
-se vključi iran
-se vključijo kinezi(mala verjetnost)
-mobilizacija v moskvi??
-neki skriti adut
Kaj ima osmansko cesarstvo za bregom?
Izrael?
Kokice?!
Kdor poje, zlo ne misli!
- spremenil: RdecTelefon ()
Deradikalizirali?
A je že prvi april ali kako?
Ne vem, zmeni se z OP-om. Samo posredujem, ker sem/smo že par let izven loopa.
https://x.com/MalcontentmentT/status/18...
Will HTS/SNA and the almost 2 dozen groups supporting be benevolent rulers as was ordered by their command? Are they "reformed" as claimed?
Will the coalition that formed against Assad hold and remain cohesive?
Will elements of the SAA turn on Assad and join HTS/SNA?
If the strategic goal is to topple Assad, chopping off heads in the streets of Aleppo will make turning it into a logistics hub for future offensive operations not just difficult but near impossible. Even if HTS/SNA operational goals are broader, they will have to enter a pause to consolidate gains.
HTS has de-raducalized over the last 5+ years (they are still a cause of concern). They created a quasi, effective government. They created their own domestic military-industrial complex designing and building their own IMV, APC, and MRAPs, They trained and created a professional C3 structure. They developed a professional fighting force. By de-radicalizing, they built deeper coalitions. They made a plan. They executed it masterfully.
In contrast to the work of HTS/SNA, Assad hid behind PMC Wagner, the VKS, and little green men from Russia with the ocassional sprinkle of Sarin. His regime focused on corruption, keeping it in the family, and permitted his military and means to support it deteriorate to an ineffective state. To stay in power, he was and is a puppet to Moscow and Tehran.
https://www.rtvslo.si/svet/bliznji-vzho...
Islamistični uporniki naj bi zavzeli večino Alepa. Rusija izvedla zračne napade na mesto.
Gre za največjo ofenzivo proti vladnim silam v več letih
Sirski observatorij za človekove pravice je sporočil, da so uporniki v Siriji zavzeli večino drugega največjega mesta v državi Alep. V ofenzivi, ki so jo sprožili v sredo, naj bi bilo ubitih več kot 300 ljudi, tudi najmanj 27 civilistov.
RdecTelefon ::
Zdaj sem prebral kar nekaj komentarjev na tem linku kaj ga je pripopal mtosev. ZDA, ZDA, ZDA, ZDA, Izrael, ZDA, ZDA, ZDA, Izrael, ZDA, EU. Rusija do Urugvaja!
Ne bi rad bil zdaj nesramen ali pa bilo kaj.. Kaj naredimo Z pokvarjeno ploščo?
Matejjjjj ::
To ni naključje, proxy eskalacije na terenih, kjer Putinovi fašisti ne zmorejo več, tj Afrika, Sirija, mogoče je naslednja faza Libija. Nato spet zakavkazje, Gruzija, C Azija, slejkoprej bodo svoje zahteve postavili Kitajci. Vse ruake sosede v Aziji so močnejše od Rusov, le j.orožje je še nek faktor. Ker ve v kako sranje se je uvalil, rešitev vidi v S.Koreji in Iranu. Kar pa ne bo špilalo dolgo. Komedija pa je, da Putin grozi NATU oz 500.000.000 glavi Evropi s svojimi 140.000.000 Rusi... če bi Ukrajina padla hitro bi bilo časovno okno za vpad v V Evropo večje, zdaj pa je čas za presenečenje minil... ostalo mu bo samo neko trganje kablov in miniranje letalskih pošiljk.
Ja, vidimo na primeru Ukrajine, kako zelo so ruske sosede močnejše od rusov. In če gre Ukrajini tako izjemno dobro ni vrag, da ne bi šlo Gruziji, Kazahstanu in podobnim še neprimerno bolje.
Oh wait...
Oh wait...
- spremenil: Poldi112 ()
Matejjjjj ::
Nemci so vse stavili na blitzkrieg in bliskovito okupirali Francijo, to je dejansko tudi bila njihova edina res pomembna popolna totalna poceni zmaga v 2.sv, ostalo so izpeljali le polovično in posledično vojno izgubili. Putinov idol Hitler se je zafrknil ko je izgubil bitko za Britanijo, nato Stalingrad... Putinu ni uspelo zavzeti Ukrajine z malo žrtvami, posledično se bo iztrošil. Ni važno zmagat, važno je, koliko zmaga stane
A je kakšna možnost, da Assad pade?
Matejjjjj ::
Tudi vojne se ne moreš iti 10 let, američani so imeli 1945 že hude probleme s financiranjem vojne, pregrevanjem ekonomije, urjenjem čet... pa so bili v totalni vojni le od 1942 do 1945, cca 3,5 let
Zakaj bi se iztrošil, če ima 3x več ljudi, delujočo industrijo ter podporo večine sveta, medtem ko ima Ukrajina vsak dan manj industrije, zemlje ter podpore zahoda?
to
https://x.com/Abdurahmanhrk/status/1862...
in to
https://x.com/tobiaschneider/status/186...
