Forum » Problemi človeštva » Konflikt v Siriji
Konflikt v Siriji
Samuel ::
Demokracija, kot jo poznamo danes, je zgolj sredstvo za ohranjanje socialnega miru.
Pesek v oči.
Tisti, ki res vladajo, slišijo na ime Kapital.
Eni sicer temu pravijo Deep State.
Tisto prvo preveč diši po Marxu.
Ker popolne demokracije praktično ni možno imeti, imejmo kar diktaturo. Ne, hvala.
noticably not worth noticing.
Pesek v oči.
Ja sej vemo, fašizem se prodaja kot demokracija.
Samuel ::
BOT čaka pred PCjem in odgovori takoj.
PS: Govorim o ruski "demokraciji".
Sem msilil da govorimo o Asadovi demokraciji. Verjetno je bila želja Fašistov, da je potrebno sistem zjebat. Kot kaže uspešno.
Če te zanima Egipt :
Postimo da predsedniški kanditati izginjajo, no novinarstvo ni niti kaj preveč uspešno. Na primer demokracije na delu s strani nekih Fašistov :
Evidence including footage of a trotting horse from Sky News Arabia; holiday snaps; a pop music video, and like the fictive account of Josef K - a bank employee, who is unexpectedly arrested one morning for an unspecified crime, the story of the 'Al Jazeera 3' makes for uncomfortable reading.
Ali no že videno bližje demokracije :
It has left thousands of Egyptians jailed for a year or more now: some sentenced to multiyear terms for no more than marching in a demonstration, some enmeshed in chaotic mass trials, others not even charged yet, and some on extended hunger strikes.
Ali pa primer demokracije v Libiji :
A political solution appears to remain out of reach for Libya seven years after Gaddafi's toppling. The country is grappling with civil war, humanitarian crises and the threat from the Islamic State of Iraq and the Levant (ISIL, also known as ISIS), leading some to question the 2011 foreign intervention that removed Gaddafi from power.
Vse v imenu Fašizma. Seveda pa lahko daš vire , kako je vse našteto napačno in laž generirana s strani Ruskih troll botov.
Samuel ::
Nacist govori čez fašizem. PRESMEŠNO.
Oprosti, staistika pravi da sem socialist, ampak tega ti ne prepoznavaš, vsak ki je poti Fašizmu je naci ali pa Rsuki oziroma China.
To da moramo tebi verjetni na besedo , da je Fašizem najboljši, ko pa dam linke, te linke ne znaš niti argumentirat, kaj šele dati kak židovski članek, ki govori nasportno napisanemu. Sory, mene jugoslovanski sistem ni poneumil, da bi slepo prevzel eno z drugim.
Redikulozno je to, da ne vidiš kako te motijo samo fašizmi, ki niso USofA sponsored.
Smešno je, ko Turki govorijo o napadu na teroriste v Afrinu, pa to počnejo skupaj z đihadisti in Al-Qaedo, prikimavajo pa jim Američani, ki sodelujejo z YPG, katerega Turki napadajo (češ, da gre za teroriste), istočasno pa imajo Američani Al-Qaedo/Al-Nusro/HTS za velike teroriste.
In seveda ni slišati kaj veliko o tem, kako Turki zapirajo novinarje, zdravnike, kurdske politike in nasploh kogarkoli, ki si drzne reči kaj nasprotnega uradni politiki. Ne, Turčija je velecenjena NATO zaveznica in G20 država.
Dragec, Jugoslavija je v zadnjih dvajsetih letih obstoja bila pojem demokracije za današnjo Turčijo in podobne države, ki jih podpirajo ZDA.
Cervantes ::
Haha. Kot bi rekel Kosovel:
Demokacija je fašizem on fašizem je demokracija.
Kje poteka ločnica?
Kje poteka ločnica?
Samuel ::
HVALA ENAKO!
PS: Izrael ima cca 8 miljonov prebivalcev in je obkrožen s par sto miljoni Muslimanov. Kalkuliraj.
Ej, če si sposoben zagovarjat Rusijo v tem (da so se umaknili iz Afrina), potem si boš že kaj zmislil tudi za Američane.
Turčija NI velecenjena v NATU. Od kod ti ta klobasarija?!?!?!
Mislim, da je popolnoma jasno, da Američani v popolnosti sploh NE podpirajo uradno politiko Turčije. A si slep, da tega ne vidiš!?
Samuel,
Oprosti ampak ko bereš te Ogrožene izraelce.
No oseba : Netanyahu: Iran is the greatest threat to the world
Potem : Netanyahu-linked officials arrested over corruption
No če se sprašuješ okoli Putina, bi se lahko začel spraševati, če je Netanyahu prava oseba za zagotovitev mira na bližnjem vzhodu. Dvomim, da so nameni , no demokratični.
