Forum » Pomoč in nasveti » XPLORE USB 3.0 64GB fornat
pino ::
Usb ključ exolore 3.o 64GB mi zazna in mi ga hoče sformatirat.
Dam format, usb ključ mi začne utripat kot da ga formatira na koncu pa izpiše
A je fuč ključ in ga vržem v smeti, ali je še kakšna možnost.
LP Pino
GTX970 ::
Prvo naredi to:
https://slo-tech.com/forum/t634787/p469...
- spremenilo: GTX970 ()
pino ::
Vrglo tole:
Description: [F:]USB Mass Storage Device(SMI USB DISK)
Device Type: Mass Storage Device
Current Speed: High Speed
Max Current: 300mA
USB Device ID: VID = 090C PID = 1000
Serial Number: AA00000000011941
Device Vendor: SMI Corporation
Device Name: USB DISK
Device Revision: 1100
Manufacturer: SMI
Product Model: USB DISK
Product Revision: 1100
Controller Vendor: SMI
Controller Part-Number: SM3267AB - ISP 140429-1AB
Flash ID code: 2C84643C - Micron MT29F512G08CMCAB - 4CE/Single Channel [MLC-16K] -> Total Capacity = 64GB
Tools on web: http://dl.mydigit.net/special/up/smi.ht...
Possible Flash Part-Number
[1CE]MT29F128G08CBCAB x 4 pcs/Channel x 1 Channel
[1CE]MT29F128G08CBEBB x 4 pcs/Channel x 1 Channel
[2CE]MT29F256G08CECAB x 2 pcs/Channel x 1 Channel
[4CE]MT29F512G08CMCAB x 1 pcs/Channel x 1 Channel
Flash ID mapping table
[Channel 0] [Channel 1]
2C84643CA500 --------
-------- 400140024004
4008FFFFFFFF --------
Max Current: 300mA
Manufacturer: SMI
LP Pino
| » | USB ključ prepozna kot DVD/CD ROM enotoOddelek: Pomoč in nasveti | 3329 (3148) | iloveboobz |
| » | Formatiranje USB-jaOddelek: Pomoč in nasveti | 2246 (2174) | iloveboobz |
| » | ADATA S102 Pro 64 GB USB 3.0Oddelek: Strojna oprema | 1921 (1651) | Han |
| » | Usb iz 32gb na 15 gb??Oddelek: Pomoč in nasveti | 2127 (1925) | Dr_M |
| » | usb storage lockedOddelek: Strojna oprema | 1211 (1157) | All |