Regime forces are evacuating Hama Airport
in to
I spent years helping to build elaborate case files for future war crimes trials against the Assad regime. You wouldn't believe what share center on this damn airbase. Attacks that killed tens of thousands launched from here. Let's pray they didn't bother to burn the paperwork.
Ruske sanje, da njihove kolonjalne sanje podpira večino sveta.
Matejjjjj ::
Itak. Sem bil velikokrat v Istanbulu, Ruski turisti so tam zelo prisotni, drugam v evropo, če to štejemo za evropo, itak ne smejo potovati. Kar naenkrat bo zelo slabo za njihovo moralo če bodo v shopping hodili v državo, ki financira pobijanje njihovih vojakov v soseščini. Putin se je zakalkuliral. Ni prvi
Ta teden je zagorel tudi njihovo skropucalo Suhoj superjet ob pristanku v Turčiji. Flota a320 bo crknila rnkrat naslednje leto, alternative pa nimajo. Pomanjkanjrnletal bo ustavilo njihovo preveliko državo
Seveda ne. Samo večina sveta tudi ne dojema ruskega posredovanja kot kolonializem, za razliko od naprimer zahodne podpore zmernim glavorezcem v Siriji ter kraji sirske nafte s strani ZDA.
https://www.npr.org/2021/05/05/99375439...
But 44% of those surveyed said another threat to democracy worldwide is the influence of the United States. That ranked higher than the influence of China or Russia.
https://nypost.com/2014/01/05/us-is-the...
The United States is the greatest threat to world peace. That's the finding of an end-of-the- year, WIN/Gallup International survey of people in 65 countries.
Of the 66,000 people polled, just under a quarter named Uncle Sam as the greatest threat to world peace.
Other menaces didn't even come close: 8 percent named Pakistan, putting that country in second place, while 6 percent named China. A mere 4 percent found Iran threatening -- which tied it with Israel.
Strel455 ::
RdecTelefon ::
V enem dokumentarcu na national geographic lepo pove zgodovinar, ko so Nemci prodirali v Francijo, da se jim je naredila več 10km kolona tam nekje med bregovi. V glavnem padli so v več dnevni Stau z tanki in vojaki. Seveda je zahod mencal in jih niso tam napadli- z bombniki iz anglije.
Zgodovinar jezno pove, da bi bil potek zgodovine zelo drugačen, ker bi jim tam uničili 3/4 železja in vojakov.
Dejansko samo ponavljaš rusko propagando, sirija je bila večina vojna med igralci na bv, iran, sa, turčija. Tisti plunek nafte boli veina samo rusofile.
delujočo industrijo
Bomo mi to vsi videli, kako je lahko industrija delujoča pri 21% obrastni meri. Aha.
Brez skrbi. Samo potem boste spet našli kak izgovor v smislu, da si Ukrajina izgleda ni dovolj želela demokracije.
Rusi se umikajo iz Hame ravnokar baje.
https://x.com/front_ukrainian/status/18...
Prav tako Asadove sile, video:
https://x.com/NOELreports/status/186289...
Rusi naj bi izgubili tudi enega lovca nad Alepom:
- spremenilo: Malidelničar ()
Ne kolega, tisti pljunek nafte primarno boli prebivalce Sirije.
Kakšna ruska propaganda? Dejstvo je, da se ZDA že desetletje trudi uničiti Sirijo in okupacija njihovih naravnih virov je zgolj en od vzvodov (poleg aktivne podpore muslimanskih skrajnežev).
Dominacija Bližnjega Vzhoda je pač geostrateški cilj USA in širjenje takoimenovane "demokracije" s podporo skrajnežev kolonialci izvajajo že odkar so tam odkrili nafto.
RdecTelefon ::
In vse to kaj je Poldi napisal zgoraj dobite poslano v paketu na črni petek iz RT.ru
Kurdi imajo od nje korist, boli predvsem asada. Dejansko sirijo uničuje asad,če bi pred desetletjem prepustil oblast bi se vsemu temu lahko izognii. Namesto tega je v džavo navlekel šiitske milice iz celega bv. Ne pozabimo, sirija je večinsko sunitska država.
Torej izrabljana lajna zda so krive.
Sicer pa ti ves čas pravi, da je to pravica močnejših držav. Torej ameriška prisotnost tam...
Pravico? Tega nikoli nisem rekel, in ti to veš, pa še kar neprestano goniš to laž.
Aha, tipičnio - kriv je Assad, ki bi moral pustiti, da ZDA nastavijo svojo lutko ter dajo državo v ropanje svojim podjetjem. Medtem ko ZDA, ki okupirajo suvereno državo ter kradejo njene naravne vire, zgolj in samo skrbijo za človekove pravice na drugem koncu sveta?