Lahko pa pobiramo stave, a bosta Donald in Netan ostala do konca mandata ?
- spremenil: Mr.B ()
Samuel ::
Ne vem, kako lahko nekdo misli, da so ogroženi Muslimani, če jih je pa 40-50x več?!
Kitajsci pa rusi, če jih je pa 4-5x vač. Žal zelo kratek doseg.
Muslimani kot celota niso nič ogroženi, še posebej ne izraelski prijatelji iz Savdove Arabije in njihovi džihadistični wahhabi ljubljenčki vsepovsod po BV in južni Aziji ter seveda Egipt in vsi ostali USofA protektorati.
Izrael dela dramo in preventivno napada druge države, kar je zločin, zaradi katerega bi jim že zdavnaj nabili sankcije, če jim USofA ne bi držali štango v VS OZN.
Mimogrede, turška partnerja Ahrar al-Sham in Nur-al-din-Zenki sta sklenila zavezništvo.
Samuel ::
Neumna primerjava. Kitajska ne kriči "death to Russia" zadnje 40 let.
Izrael in Iran sta defacto v vojni od trenutka "Death to Izrael".
- spremenil: Samuel ()
Pa kljub temu Amerika opraviči oboroževalsko tekmo, ker jih kao Kitajci ogrožajo, Tako kot Izrael zaseda ozemlje, ker se kao počuti ogožene.
Leta 1967 je Savdski kralj Faisal podpisal deklaracijo z drugimi arabskimi voditelji..ni priznanja Izraela, ni pogajanj z Izraelom in ni miru z Izraelom. Danes se ljubčkajo pod odejo.
Iran si, glede na Izraelski jedrski arzenal, ne more privoščiti odprte vojne z Izraelom. Istočasno pa Irana ne bodo mogli več spraviti iz Sirije. Če se ne bi šli rušenja sirskega režima, se to ne bi zgodilo.
Drugače pa na BV ni samo igra Izrael vs. nasprotniki. Imamo tudi boj za prevlado med Iranom in Savdovo Arabijo, boj med Suniti in Šiiti, Kurde in Kurdistan, fašistično Turčijo z ozemeljskimi pretenzijami (kar vključuje še vedno nerešen Ciper), nestabilna Libanon in Egipt ter vojno v Jemnu. Izraelski režim ni edini drekač na igrišču, je pa sedaj z Bibijem bolj nevaren, saj bo poskušal preusmeriti pozornost s svoje podkupovalne afere.
Separately, Turkey has denied using chemical weapons in Afrin after being accused of doing so by a monitoring group and the YPG.
Six people were reported to have suffered symptoms of a gas attack during the bombardment of a village on Friday - but Turkey's Foreign Minister Mevlut Cavusoglu said it was a "fabricated story".
To je odličen opis Gadafijevega marketinga, pri katerem nekateri čakajo v vrsti ko zvišajo cene.
Enako velja za Kubo, Venezuelo in Rusijo.
Se en ki ne ve kaj je Fašizem, ampak ja izrael je demokracija na vrhu. Kar vprasaj italjane pod Musolinijem.
- predlagal izbris: Smrekar1 ()
Po ruski definiciji je fašist tisti, ki se upira pravični ruski vladavini.
Sam imam raje kaj malo širše sprejetega. Najbrž ne boš razumel.
Če je to tvoj edini argument, se pridruži samuelu.
windigo ::
Glede na to, da je turška ofenziva na Afrin precejšen fail in so uspeli zasesti samo nekaj vasic direktno na turški meji, so verjetno turški komandanti pod precejšnjim pritiskom, zamenjava je še najmanj, kar se jim v Erdoganovi Turčiji lahko zgodi (v Turčiji si hitro lahko izdajalec), tako da me ne bi začudila kakšna uporaba sredstev, zaradi katerih se gre lahko na kakšno mednarodno sodišče. Med Erdoganovo nemilostjo in možnostjo sodišča se pač izbere zanje manj hudo opcijo. In večje zlo.
Če to zaradi Erdoganovega besa postane uradno požegnano in uporabljeno v Afrinu, ne znam niti približno predvideti posledic, kaj vse se bo še dogajalo na tistem koncu.
Cervantes ::
Za začetek si lahko malo bolj skromen.
Kajti:
Bolje dober fašizem kot slaba demokracija!
nevone ::
A lahko opišeš, kaj je to dober fašizem? A to, da si ti fašist?
Temu kar je morda bolje od demokracije, se reče razsvetljeni absolutizem, ne pa fašizem. Ampak verjamem, da vam bolj na fašizem vleče.
o+ nevone
Cervantes ::
V čem se razsvetljeni absolutizem razlikuje od fašizma?
In seveda sem fašist, ker za prosvetljenega absolutista ne izpolnjujem pogojev,
Kako pa zgleda dober fašizem?
