Konflikt v Siriji
Konflikt v Siriji
Samuel ::
Mr.B je izjavil:
Konsprator,
pozabil si dodati kako se vrhunski Abrami kuhajo. Verjetno so res na nivoju T72/80.
Abramsi imajo zadaj v kupoli shrambo granat:
zavarovano z drsnimi vrati, ki preprečujejo poškodbe znotraj kupole, kjer je posadka.
Pri T72/80/90 pa kupole letajo po zraku...
noticably not worth noticing.
konspirator ::
Kakšen info, kako jo je odnesla posadka Abramsa ?
Okoli Tel Madiq se dogaja, SDF zavzela omenjeno vas iz rok FSA/TR
http://syria.liveuamap.com/en/2016/26-o...
http://syria.liveuamap.com/en/2016/25-o...
Turki granatirajo SDF na tem področju
SAA letalstvo iz helikopterjev bombardiralo FSA/TR "borce"
Turki odkrito podpirajo isil:
Turkish FM: Turkey will take actions if any group attack Talafar, western Mosul.
http://isis.liveuamap.com/en/2016/26-oc...
Samuel ::
ta Abrams (verjetno starejši M1A1) je bil zadet ravno v skladišče granat v zadnjem delu kupole
konspirator je izjavil:
verjetno so vsi preživeli
  • spremenil: Samuel ()
Samuel,
odvisno od rakte. Če je zadnji model TOW-a, je skoraj verjento šel skozi municijo do posadke. Na filmu tudi zelo dobro vidiš dva stolpa ognja, to pomeni, da je zadetek penetrlal notranjost tanka...
Janse reserch pravi tudi tole :
The armour on five of Iraq's M1A1 Abrams tanks was penetrated by anti-tank guided missiles (ATGMs) and six helicopters were shot down between 1 January and the end of May, The New York Times quoted an unnamed US official as saying on 13 June.
The official said 28 Iraqi Army Abrams had been damaged in fighting with militants, five of them suffering full armour penetration when hit by ATGMs. The United States supplied 140 refurbished M1A1 Abrams tanks to Iraq between 2010 and 2012. While they have new equipment to improve situational awareness, they do not have the depleted uranium amour package that increases protection over the tank's frontal arc.
Samuel ::
Mr.B je izjavil:
Samuel,
Saj je penetriral direktno v skladišče municije v zadnjem delu kupole in jo detoniral. Kupola je še vedno na tanku.
Sicer pa so tako ali tako tanki v zadnjem delu najbolj ranljivi.
Samuel,
Bodo že povedali. Kupola pri Abramsu pač ne leti v Luft kot pri T-xx tankih, ker pritisk nima kam drugam iti kot vs kupolo v luft.. Zato s posnetka ne moremo reči če so preživeli. Toda če je TOW, pač ni preživel.
Samuel ::
Ta dizajn je namenjen ravno temu, da posadka preživi napad z TOW (Tube-launched, Optically tracked, Wire-guided missile).
Glede na komentar spodaj:
"It is indeed a Kornet ATGM you can notice that by distinctive flight path of the missile..."
Bi se blo za vprašat kaj toliko ruskih Kornetov dela v rokah ISISa (glede na to, da je edina aktivna fronta med SAA in ISIS v Deir Ezorju) in ISIS praktično nima kje drugje prit do njih. Po drugi strani pa prav ironično, vedno, ko ISIS zadane kakšen SAA tank v okolici Deir Ezorja, vedno proruska propaganda kaže ameriške ATGMje?!??! Čisto brez vsake osnovne logike.
7tom1ja ::
he he
a ni to lepo, ameriška raketa uniči ameriški tank; glavno da je biznis pravijo
Na nas leži naloga, da naprej razvijamo našo samoupravno socialistično družbo,
da jo gradimo na revolucionarnih temeljih, temeljih marksizma.
Brigada AVNOJ 77;Komisar Ivan Janša
Samuel ::
7tom1ja je izjavil:
he he
Že spet si zgrešil.. gre za ruski Kornet (delivery form Rasha), samo da se nagaja Američanom v Iraku.
konspirator ::
Isis dobiva svoje towe od moderate western backed glavorezne opozicije, nekaj protitankovskega orožja so (verjetno?) dobili tudi letos junija v skladišču SAA v Deir Ezorju, od koder so se slednji morali na hitro umakniti in ga niso spustili v zrak.
