Forum » Strojna oprema » AMD Radeon R9 400 Series
tiborrr ::
Ma kakšni power issue, bože sačuvaj. Dandanes ljudje očitno res palijo samo še na paničarjenje in dramo. Vsaka tretja PCIe kartica na trgu ne bi smela dobiti certifikata, ker prekoračuje porabo iz PCIe konektorja.
Pa sploh veste, koliko zdrži ta konektor na dolgi rok? 13A, to je 156W!
Koliko 6-pinski PCIe? 17A, torej 204W.
Svašta p%$ka rodi, ali para neče.
Virjan ::
Sem vceraj bral en clanek..eni nemci so jo menda undervoltali in dosegli 150W nizje temp, bolsji performance,
zgleda, da jo je AMD prevec gnal.
tiborrr ::
iloveboobz je izjavil:
hja, vprašanje če tudi zdrži tak dolg na plati za 45e
Čakaj, ti se tako malo neumnega delaš ali samo trollaš?
Na platah za napajanje PCIe rež ni nobenega napetostnega pretvornika, napaja se direktno iz +12V, torej je vseeno, kako zanič je plata. Na plati za 300e in na plati za 45e do tja vodi isto število enako širokih traceov. Konektor je šibki spoj električne povezave!
NightHawk ::
Tole je iz Tomshardware. Je potem to problem ali ne?
AMD's Radeon RX 480 draws an average of 164W, which exceeds the company's target TDP. And it gets worse. The load distribution works out in a way that has the card draw 86W through the motherboard's PCIe slot. Not only does this exceed the 75W ceiling we typically associate with a 16-lane slot, but that 75W limit covers several rails combined and not just this one interface.
With peaks of up to 155W, we have to be thankful they're brief, and not putting the motherboard in any immediate danger. However, the audio subsystems on cheaper platforms will have a hard time dealing with them. This means that the "you can hear what you see" effect will be in full force during load changes; activities like scrolling may very well result in audible artifacts.
We're also left to wonder what we'd see from a CrossFire configuration. Two graphics cards would draw 160W via the motherboard's 24-pin connector; that's a tall order. Switching from the bars back to a more detailed curve makes this even more evident.
tiborrr ::
Tip kvasi bedarije. Vsak rail mora dobiti 75W, tako x1 mehanski in električni slot kot x16 slot.
EDIT: Vsak rail na plati, nič ni to 'skupno'.
- spremenil: tiborrr ()
Napajalc ::
Če bi na 75w porabe na povezavah do pcie na plati žarele bi dodatnih 11w spremenilo barvo žarenja, ampak temu ni tako.
011011100111010101100010
NightHawk ::
Napajalc ::
70W razlike pr skor istem performancu med 28nm in 14nm, tle se ni nicesar za hvalit.
1070 pa je 16nm in porab samo 40W vec potemtakem in je konkretno hitrejsa, brez PCI-E komplikacij.
gtx 1070 je preveč obrezana, to ji bo rapidno padal performence v bodočih igrah napram starejšim/novejšim mišičnjakom.
petrus ::
tiborrr: Kateri procesor bi ti priporočal za v kombinacijo z 480tko/1080p gaming? Obstaja perfect budget match, nekaj kar ne bottlenecka in da tudi nima rezerve?
stati inu obstati
Hydros ::
Blazz ::
tiborrr ::
Jaz bi zmontiral najcenejšo Z170 ploščo, ki podpira navijanje zaklenjenih čipov in en Core i3:
- ASUS: http://overclocking.guide/asus-z170-non...
- MSI: http://overclocking.guide/msi-z170-non-...
Recimo Core i3-6098P (ki ima slabšo integrirano grafično). Brez težav prisopihaš na vsaj 4.3-4.5GHz, tako da bo računalnik sigurno imel še kaj rezerve za prihodnje. Če se stegneš višje, je pa že bolje vzeti i5 6400.
To je en tak budžet nasvet z moje strani za vsakogar, v katerem tiči malo navijalca:
- CPU: 120 (i3) oz. 180EUR (i5)
- MB: okoli 100-120EUR
- RAM: 2x8GB HX421C14FB2K2/16 (odličen OC ram, default 2133 C14, gre krepko čez 3200) - cca. 70EUR
M-XXXX ::
Grey ::
Tule imaš primerjavo procesorjev na 1080p...tako na oko bi rekel, da je Athlon II X4 880K trenutno in za naslednjih nekaj let zelo dobra izbira za budget gaming procesor.