Tako, da si pri koritu...
Recimo kot slovenska javna uprava in njeni zaposleni...
Cervantes ::
Razsvetljeni absolutizem dela za dobrobit ljudstva.
Fašizem dela za dobrobit korporativne elite, ki podpira režim.
Razsvetljeni absolutizem je antiteza fevdalizmu, fašizem je moderna različica fevdalizma.
Podobna sta si samo v tem, da gre za dva nedemokratična sistema. Še en fail Cervantesa. No, saj smo že vajeni.
xxxul ::
Crvantes vas majcken trolla, pa ne dojamete.
Pocasi se transformira v jype-ta. ker bi ble fojbe preveč očitne je izbral drugo smer
Cervantes ::
Pocasi se transformira v jype-ta. ker bi ble fojbe preveč očitne je izbral drugo smer![]()
Ma saj.
Enkrat nazaj sem že predlagal uvedbo nekakšnega shredderja, pa se ni prijelo.
Mi grejo pa na živce tipci, ki niso sposobni izza svoje zabetonirane ograje pogledat še malo naokol in morda uvideti, da ni vse tako črno-belo, kot diktira njihova indoktrinacija.
- spremenil: Cervantes ()
Največji hec pa je v tem, da svojo zaslepljenost z enim polom tako radi pripisujejo drugim.
Pogosto je težava v tem, da je za razumevanje ironije in sarkazma potrebna določena širina
nsa_ag3nt ::
Mr.B
A je že 1 april ?
Je letos pohitel.
Ja, Iran ima po celem svetu svoje vojaške baze in jedrske rakete z dolgim dosegom, njihov predsednik povsod ko potuje po svetu ima s seboj "jedrski kovček" http://www.telegraph.co.uk/news/2018/02..., njihovih 10 letalonosilk s spremljajočo floto (ostali države imajo 1 ali max 2, če sploh imajo katero) pluje so vseh svetovnih morjih, uradni vojaški proračun je 10 x večji od Rusije, ja Iran je nedvoumno glavni bad guy.
btw, Izrael ima dovolj jedrskih raket in podmornic, da spremeni celotno Evropo v puščavo.
Samuel,
A je že 1 april ?
Je letos pohitel.
- spremenilo: nsa_ag3nt ()
arnecan1 ::
Jaz oziroma kdorkoli lahko serje po forumih kolikor hoče, spremenilo se zato ne bo nič.
Kdor misli, da je svoboda govora kaj drugega kot ventil za nezadovoljneže, še ni slišal za Deep State.
Sucks, not stinks.
Saj ni nič čudnega, zakaj po eni strani postavljaš vprašanja o demokraciji, po drugi stani ti je pa Rusija s Putinom tako všeč. Putin postaja (oziroma je že) center, kjer se združujejo razni totalitaristi (ti) ter nacisti (Mr.B). Res super druščina.
Jype, zdravo. A imaš novo ime?
7982884e ::
sedaj tudi uradno, rusko obrambno ministrstvo:
“During a recent military clash, in which servicemen from the Russian Federation did not participate in any way... citizens from Russia and CIS (former Soviet) countries died,” the ministry said in a statement. “There were also about several dozen wounded.”
windigo ::
Rusi so pripeljali v Sirijo par novih frčeplanov (med drugim celo prototipe). Lovce.
Gotovo gre tudi za reklamo za njihovo orožarsko industrijo, po drugi pa tudi morda opomin, da bi kakšna zračna kampanja nad Sirijo lahko imela kakšno dodatno neznanko in težje izračunljivo ceno.
Samuel ::
Če tole dol pade zaradi ne vem kakšnega razloga, bo tole pogreb za rusko letalsko industrijo.
Ker?
Samuel ::
A potrebno razlagat?
Ker že tako ni kupcev, razvoj pa od prvega poleta traja že 8 let, pa ni letalo niti približno v takem stanju, kot je bilo prvotno zamišljeno.
No se zato so pa nehali delat F22, so ugotovili da je preveč bugast za odpravo napak, vključujoč rakotvorni "stelth" premaz ki izpareva, življenksa doba, ki je zaradi defektvo, pač bistveno manjša, težave s kisikom, trid dnevna rotacija, verjetno ga zaradi premaza ne morejo prej kot v treh dneh spraviti v lusft "po misiji" če to ni ravno nujno, pa še kaj. Kot na primer streljanje na daljavo, no najdalši strel je bil 35 km, pa ne z f22 pa še to na miga brez radarja in opozoril...
Ali mistery, da na napad na irak, so najprej leteli helikopterji ter enote elenskega bojevanja, šele potem, ko so helikopterji uničili kar je bilo potrebno uničiti, so preleteli s stelth letali. Blemaža bi bila enostavno prevelika.
