ZDA, volitve 2016 in politična ureditev
Zheegec ::
Štos poglej si zgornji link pa komentar o njemu, da se boš malo nasmejal in boš manj resen.
S samim bombardiranjem ne bo šlo to je jasno, je pa to zagotovo en mali korak k rešitvi tega problema..
To so tudi Bush&Cheney&Blair rekli v 2003, ja. Se je izkazalo, da je bombandiranje odličen korak k rešitvi problema miru...
Janez Janša, 29.04.2014
Jim Jones ::
Zheegec je izjavil:
Donald Trump's first TV ad shows migrants 'at the southern border,' but they're actually in Morocco
Ahaha, umiram. Trump the klovn. Prav vseeno mu je za dejstva in kaj se dogaja. Samo, da je reality show.
hahahaha jaz pa umiram samo da sem videl naslov internetne strani http://www.politifact.com/ :)):))
Sem zaprl še preden sem sploh prebral prvi stavek :)):))
Bombardiranje ISIS-a je zagotovo korak v pravo smer. Če ni mi povej kateri je pravi korak oziroma kako bi se ti tega lotil oziroma ta problem rešil. Z besedo na dan...
Ni potrebno. Dovolj je da preberem smešne komentarje Clintonovih in Bernijevih fanov pa je že to več kot dovolj smeha :))
jype je izjavil:
Obama ni socialist.
Seveda je. Precej zmeren, sicer. Je pa dovolj pameten, da tega ne pove na glas.
Obama je tudi ateist, je precej ocitno.
Zheegec ::
Saj ne nakladajo nekaj v prazno, so našli original video footage. Preberi si.
PolitiFact was able to trace the footage back to the Italian television network RepubblicaTV. On May 3, 2014, the network posted footage of Moroccans crossing the border into Melilla, one of two enclaves on the Moroccan coast that are held by Spain. Migrants who cross the border there are essentially entering territory held by a European Union nation, even though they are still on the African continent. (It can also be seen posted by a YouTube user here.)
funny now?
youtube verzija - Published on May 3, 2014
Regardless of Trump's imagery, the Pew Research Center noted last month that "for the first time since the 1940s, more immigrants from Mexico are leaving the U.S. than coming into the country. The shift is due to several reasons, including slow economic recovery after the Great Recession that may have made the U.S. less attractive, as well as stricter enforcement of U.S. immigration laws, particularly at the border."
Trump spokeswoman Hope Hicks said she did not know the source of the video included in the ad and that she doesn't speak for the video production company.
V glavnem noro smešno :) Trump for clown 2016.
Če pogledamo nazaj, potem tako, da se ne bombandira in problem sploh ne bi obstajal. Sedaj, ko problem obstaja pa je najlažje s prenehanjem podpiranja SA in Quatarja, ter da se jih prisili, da pošljejo svoje ground troops nad ISIS in pa da nehajo podpirati ISIS. Pa da se pomaga Kurdom in Iranu na več možnih načinov. Zahod sam se mora pa čim manj vmešavati v zadevo.
  • spremenil: Zheegec ()
Jim Jones ::
Zheegec je izjavil:
funny now?
Vidim da si spregledal vprašanje:
Povej kateri je pravi korak oziroma kako bi se ti tega lotil oziroma ta problem rešil. Z besedo na dan...
kow> Seveda je.
Nah, nikakor ne. Če bi bil socialist, bi se tako tudi obnašal, pa se ne.
kow> Obama je tudi ateist, je precej ocitno.
A to sklepaš na podlagi tega, da ne predseduje kot mu veleva Biblija?
Štos> Povej kateri je pravi korak oziroma kako bi se ti tega lotil oziroma ta problem rešil. Z besedo na dan...
Saj smo ti povedali. Diplomacija je prvi korak. Brez nje ISISa ne moreš uničiti.
Zheegec ::
@Štos - sem dodal ravno minuto preden si postal. Pa kot drugo, si spregledal glavno vprašanje - da se Trump noro laže v videu. Imaš vse razloženo in pa linke na originalni video.
razerznak2 ::
jype je izjavil:
vsakemu "diplomatu" bi tiak odrezali glavo, kaj boš pa pol? jih kar dalje pošiljal?