AMD Athlon II X4 880K (Wraith) = 81.84€
V večini iger je zelo soliden mid range rezultat.
- spremenilo: Grey ()
tiborrr ::
Tudi to je dobra izbira, da, seveda ob predpostavki, da se dobi sistem za takšno ceno.
Leprechaun ::
Prosim, ne uporabljat beseda bottleneck, ker je to še ena izmed neumnih domislic kavbojev. Samo v "idealnih" scenarijih boš imel CPU 100% in GPU 100% load. Ciljaš najverjetneje na kar se da dober izkoristek GPU-ja vsaj za igre, čeprav so nekatere igre npr. Total War ipd. bolj odvisne od CPU.
Drugače pa kot je rekel Tiborrr i3 6100, 6300, 6098P... i5 6400.
Tiborrr se ti čipi še dajo navijat? Ali je pred tem potreben kak flash na starejšo BIOS verzijo?
tiborrr ::
Preberi linke, ki sem jih podal višje. V grobem - da, treba je flashati specialen BIOS. Slabosti:
- The missing power-management will not allow to read out any core temperature. However, you can read-out the package temperature with the tool HWInfo (make sure to stay below 70°C package temperature)
- No C-States. CPUs will always run full speed and full voltage.
- No Turbo-Mode.
- No iGPU.
- Intel AVX is screwed. Some benchmarks like Intel XTU use AVX and you will have about 4-5 times lower score. As far as I know no game is using AVX so it’s no problem to use this for gaming rigs. Not suitable for professional usage tho.
- Avoid high memory clocks. Everything around 2600 MHz will be fine.
Ni panike, kot je tiborrr omenil.
AIB bo dobil specifičen BIOS in custom rešitve.
Source pls. Dvomim, da ima najcenejša in najdražja plata enako široke trace za napajanje. Aferall, rabi najcenejša plata zdraž samo 75W in niti W več.
Athlon je najslabša možna izbira za gaming ?
Zakaj ? Bodo povedali tisti, ki so šaltali z FX8 na i5.
Za gaming vzameš i5 in najcenejšo spodobno plato (kakšno navijanje neki z i3, to je bedarija. En bios updejt ali microsode update pa je konec špasa).
https://www.mindfactory.de/shopping_car...
- spremenil: iloveboobz ()
- No Turbo-Mode.
- No iGPU.
pa še ena slabost. Tole zadevo lahko intel BP ubije z microcode updejtom. Samo enkrat pržgeš komp po windows updejtih in baam, bsod :)
https://www.techpowerup.com/forums/thre...
Senitel ::
Sem že za "async compute" rekel, da bi NV morala izdat driver, ki bi 50% SM-ov rezerviral za compute in 50% za grafiko na Maxwellu. Izključno zaradi retardov, ki padajo na "omg async boost!!111oneone".
Bom moral isto dodat še za DX11 driverje. Očitno mora NV pripeljat nazaj pre Mantle DX11 driverje. Spet izključno zaradi retardov, ki padajo na "omg DX12 boost!!!1111oneoneone".
Ker ja 1+1 se v DX12 izračuna bistveno hitreje kot v DX11.
Torej, da potegnemo črto. Za vse je kriv AMD.![]()
Od kje nekateri to razberete ej... NV DX11 driver je hitrejši od AMD-jevga. To je fact, ki se ga je lepo demonstriral leta nazaj ob prvih Ashes of Singularity demotih, ko je AMD začel mahat z Mantle, NV je pa samo izdala updatean DX11 driver (pa že prej je bil njihov driver hitrejši).
Ta hitrost driverja v igrah tipično ni problem, ker so bili developerji že od samega začetka navajeni delat okrog tega (~5000 Draw klicev na frame, kar se je skozi leta potem počasi dvigovalo). Oxide je nad tem enostavno popizdil in začela se je vsa galama okrog Ashes of Singularity. V tech demotu je Mantle bil super in fajn, DX11 je pa praktično pokleknil, dokler ni NV popravila svojih driverjev. Na AMD-ju pa DX11 še danes poklekne.
