Forum » Pomoč in nasveti » Blue screen
Blue screen
macoom ::
On Sat 5.9.2015 17:41:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090515-22152-01.dmp
This was probably caused by the following module: atikmpag.sys (atikmpag+0x780C)
Bugcheck code: 0x116 (0xFFFFFA8006903010, 0xFFFFF88003A9080C, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\atikmpag.sys
product: AMD driver
company: Advanced Micro Devices, Inc.
description: AMD multi-vendor Miniport Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: atikmpag.sys (0xFFFFF88003A9080C)
product: AMD driver
Je računalnik za v smeti ali je možno te napake popravit brez večjih stroškov?
product: AMD driver
product: AMD driver
mat3 ::
Obe napaki se navezujeta na težave z grafičnim gonilnikom ali z grafično kartico...
AMD Ryzen 7 3700X, 32 GB DDR4-3600 MHz G.Skill TridentZ Neo
500GB Samsung Evo Plus, Crucial P2 500GB, GTX 1660 Super, 4x 3TB HDD
http://www.bozic17.blogspot.com
macoom ::
Hvala ste mi bil v veliko pomoč. Bom poizkusil z namestitvijo novih gonilnikov. V primeru nerešene napake je težava v sami kartici? Je intergrirana na matično tako da lahko vržem v smeti. lp
| » | atikmdag.sys - rabim pomočOddelek: Pomoč in nasveti | 7322 (5805) | The Player |
| » | atikmpag.sys BSoDOddelek: Pomoč in nasveti | 4172 (3920) | zupanman |
| » | Sesuvanje računalnika (NVIDIA)Oddelek: Pomoč in nasveti | 1663 (1305) | KTr1sk |
| » | Plavi ekran pomoč FlashplayerOddelek: Pomoč in nasveti | 4443 (4037) | D-PaX |
| » | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2913 (2652) | Duhec |