Samuel ::
Če ima F22 toliko problemov, kaj je šele z SU57, 20 let kasneje. Za v kanto direktno.
Sammi,
ti pomagam, da boš izpadel resen sogovornik.
Na primer : Ta nova konzerva se bo morala zoperstaviti Izraelcem, ki so v decembru objavili, da je njihov F35 sedaj v operativni uporabi.
Um, ne.
2003 invasion of Iraq @ Wikipedia
Opening salvo: the Dora Farms strike
On the early morning of 19 March 2003, U.S. forces abandoned the plan for initial, non-nuclear decapitation strikes against 55 top Iraqi officials, in light of reports that Saddam Hussein was visiting his sons, Uday and Qusay, at Dora Farms, within the al-Dora farming community on the outskirts of Baghdad. At approximately 05:30 UTC, two F-117 Nighthawk stealth fighters from the 8th Expeditionary Fighter Squadron dropped four enhanced, satellite-guided 2,000-pound GBU-27 'Bunker Busters' on the compound.
One bomb missed the compound entirely and the other three missed their target, landing on the other side of the wall of the palace compound. Saddam Hussein was not present, nor were any members of the Iraqi leadership. The attack killed one civilian and injured fourteen others, including four men, nine women and one child. Later investigation revealed that Saddam Hussein had not visited the farm since 1995.
Opening attack
On 19 March 2003 at 21:00, the first strike of the operation was carried out by members of the 160th SOAR: a flight of MH-60L DAPs (Direct Action Penetrators) and four 'Black Swarm' flights - each consisting of a pair of AH-6M Little Birds and a FLIR equipped MH-6M to identify targets for the AH-6s (each Black swarm flight was assigned a pair of A-10As) engaged Iraqi visual observation posts along the southern and western borders of Iraq. In the space of seven hours, more than 70 sites were destroyed, effectively depriving the Iraqi military of any early warning of the coming invasion. As the sites were eliminated the first heliborne SOF teams launched from H-5 airbase in Jordan, including vehicle-mounted patrols from the British and Australian components who were transported by the MH-47Es of the 160th SOAR. Ground elements of Task Force Dagger, Task Force 20, Task force 14 and Task Force 64 breached the sand berms along the Iraqi border with Jordan, Saudi Arabia and Kuwait in the early morning hours and drove into Iraq. Unofficially, the British, Australians and Task Force 20 had been in Iraq weeks prior.
On 20 March 2003 at approximately 02:30 UTC or about 90 minutes after the lapse of the 48-hour deadline, at 05:33 local time, explosions were heard in Baghdad. Special operations commandos from the CIA's Special Activities Division from the Northern Iraq Liaison Element infiltrated throughout Iraq and called in the early air strikes. At 03:15 UTC, or 10:15 pm EST, George W. Bush announced that he had ordered an "attack of opportunity" against targets in Iraq. When this word was given, the troops on standby crossed the border into Iraq.
Pac-Man
The thought that a critical portion of Iraq's elaborate radar "fence" was blinded by helicopters seems strange in this day and age of stealthy standoff weaponry. But 25 years ago today, the choices for kicking open a hole in Iraq's radar defenses weren't so plentiful
Vzemi kak twixic v tableti. Sicer pa bi bilo tudi danes lahko enako, leteti moraš nižje kot te lahko radar vidi ali tragetira.
Cervantes ::
Zakaj v Siriji ne deployajo F-35?
Enostavno. Ker nočejo, da si jih "ogledajo" ruski radarji.
Ker morda bi se izkazalo, da se da kaj videti.
Pa ssej formalno letijo. Razzen, ce se bodo sedaj drzali zelo dalec prec... LITTLE LESS THAN A YEAR AFTER THE FIRST TWO AIRCRAFT WERE DELIVERED TO ISRAEL, THE ISRAELI AIR FORCE F-35S HAVE ACHIEVED IOC (INITIAL OPERATIONAL CAPABILITY).
Po moje ta ruski awacs bo vse to zbiral, samo vprasanje je kdo si bo vec upal. Glede na fiaske, verjetno ne rusi.
Spet, stealth ne pomeni nevidnost, ampak prikritost.
Zagotovo se da kaj videti. Ampak precej manj kot v primeru F-16.
Samuel ::
]Na primer : Ta nova konzerva se bo morala zoperstaviti Izraelcem, ki so v decembru objavili, da je njihov F35 sedaj v operativni uporabi.
Ta konzerva v tej konfiguraciji kot je, seva v zraku kot novoletna jelka trenutno. Pa Izraelci imajo xy protiletalskih sistemov, ne samo F35.
F35 in F22 kažejo na sejmih, ljuba duša...
Bolj je zanimivo, zakaj bi Rusi hoteli, da si Američani ogledajo SU-57?!