In sedaj je to vsesplošen primer kako AMD profitira v DX12, ker se frame rate praktično podvoji in na tem enem primeru je zdej en kup folka zgubilo glavo. DX12 ne prinaša čisto ničesar, kar bi GPU-jem zmanjšalo delo. Vsi feature-ji so bili portani nazaj na DX11 (DX11.3 ima feature level 12_1 za DX11 interface) in NV na Pascalu dela tudi "async compute" v DX11.
Kar ni bilo portano nazaj v DX11 so vse arhitekturne spremembe znotraj DX-a in spremembe, ki jih to potegne za sabo v driverjih, binding model itd. Skratka stvari, ki prihranijo tono CPU časa v driverjih.
Ampak folk zgleda doživlja orgazme takoj, ko vidi nek performance gain in jih potem vse kri uide iz betice, da bi se sploh vprašali od kje ta gain pride.
tiborrr ::
Kaj ti naj sourcam? Poglej si kak design guide za posamezno platformo (je javno dostopno), drugače pa imaš PCI-SIG design guide za PEG gen3 tudi, kjer je jasno popisano, da vsak od PCIe slotov na plošči mora zagotavljati maksimalno moč po standardu. Štrije sloti na mATX plati? 4x maksimalna moč! Nihče ne dela 'širših' ali 'ožjih' traceov, ker - še enkrat - ni omejitev bakrena povezava na pertinaksu ampak fizični konektor!
To, v kar ti dvomiš, je pa na žalost problem tvoje zveličavosti. Res misliš, da se plate delajo 'iz nule' ali se začne redesign glede na referenčni dizajn, ki ga pošlje Intel oziroma AMD. To je retorično vprašanje, da ne boš slučajno odgovarjal...
Hmm, moje zveličanje, ker podvomim v sklicovanje lastne avtoritete ? Oz. nasploh trditve brez kakršnih koli virov ?
Kam je ta forum padel..
tiborrr ::
Ni moja naloga, da iščem nekemu adolescentnežu vire. Iznajdljiv si zadosti, najdi si jih sam. Sam vem, o čem govorim, ker sem pač že dizajniral razširitveno kartico formata PEG. Ti pa po želji.
Truga ::
Tocno to. Meni referencna 980Ti (kao 250W karta) vlece ~420W na max overclocku. Ze na stock nastavitvah zna vlect preko 80W iz motherboarda. OCjana verjetno >100.
PC mi se vedno dela bp.
In zaradi takih in podobni postov temu forumi pada kvaliteta z vsakim letom. Vsi bi se najraje sklicovali na lastno avtoriteto (super, imaš izkušnje z dizajniranjem, ampak to nekomu na drugi strani nič ne pomeni, ker na internetih si lahko vse), izpodbijali vire na podlagi whoknows what.
In potem nastane tema ena velika greznica postov, ki imajo vrednost =0.
Truga ::
http://www.tomshardware.com/reviews/gef...
Pa se 750Ti, do 140W iz pcie. Nisem se za nobenga slisal da bi se mu motherboard stopil, pa je to najbolj budget maxwell, ki gre verjetno na najbolj budget motherboarde...
tiborrr ::
@Truga: Točno o tem govorim.
@hojnikb: Mislim, da nisi pravi za polaganje računov. Poglej svoje poste v teh temah, 90% je nabijanje brez prakse, manjko prakse pa nadomeščanjem z neusahljivim (selektivnim) iskanjem virov, ki potrjujejo tvoja prepričanja (prepričanja, ne realno stanje).
Nisi edini, si pa del problema, tako da se prosim vzdrži moraliziranja te vrste.
Sicer pa, kdo je brez greha naj prvi vrže kamen...
P.S.:
Predlagam vrnitev na temo.
P.S.:
To be clear, your motherboard isn't going to catch fire. But standards exist for a reason. All of the components around the PCIe slot and along the path from the slot to the 24-pin ATX connector will suffer from the peaks. And depending on your platform's design, audio problems may also materialize.
Še najbolj relavanten izsek celga #powergeta za povprečnega janeza.