Samuel,
Slika lepo kaže kuhanje Abramsa : http://www.janes.com/article/39550/iraq...
Dokler Iraške sile ne pokažejo slike, kako je posadka preživela, je posadka kuhana.
SA je leta 2015 poslala 500Tow raket v Sirijo. Glede na to da so do sedaj poslali v luft vse razen T90, je jasno koliko je ruska konzerva, zaščitena proti TOW raketami. Sklepam da Amerji niso toliko nemumni da bi pošiljali tow-e, ki napadajo kupolo od zgoraj, ker bi pri morebitenm posredovanju, lahko tudi oni občutili kuhanje ne samo starih Abramsov...
Samuel ::
Fora je v tem, da ISIS okoli Deir Ezorja (torej ravno tam, kjer naj bi prišli do ruskih Kornetov) uporablja izključno ameriške ATGMje (vsaj tako vidimo iz propagande). Zdaj mi pa povej, kje je tu logika.
7tom1ja ::
Samuel je izjavil:
7tom1ja je izjavil:
he he
absolutno nemogoče, da lahko rusko sranje "verjetno že iz SZ časov" uniči modern ameriški tank
Samuel ::
7tom1ja je izjavil:
Absolutno je nemogoče, da je nekdo tako len, da ne zna niti na Wikipediji pogledat za kaj se tu gre:
9M133 Kornet @ Wikipedia
Service history: 1998–present
Ampak ti si verjetno malo starejši možakar, še iz bivše Juge, pa ti ne grejo novejše tehnologije kaj dobro od rok.
Mr.B je izjavil:
Samuel,
Če prebiješ oklep in prideš do notranjosti in vžgeš gorivo, se bo tank "skuhal".
In starejši M1A1 še dosti prej kot M1A2 (pa že ta design je star 30 let - torej starejši od ruskih T90).
Samuel,
Če en pameten. Kaj ko bi kaj poguglal. Glede na specifikacije, je prebila skladišče in končala pri posadki...
chucki ::
Tole pa res dvomim, da so preziveli v tanku, razen ce je bil prazen :)
Samuel ::
Mr.B je izjavil:
To, kar si napisal, je totalna bedarija. Razen, če misliš, da v skladišču ni bilo granat.
suhifallen ::
a nima SAA v 1070 apartment project že nekaj zavzetega?
konspirator ::
Samuel
Pojma nimam, če je bil zgoraj uporabljen RU kornet ali ZDA tow, tisto je samo komentar ob video posnetku, ki je lahko pravilen ali napačen.
suhifallen
1070 apartment project so poskušali zavzeti direktno in ni šlo, sedaj se gredo "kotel" sistem, torej ga bodo obkrožili iz čimveč strani.
Samuel ::
iz te skice se lepo vidi, da ni teorije, da bi raketa prišla do notranjosti kupole...
Samuel,
Bodo že dali objavo zaradi medijke slike : so ali niso preživeli.
Je Kosovo po tvoje legalna država?
Ne ni, ampak dokler za USA in lakaje EU le-ta je (izvzemši redkih primerov kot so Španci recimo) tako dolgo nima niti ena izmed teh držav pravico komentirat aneksacije Krima...
Kosovo je zibelka Srbije, pa morda bi še pogledal stran in rekel naj jim bo pa imajo državo, če Albanija že ne bi obstajala, in ne bi imeli kam za it
Samuel ::
Samuel, Bodo že dali objavo zaradi medijke slike : so ali niso preživeli.
recimo statistika iz prve zalivske vojne s primeri, ko je pri Abramsih prišlo do "Ammunition blown-up"
History of the M1 Abrams @ Wikipedia
rezultat:
TF 1-41, 2nd Armored Division : 1 KIA, 3 WIAs
197th Brigade, 24 Infantry Division: None
2nd Platoon, A Company, TF 4-64 : 1 WIA
Torej v petih primerih je prišlo do enakega efekta (Ammunition blown-up) in je v kar treh primerih posadka odnesla brez praske.
konspirator ::
http://www.independent.co.uk/news/world...
https://www.amnesty.org/en/latest/news/...
