Forum » Pomoč in nasveti » Odpiranje strani Tujina
Gutjerez ::
Pozdravljeni
Nahajam se na Kosovem kjer trenutno uporabljamo Serbian Network.
Opazil sem npr da mi dveh strani noče odprt. rtvslo.si in gamedesire.com
odpira odpira a ne odpre. to pa je tudi vse kar se zgodi.
Uporablja se router znamke Tenda
Ima kdo kak nasvet kaj storiti da bi odprli ti dve strani?
Nikoli ne obupaj, saj je tukaj slo-tech
Gutjerez ::
sem šel malo do drugih sodelavcev kateri imajo druge routerje njim pa dela. torej bo problem tičal v samem routerju.
kaj pa spremeniti da bo delovalo. dat ga na defoult?
Connection Status Connected
Internet Connection Type PPPoE
WAN IP 10.100.51.28
Subnet Mask 255.255.255.255
Gateway 10.100.51.253
DNS Server 10.100.51.253
Alternate DNS Server 10.100.62.1
WAN IP 10.100.51.28
Gutjerez ::
tu pa sem sedaj od soseda kateremu odpira vse strani kopiro ven
Firmware Version:
3.16.6 Build 130529 Rel.47286n
Hardware Version:
WR740N v4 00000000
LAN
MAC Address:
C4-6E-1F-57-07-72
IP Address:
192.168.0.1
Subnet Mask:
255.255.255.0
Wireless
Wireless Radio: Enable
Name (SSID): LUKA-PC_Network
Channel: Auto (Current channel 1)
Mode: 11bgn mixed
Channel Width: Automatic
MAC Address: C4-6E-1F-57-07-72
WDS Status: Disable
WAN
MAC Address: C4-6E-1F-57-07-73
IP Address: 10.100.51.52 PPPoE(Connect Automatically)
Subnet Mask: 255.255.255.255
Default Gateway: 10.100.51.52
DNS Server: 10.100.51.253 , 10.100.62.1
Online Time: 2 day(s) 17:20:16
Traffic Statistics
Received Sent
Bytes: 1746693352 528630132
Packets: 4877423 3344411
System Up Time:
2 days 17:20:57
Firmware Version:
Hardware Version:
WR740N v4 00000000
LAN
MAC Address:
C4-6E-1F-57-07-72
IP Address:
192.168.0.1
Subnet Mask:
255.255.255.0
Wireless
Mode: 11bgn mixed
WDS Status: Disable
WAN
Traffic Statistics
Received Sent
System Up Time:
2 days 17:20:57
GTX970 ::
Zamenjaj dns strežnika z:
opendns
208.67.222.222
208.67.220.220
Kaj javita tracert in ping do omenjenih nedelujočih strani ?
Ter nslookup ?
rtvslo je drugače na:
94.103.67.4
gamedesire.com:
209.62.49.202, 209.62.49.201, 174.123.95.100, 174.123.95.101, 209.62.49.200
opendns
208.67.222.222
208.67.220.220
Ter nslookup ?
94.103.67.4
gamedesire.com:
- spremenilo: GTX970 ()
Gutjerez ::
zamenjo sem dnsje z temi kot si napiso ampak nič. to spodaj pa sem vse naredo ampak se pač nič ne razumem :D
in prilagam 8 slik z nastavitev routerja mogoče bo kdo kaj ugotovil kaj je narobe
1 http://postimg.org/image/4syd4bqgz
2 http://postimg.org/image/saonaocr3
3 http://postimg.org/image/owmku47ur
4 http://postimg.org/image/xtfmj0odb
5 http://postimg.org/image/h91in6ol7
6 http://postimg.org/image/yl6gmd7gb
7 http://postimg.org/image/4fhflqgjd
8 http://postimg.org/image/jpym474hj
in copy paste iz cmdja
http://pastebin.com/zKP48Qy4
Gutjerez ::
naj še omenim da nas je v tem prostoru 25
in kdor ima npr Linksys ali netgear router mu dela normalno. kateri pa imamo Tenda router pa imamo to težavo. torej tiči problem nekje tu. in je ta stvar rešliva.. hola browser mi spremeni pač drugi ip katero državo pač izberem. zaradi katerega spet druge strani rabijo minuto da se odprejo...
| » | Namizni računalnik in glasni ventilatorOddelek: Pomoč in nasveti | 4592 (2909) | ST-777 |
| » | USB 3.0 BRACKET ki ima drugačen izhod kot USB 2.0Oddelek: Pomoč in nasveti | 2998 (2595) | WinXP |
| » | Počasno kopiranje (strani: 1 2 )Oddelek: Pomoč in nasveti | 16126 (13540) | iloveboobz |
| » | Prenosnik Toshiba Satellite namestitev winOddelek: Pomoč in nasveti | 1005 (946) | duff |
| » | Kako telekom upravlja s svojim kablovjem?Oddelek: Pomoč in nasveti | 2443 (2237) | Goran's Blog |