Itk pa, #powergate gor ali dol, vsak z vsaj kančka zdrave pameti bo kupil nereferenčno karto. Tole pa pustil neučakanim in tistim, ki bodo kupl vodne bloke :)
FX6300B ::
če mene prašaš je pomoje glede tega 6-pinskega priklopa malo pretirano, ker taki retardi pa tudi niso da bodo naredli kartico ki funkcionira potem pa ji dajo prešvoh priključek, ali pač
May the force be with you!
Napajalc ::
Tebi se ne sanja nič o izdelavi PCB, a veš da je širši trace ceneje za izdelavo, pa če PCB ne stripamo je še ceneje, to oboje pomeni večji tok na trace in cenejšo izdelavo.
damirez ::
Nereferncne z boljšim hladilnikom in 2x priključkom za štrom ter 2-3 vente bodo boljše.
Kolko boljše?
Od 1480mhz - 1600 mhz in več.
Must buy!
Kolko boljše?
Must buy!
Napajalc ::
Verjetno bo p/p ostal na izbolšanih verzijah, več denarja več muzike kot ponavadi.
P.S.:
hojko ne trudi se. Niko je v drugi ligi.
SimplyMiha ::
Are two RX 480s faster than a single GTX 1080?
Avtor pravi, da ne. A glede na grafe je več kot očitno, da sta dve RX 480 v Crossfire primerjivi s GTX 1080:
Dve $200 grafi proti eni $600. Če prezremo dvojno obremenitev, to niti ni tako slaba kupčija.
Potem se pa zbudiš v realni svet in vidiš tole
Tudi v igrah, ki cfw dober skalira, je performance še vedno slabši kot ena 1080.
Da o porabi takega setupa nebi...
Na koncu dneva ugotoviš, da je bolje vzet eno 1070 in jo navit. Cenovno bo tam tam (zavoljo fer primerjave damo tukaj noter x2 480 8GB)
CF je ok, dokler in kjer dela super. To je kot kupiti cel zaboj krofov od katerih je v samo 70% marmelada. Za nekaj malega denarja več, pa lahko kupiš zaboj, kjer je marmelada definitvno v vseh krofih.
Če daš že 500eur za CF in nimaš nikoli enako skaliranega performensa v vseh igrah, plus nešteto problemov, je dodati še 100 za 1080 kar smiselna odločitev.
- spremenil: Machete ()
Ne, retardi defenitivno niso, ker je pcb zlo dober zasnovan..
Kartica je zelo majhna, tako da se lah zgodi, da bosta gor dva čipa v prihodnosti. Z porabo tam okoli 270w bi bla to tombola. To da mal popeglajo...to porabo.
Nekej v tem smislu.
http://www.guru3d.com/index.php?ct=news...
- spremenilo: Telbanc ()
Hydros ::
Nekej v tem smislu.
Pomoje direkt od AMD ne bo mogoče bo naredu PowerColor oni so znani po tem
http://videocardz.com/61404/powercolor-...
Neki takga recimo http://wccftech.com/powercolor-launches...
Od AMDja se lahko pričakuje samo rx 490 z dvema čipoma tako kot r9 295x2 al pa Pro duo
- spremenilo: Hydros ()
mah zakaj bi mel 2 rx480 na enem pcbju, če maš enojederno 1070/1080 z podobnim performancom pa pol manjšo porabo ??
Nerazumem folka, ki se hoče načrtno zaklat z crossfire. Ok štekam da maš topend grafiko in hočeš še več. Da bi pa dve mindrangarki skup tiščal...
M-XXXX ::
Kot prvo ni pol manjša poraba kot drugo je konkretno višja cena.
Briga mene poraba, če to na letnem nivoju prinese 10€ razlike pri 200€ nabavne razlike.
Hydros ::
ni fora v porabi fora je v tem da cross fire ni optimiziran za vse igrce sploh z novimi igrcami je tako da je treba počakat na driverje pa update
Konkretno višja cena ? Tudi če odmisliš premium ki bi ga prinesu tak setup, bi ob ceni x2 RX480 8GB stala stvar cirka ~500€
1070ko maš z custom hladilnikom za 470e. Pa nobene jebe z dual gpu setupom.