Kirurško natančni letalski napadi Murica koalicije - samo 300 civilistov v 11 napadih rip.
Samuel je izjavil:
rezultat:
Bodo objavili, ali so ali niso... Verjetno v roku 24ur.
Samuel je izjavil:
Slabo poznaš teorijo in moderne bojne glave PO raket.
Kako je IS prišel do večje zaloge orožja (tudi PO raket in lanserjev ter protizračnih prenosnih raket in lanserjev je bilo objavljeno v tej temi...ko so osvojili večje skladišče SAA katerega le ti niso uničili ob umiku). Za razliko od Američanov & Co. se Rusi verjetno dobro zavedajo, da se jim vso orožje, ki bi ga dali ali prodali islamistom, lahko hitro odbije v glavo.
Kako je IS prišel do ameriških raket TOW, hrvaškega orožja ipd. je tudi dobro znano.
Dajmo samo za potrebe ravnotežja:
The report focuses on six attacks in Homs, Idleb and Aleppo between September and November 2015 which killed at least 200 civilians and around a dozen fighters.
Razmerje je pri Rusih kvječemu slabše, ampak za naše rusofilčke so tisti očitno manj mrtvi - s tem da gre pri amerih za DO 300 mrtvih v 11 napadih, pri Rusih pa za VSAJ 200 mrtvih v 6 napadih.
No ja, če malo pogledaš po Youtube, je kar nekaj kuhanj Abramsov, sploh iz SA.
Če posadka preživi ali ne, niti ni pomembno (razen za posadko...). Po takem zadetku je tank uničen. Posadko pa ponavadi tako potolčejo s kakim mitraljezem ko skoči ven. Že videno v Siriji.
Kornet je pač skoraj zadnja tehnologija pri Rusih. Nekaj novejših še imajo, ampak jih niso poslali v Sirijo.
windigo ::
Smrekar1 je izjavil:
Debater Smrekar1 je v tej temi pred časom opravičevanje zločinov posameznih storilcev z navajanjem podobnih ali hujših zločinov drugod označil za moralno zavržno in dobesedno nagnusno početje.
windigo je izjavil:
Saj jih nisem opravičeval, postavljal sem jih v primeren kontekst. Marsikdo tule je namreč mnenja, da so Rusi v čem boljši od ZDA. To je res pri nabijanju in trolanju, drugje pa bolj malokje.
windigo je izjavil:
A misliš, da se ga kaj prime, ko ga ujameš z roko v marmeladi? Enostavno ignoriraj..to je edino zdravilo za trole.
Smrekar1, je pač pod ravnotežje mislil, da če v lusft vržejo amerji eno barako sredi ničesar, pa pri tem še kdo on civilistov dobi po p, je enako kot če bombo mečeš v nn fakto bolj naseljeno območje, že statistika ti da vetra...
Samuel ::
Mr.B je izjavil:
Bolj je čudno to, da nekdo jemlje propagando ISISa (to je tistih kao 300 ljudi ubitih) zares. Po TVju so pa takrat kazali nekaj mrtvih (največ deset).
In Aleppo ni podoben primer v teh zgodbi. Bolj je svinjarija kaj se dogaja z bombardiranji (RU, SAA) letal v Idlibu. Tam nihče ne drži civile kot živi ščit, pa bombe dnevno padajo po bolnicah, šolah, pekarnah...
konspirator ::
Samuel
Glede na domnevno število sta Aleppo/Idlib absolutna rekorderja po številu bolnic, šol, pekarn.
Samuel ::
Samuel
Saj pada večkrat mesečno po istih objektih (dokler niso popolnoma uničeni).
No, tale je od včeraj, ko je v Maarat al-Numanu padlo po šoli.
konspirator ::
Whistleblower exposes how NATO's leading ally is arming and funding ISIS
"I am the police chief who was asked to guard ISIS terrorists"
https://medium.com/insurge-intelligence...
MadMicka ::
kospirator, a ti veš, koliko je bolnic in osnovnih ter srednjih šol v Ljubljani, ki ima dobrih 250 tisoč prebivalcev?? Lahko celo leto vsak teden bombardirajo drugo, pa jih bo še vedno večina stala.