RdecTelefon ::
Kaj to prav vidim, da drži belo zastavo vojak? Pohvalno!
Proti-Asadova vstaja na jugu Sirije???
Pro-Assad forces forces open fire on protesters in the city of Inkhil
https://syria.liveuamap.com/en/2024/30-...
RdecTelefon ::
Tipični ruski stil Z ostrimi naboji nad protesnike. Že videno na EuroMajdanu.
Strel455 ::
https://x.com/Tendar/status/18629026813...
Reportedly all rebel factions, no matter their colors in the North, have agreed not to fight each other. There are already overlapping control areas like in Kuweires air base and the city of Dayr Hafir east of Aleppo which support that claim.
Apparently, all Syrian rebel factions have agreed that the primary enemy of Syria is Assad, Russia, ISIS and Iran.
Zanimivo.
nejcek74 ::
Putin je v Asada vložil ogromno, in vložka še nikakor ni dobil nazaj. Tako da je tale zadeva precej dober lakmusov papir o dejanskem stanju v Rusiji. Če podpore ne bo, potem je Putin (in njegova vizija Rusije) šibka in že močno blefira v Ukrajini. Če bo, ima še rezerve. Sirska anti-Asad koalicija pa po mojem mnenju nima dovolj skupnih imenovalcev, da bi lahko preživela daljši spopad.
blay44 ::
Tole je delo Američanov. Pod prejšnim mandatom Trumpa so Rusi podprli Asada. Obama je popuščal. Zdajle je pa Trump dal pogoj.
Vidi pa se kaj naredi nesposobno vodenje vojske. Sposobni generali točno vedo, da bodo ostali bez podpore, če ne žrtvovani.Vse za veliko Ime.
Strel455 ::
https://x.com/RALee85/status/1862940450...
Rybar and other Russian channels are saying that the commander of Russian forces in Syria, Lieutenant General Sergei Kisel, has been relieved, possibly by Colonel General Chayko. Russian channels are mostly blaming the Syrian military but some are also directing blame at Kisel, Chayko, and the pattern of sending generals relieved in Ukraine to Syria.
tony1 ::
Ni pa posledica planiranih dveh naftovodov čez Sirijo, za katera se z Asadom niso mogli zmenit?
Strel455 ::
Seveda se tudi za to niso mogli zment, saj je to šlo v nos predvsem Rusom.
- spremenilo: Strel455 ()
sir_mha ::
V bistvu so Turki to spet zvito in učinkovito taktično izvedli akcijo, podobno kot pri vojni med Azerbajdžanom in Armenci. Tokrat je Izrael dotolkel Hezbolah, Rusi so eliminiral samega sebe in Iran je tudi zaposlen z Izraelci (v bistvu je enako naredil samomor iz zasede kot Rusi, ko je spodbudil Hamas v Gazi).
Uporniki so zelo blizu letalski vojaski bazi v Hami in jo ze lahko napadajo z artilerijo in droni.
blay44 ::
Med sabo v Damasku so se počili:
Very violent clashes between the Syrian Republican Guard and the Fourth Division in Damascus are being reported by the opposition media. The clashes are gathered inside the capital, specifically in the Kafr Sousa area
Naj pa bi zdaj bil kvazi to napad na 'sleeper cells' v prestolnici:
4th division now says they are responding to sleeper cells inside of Damascus
Kako to misliš, da ni dobil nazaj vložka? Kaj točno bi po tvojem moral dobiti?
Ustavil je američane pri uničenju Sirije ter s tem ohranil svoje baze v ključni regiji. Nato je pa še razbil s strani NATO trenirane sile v Ukrajini. Dalo bi se reči, da je lastnoročno celotnemu svetu demonstriral nemoč zahoda in s tem vlil upanje državam v razvoju. Sedaj, ko ima na svoji strani še Iran (ter posledično praktično Irak), so pa časi ameriške prevlade na tem ključnem območju šteti dnevi.
Če kaj, je to dober lakmusov papir glede dejanske moči rusije, ter nemoči američanov, ki lahko zgolj bevskajo, ko že leto dni neumorno prodira po Ukrajini in jim meša štrene na Bližnjem Vzhodu.
RIP Pax Americana, long live BRICS. Samo vprašanje časa je, kdaj nas v EU sreča pamet in se tudi sami priključimo dekoloniziranim državam v dejanskem svobodnem svetu.
https://x.com/clashreport/status/186295...
SAA je konsolidirana, ruska avijacija melje koljače. Ki so že podurhali iz Hame.
Grinmiir3 ::
Tako kot so Rusi zavzeli nazaj Kursk?
Strel455 ::
sir_mha ::
Jaz bi se umaknil iz Alepa, če bi bil tam, kar se da daleč.
https://x.com/Megatron_ron/status/18626...
NEW: ?????? Russia says that 'Turkey has violated the Astana and Sochi agreements, and the Syrian Government has the full right to restore security in Aleppo using all types of weaponry and methods, and by any means necessary'
