Forum » Mobilne tehnologije » Kalibracija baterije?
Pesimist ::
Ve kdo kak se na androidu kalibrira baterija? Je system restore dovol ali moram obvezno reflashat?
Sami ::
Seveda je. Tisti battery stats bullshit nič ne pomaga.
Edini proper način za kalibracijo baterije je samo to, da jo napolneš do 100% in sprazneš do 0%.
Tako bo krmilno vezje spet dobilo idejo, koliko kapacitete je še v bateriji.
Isti štos velja za praktično vse naprave, ki koristijo smart li-ion baterije.
- spremenil: iloveboobz ()
Insan3Lik3 ::
iz samijevga posta se mi tale metoda zdi smiselna:
Fully charge the battery with the phone on and when the phone is fully charged, unplug the charger and turn it off.
When your phone is off, plug it into the charger and let it charge to 100% again. The green LED light will indicate when this is done.
Next unplug the charger, turn on your phone and set the option to ensure that your screen doesn’t turn off, if you have this option. Then reconnect to the charger and wait for it to charge again to 100%.
Once loaded to 100%, unplug the charger again and do not load until the smartphone turns itself off after reaching a 0% battery level. Once off, fully charge it again and it should work properly. The screen setting can put back to normal again (meaning turn off after a certain amount of time).
NZXT s340 White | Gigabyte GA-B85-HD3 | Intel i5-4690K | Corsair Vengeance 8GB
1600MHz DDR3 | Gigabyte GTX 970 G1 Gaming | Transcend SSD SSD370, 256 GB |
Western Digital Black 1TB | Corsair CS750M 750W
Pesimist ::
pravim da ni tak simple ker sem probal 1 teden po kitikatu pa sevedno bateri procent v idle nacinu prepocasi dropa. Potem pa mi iz 75% cez noc na 8%, 5min kasneje izkloplen. Al pa med uporabo nenormalno dolgo drzi nek procent.
Koliko sem bral se ta batinfo file ustvari in ga lahko zbrisem samo z reflashom ali rootom.
Tako da bom jutri prvo probal root->delete z appom-> spraznit z videoplayingom->polnit 3h cez 100%. Tak vsaj pise v tem postopku.
tist batinfo nima nič s tem, kako ti sam android sporoča procente. Evo en člančič na xda
http://www.xda-developers.com/google-en...
pač, naredi kalibracijo 100-0%. Če ne pomaga, še enkrat ponovi vajo. Če še vedno ne pomaga, ali menjaj rom ali zamenjaj baterijo.
shadeX ::
Nebom odpiru nove teme ampak sem želel ta screenshot šerat z vami :)
Kar hočem povedat je da ni potrebno vsak teden resetirat androida da deluje :)
EDIT: Aja, telefon pa je HTC Wildfire S.
- spremenil: shadeX ()
| » | Življenska doba baterije pri prenosniku (strani: 1 2 )Oddelek: Pomoč in nasveti | 12530 (11055) | link_up |
| » | Test matičnih ploŠč - kje so clr cmos zobciOddelek: Strojna oprema | 4665 (4368) | Siddh |
| » | Še o težavah z novim iPadom (strani: 1 2 3 4 )Oddelek: Novice / Apple iPhone/iPad/iPod | 45801 (39252) | Owe- |
| » | HTC Desire HD (ali kako je Symbian uporabnik prešel na Android)Oddelek: Mobilne tehnologije | 3744 (2438) | damjan1980 |
| » | računalnik se ne bootaOddelek: Strojna oprema | 1627 (1526) | IvoJan |