Samo vojni zločinci nalašč bombardirajo šole in bolnice. Kako vemo kdaj je nalašč? Ko kljub opozorilom mednarodne skupnosti tolčejo po istem objektu in ko bombardiranje bolnic postane stalnica. Take je potrebno postaviti pred zid.
  • spremenil: MadMicka ()
konspirator ::
Turkey's secret pact with Islamic State exposed by operative behind wave of ISIS attacks
The elephant in NATO's room: state-sponsorship of Daesh
konspirator ::
USA pametne pametne bombe
https://twitter.com/hashtag/DAQUQ?src=h...
Od 21.10 dalje.
Samuel ::
To je vse super, ampak mi še vedno čakamo ruske dokaze o vpletenosti Erdogana v trgovino z ISISom.
Glede na to, da sta zdaj Putin in Erdogan že spet buddyja, bomo morali na dokaze ponovno malo počakati.
Ve kje je trenutno Kuznjecev ? Šla je skoz Gilbratar, ampak če kdo ve točno kje je?
Samuel ::
Od 21.10 dalje.
Rusi v bližini te vasi v okolici Kirkuka nimajo ničesar, da bi lahko karkoli spremljali. To je lokacija globoko v Iraku, nekaj sto km stran od česarkoli ruskega. Bedna ruska propaganda, ki naj bi skušala uravnotežit lastna dejanja v Siriji. Novica namenjena ravno takim, ki ničesar ne preverijo.
SimplyMiha ::
V dobi Interneta ta človek pravi, da Rusija ne more spremljati dogajanja globoko v Iraku, kjer ima vsakdo svoj smartphone...
windigo je izjavil:
Torej je Ameriško ubijanje SAA REGULARNE armade Sirije, ubijanje policistov v Afganistanu/Iraku pa bombardiranje bolnic ok, rusko pa ne?
Sicer pa kdo ima dokaze da v bolnici ni zavetišče iskalo 20 pripadnikov teroristov in iskalo ščit pod rdečim križem bolnic??? A lahko to dokažeš?
Samuel ::
SimplyMiha je izjavil:
LOL, torej so poklicali po telefonu nekoga v to vas in jim je ta povedal, da so to bile ameriške bombe
Mato989 je izjavil:
A lahko ti dokažeš, da se 20 pripadnikov teroristov ni skrivalo v bolnicah v Afganistanu in Iraku?
Glede na to kakšnega ogorčenja in zgražanja so bili ti napadi deležni.
Ko boste razumeli in uvideli da mediji OČITNO pristransko poročajo boste razumeli zakaj se eni zgražamo nad eno stranjo bolj kot nad drugo :) Pa ne bi rekel da bi bil pristranski nek siol ipd omladina itd.... ampak RTVSLO, ki ga vsi plačujemo pa je tako pro ameriški in pro imigrantski da glava boli....
Če bi količina novic posvečenih napakam USAja bila enaka kot količina Rusom bi bilo ok,bi se nad obojim zgražal ampak prav silijo me da se postavim na stran javno zatirane države :) Hegemonija ZDA ne koristi nobenemu razen ZDA.
Samuel ::
Saj Rusi te cilje napadajo zavestno. To niso napake. To je njihova vojaška doktrina.
Samuel je izjavil:
Pa saj to je dobro, kdorkoli ni v teh letih spokal iz Sirije na varno v Jordanijo ali Turčijo je itak simpatizer ISISa, če ne pa je spokal na ozemlje pod vodstvom SAA... rezultat je, da je v sovražnih bolnišnicah zdravljeno večinoma simpatizerstvo z ISISem in res ne vidim razloga da bi jih pustili pri miru... Kot da bi puščal da si nasprotnik opomore, posekat vse dol pa mir.
MadMicka ::
Če bi policija opravljala svoje delo, bi takile osebki kot je Mato989 že sedeli za rešetkami zaradi sovražnega govora zoper temeljne človekove pravice in svoboščine.
KZ-1 v 102. členu kot vojna hudodelstva določa napade na ranjence in bolnice, ta določba je povzeta iz mednarodnih aktov, katerih namen je prispevek k civilizaciji in napredek človeštva.
120 / 314