Vesoljec nacist
Jim Jones ::
Uhhh ohhh a dej no ok. Povej kako bi se ti tega lotil to me zanima. Lahko je govoriti narediti pa težje. Res misliš da nihče ni pomislil vse skupaj rešiti po tej tvoji logiki?
razerznak2 je izjavil:
jype je izjavil:
Tip ne razume resno. To so ljudje ki se ne mislijo pogajati...
jype je izjavil:
kow> Seveda je.
Obamacare je precej socialisticna ideja. Pa ne pravim, da je slaba.
Zheegec ::
Saj sem ti jaz že 2x napisal, kako začneš. Pa z veliko reformo UN in NATO.
No ja, niti ne. Še vedno privatne insurance companies služijo vmes,.
kow> Obamacare je precej socialisticna ideja. Pa ne pravim, da je slaba.
Nah, to si misliš, ker so ZDA tako zelo neobičajne.
Štos> Uhhh ohhh a dej no ok. Povej kako bi se ti tega lotil to me zanima. Lahko je govoriti narediti pa težje. Res misliš da nihče ni pomislil vse skupaj rešiti po tej tvoji logiki?
Najprej bi se zmenil z Rusijo, da mora nehat kršit človekove pravice in streljat svoje opozicijske politike, ker sicer ne bomo sodelovali, ampak bomo zoper njih sprejeli sankcije. Verjetno vidiš, da je od tam še dolga pot, jaz pa nimam časa, da bi ti razložil vse podrobnosti.
razerznak> vsakemu "diplomatu" bi tiak odrezali glavo, kaj boš pa pol? jih kar dalje pošiljal?
Ni potrebe komentirat reči, ki jih ne razumeš.
Jim Jones ::
Ok spoštujem, ker si se odločil in napisal vsaj 3 stavke ne pa tako kot uporabnik @jype ki nekaj pravi pa ne zna utemeljiti oziroma razložiti.
Ja tvoja razlaga mi je všeč pač na koncu je dejstvo da jih je treba odstraniti, to je tudi moj glavni point. Recimo @jype bi se pogajal kar je povsem nerealno.
Druga kar sem želel napisati pa je, da če bodo Američani bombardirali kot to počnejo zadnje 3 mesece potem sem jaz za, kajti Irak je v hitrem času ponovno zavzel Ramadi in zdaj s pomočjo Ameriških sil napreduje proti Mosulu, če bo šlo tako naprej potem sem še kako za bombardiranje.
To resnično dvomim.
Naj se čudno sliši ampak se popolnoma strinjam. zdaj je kar je in je stvar treba dokončati. Lej še 1x na koncu vse kar si jaz želim je to da se vojna v Siriji in Iraku končata in da se lahko ponovno normalno zaživi in da se začnejo ponovno graditi mesta. To kar se zdaj dogaja dol vpliva tudi na Evropo in zato me je ta tema sploh pritegnila, ker prej sploh nisem vedel kaj se dogaja. Jaz bi tudi raje videl, da se vse skupaj reši na diplomatski način, če bi se le dalo ampak v tem primeru je to nemogoče. Upam, da se tu strinjaš z menoj. Isis je enostavno treba odstraniti.
jype je izjavil:
Ne. Na podlagi njegove biografije, dejanj, retorike.
IMO je Obama najsposobnejsi ameriski predsednik po Nixonu.
razerznak2 ::
jype je izjavil:
kot je trump rekel ne moreš metat bombe na assada in daesh hkrati, prvo treba iztrebit daesh z bombardiranjem in kopensko , ko je to rešeno potem se začnejo pogajat z assadom? kapiraš?
Vesoljec nacist
Štos> zato me je ta tema sploh pritegnila, ker prej sploh nisem vedel kaj se dogaja
No, vidiš, jaz sem pa hodil v šolo, kjer smo se učili te reči in sem zato vedel, kaj se dogaja (in še vedno vem).
kow> IMO je Obama najsposobnejsi ameriski predsednik po Nixonu.
Verjetno. Meni se sicer zdi, da iz slabe situacije iztisne ogromno, ampak po drugi strani sem prepričan, da ni dovolj sposoben, da bi prepričal ljudi, da mu pomagajo tudi v kongresu in senatu - Bernie je pa že dokazal, da to zna (in je tudi ateist).
razerznak> kot je trump rekel ne moreš metat bombe na assada in daesh hkrati, prvo treba iztrebit daesh z bombardiranjem in kopensko , ko je to rešeno potem se začnejo pogajat z assadom? kapiraš?
Trump je idiot, ali se pa samo dela da je, da bi ga volilo dovolj idiotov.
  • spremenilo: jype ()
vostok_1 ::
Jype je predvsem mislu na diplomacijo med zavezniki in vpletenimi strankami. Rusija in ZDA se morata nehat sabljat z luleki, Turčiji dve okoli ušes, oštet SA in Katar, Iran podkupit, Kurdom orožje in vojaško pomoč, on ground nadzor iraških sil, Assadu en hug, ISIS vodstvu smartbombe na čelo, specialce na ISIS kontrolirana naftna vrelišča.
Something along these lines. I know, it's not pretty.
razerznak2 ::
vostok, če pa jure rekel da bombardiranje ni dobro no, treba diplmate tja poslat da se v miru zmenijo
Vesoljec nacist
Bombardiranje ustvarja ekstremiste hitreje, kot jih pobija. Čeprav WarpedOne misli, da jih bo prej ali slej zmanjkalo, se temeljito moti.
jype je izjavil:
Ne. Ampak zaradi povecanih pooblastil drzave.
dice7 ::
množično bombandiranje je vedno prava rešitev; samo poglejte al kaido, al nusro, talibane, hamas, al shabab in zdaj še isis
Jim Jones ::
jype je izjavil:
Bravo! Točno to je trenutni problem. Obama se želi takoj znebiti Assada in Rusi tega ne dovolijo, ker dobro vedo oziroma vemo kako se je končalo ko je odšel Hussein in potem še Gadafi!
kow> Ne. Ampak zaradi povecanih pooblastil drzave.
To nima nobene zveze s socializmom.
Štos> Preden bi se ti zmenil bi ISIS zavzel že polovico middle Easta, kar bi na koncu pomenilo, da bi spet bilo treba bombardirati.
ISIS je že v Parizu, ti se pa pretvarjaš, da bombardiranje pomaga.
Štos> Bravo! Točno to je trenutni problem. Obama se želi takoj znebiti Assada in Rusi tega ne dovolijo, ker dobro vedo oziroma vemo kako se je končalo ko je odšel Hussein in potem še Gadafi!
Bravo, idiotov je toliko, da Trump vsekakor lahko dobi republikansko nominacijo, celo v državi, kjer naj bi osnovno šolstvo ljudi naučilo osnov logičnega sklepanja.
razerznak2 ::
jure a veš mogoče zakaj se obama hoče znebit assada?
Vesoljec nacist
dice7 ::
bogatas ki je cez leta ostal bogatas :O podobno kot srednjeslojec, ki je cez leta ostal ... srednjeslojec
Looooooka ::
Ene 3-4 pa še zmer je ostal lastnik in podjetja še zmer obstajajo? Večina so kazinoji v ostalih pa niti ni bil lastnik(najebali so investitorji, ki so točno vedeli v kaj vlagajo al so bli pa tko neumni, da so padli na besedo "Trump", kar je spet dokaz, da je že glede marketinga precej pameten).
Se pravi se je vsakič zmazal in se danes valja v denarju. Naši gospodarski veleumi pa nimajo za burek oziroma majo samo tisto, kar jim je uspelo skriti v tujini. Za naše razmere je model Einstein.
Če se dela neumnega zaradi volitev in zmaga potem ve kaj počne. Najbolj pomembno pa je to, da je bil že od začetka PROTI kakršnikoli invaziji na katerokoli državo na vzhodu.
Ne vem če je zdaj spremenil taktiko(če jo je potem očitno računa na točke zaradi tega).
Ne glede na to koliko je prijavil ima še zmeraj par milijard.
Čeprav gre vsem na kurac zaradi "rasističnih" izjav mu gre bolje kot folku, ki obljubljajo nebesa za katera vsi vedo, da so navadno politično nakladanje. Torej mu gre bolje z neumnostmi kot z z lažmi, ki so jih ostalim kandidatom pripravili magistri statisticnega bullshita. Ne vem če bi navadnemu idiotu vse to uspelo...
Looooooka> Ne vem če bi navadnemu idiotu vse to uspelo...
Torej je Trump posebne vrste idiot? Vsekakor. Večina idiotov se ne rodi s tako bogatimi starši.
:D
Dolgo je, ampak veliko pove o tem, za kakšnega človeka gre.
  • predlagalo izbris: Jim Jones ()
ZaphodBB ::
Tako kot ti? :>
Edit: za neposvečene, is a meta joke.
  • spremenil: ZaphodBB ()
Ne, jaz sem navaden idiot.
Jim Jones ::
Medtem ko ostali kandidati še spijo
Trump že v akciji
Njegovi govori so zabavni :D Pri drugih kandidatih lahko vmes 5x zaspiš pri Trumpu se vedno nekaj dogaja :D tole je bolj kot kakšna serija...
v zgornjem video pri 8:30 shots fired :))
Jim Jones ::
looool pri 11:15 samo z roko zamahne Get him the out of here :)) Kako jih meče ven kot za šalo :D
Zheegec ::
Jim Jones je izjavil:
Bi rad videl Trumpa, kako gre sam do človeka in ga vrže ven. Človek je največja reva na svetu.
Jim Jones ::
Zheegec je izjavil:
In zakaj reva? Je to mogoče naloga predsednika ta lastnoročno fizično meče ven svoje ljudi? Itak ti bi rad videl ampak potem ko bi to naredil bi pa rekel kakšen je, kaj si dovoli poglej ga kaj je naredil. Se pravi ti v nobenem primeru ne bi bilo všeč.
Sploh pa so to butaste debate zakaj sam ne gre do človeka in ga vrže ven? Lol kot, da bi jaz rekel za Bernija zakaj ne gre in vrže ven ljudi, ki mu prekinjajo govor. To so res nesmiselne debate in jih je brez veze omenjati...
dice7 ::
no, ce te pa kandidat zna nasmejati je pa po moje kar ok za predsednika najvplivnejse drzave na svetu
Škoda, da Jimmy Carr ne kandidira.
Našu:
vostok_1 ::
George Carlin for president then.
Izbiranje kandidatov na osnovi, kdo ti je bolj smešen. Gold.
vostok_1 ::
jype je izjavil:
Našu:
Se strinjam. Prostovoljne slaboumneže se zlahka pretenta.
jype je izjavil:
Našu:
jezik delovnih ljudi, ki delajo da se ta svet vrti, in ne jezik nakladačev ter političnih spletkarjev (akademske sfere pa v politiki itq ni...)
Zheegec ::
Zheegec ::
Zheegec je izjavil:
Tole je pa sveže od danes:
Wall Street Reform and Financial Policy | Bernie Sanders
Še enkrat - What a guy! Sicer drzne obljube, ampak če komu lahko uspe, potem je to Bern.
manj šteka.
Sem na polovici, pa še ni ničesar narobe povedal.
Trump bo zdaj imel podobno navdihljiv in konkreten speech, poln vsebine.. Nekako tako:
I will make America great again.
We will all live an American dream and we will all become rich.
Anyone trying to harm America or our dream, I will kill him and his family.
Free market and flat tax FTW! Regulation sucks and we all know it.
Obama is a Muslim born in Kenya!
I'm fantastic and I will do us all a tremendous service!
Whites are the Real Americans!
China is our number one Enemy. I will personally strangle them!
In množica bo vzklikala: USA, USA, USA, USA, USA, USA, USA, USA, USA!!!
  • spremenil: DarwiN ()
jype je izjavil:
ne vem ali imaš samo selektivni spomin ali je še kaj drugega hujšega...
nobeden demokrat še ni nikoli povedal nič narobe, problem je le, da jih tepe realizacija, ki je diametralna povedanem.
zdaj, za ene je to več kot sprejemljivo, za druge pač ne...
WarpedGone ::
Kaj je trump že naredu v življenju, je precej očitno.
Kaj je berni naredu iz svojega živlenja? Profesionalnega politika.
Po domače: ve kako in kaj je treba govorit, da ga množica postavi na svoja ramena.
Kako se zamenja žarnica, kolo na avto? To ni več njegova stroka.
Zbogom in hvala za vse ribe
dice7 ::
potem pa najbolje da se da en prakticni clovek na mesto predsednika namesto dejanskega politika
WarpedGone ::
"Dejanski politik" : junfer razpreda o kamasutri
