Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
https://www.amd.com/en/support/chipsets...
Release Highlights
General system stability improvements.
Fixed Issues
The chipset installer .exe help switch is enabled with the command line installation instructions.
AMD Ryzen Power Plan /
AMD Processor Power Management Support
6.0.0.9
Updated Ryzen™ 7 desktop setting to support power slider and quiescent mode
Updated Ryzen™ 7 mobile slider setting for Better Battery and Better Performance
AMD PCI Device Driver
1.0.0.82 Bug fixes
AMD I2C Driver
1.2.0.117
Fixed the Synchronization when there is a delay
Robust Error Handling in case of ghost interrupt
AMD UART Driver
1.2.0.112
No Change
AMD GPIO2 Driver
2.2.0.130
No Change
PT GPIO Driver
2.0.1.0
No Change
AMD PSP Driver
4.13.0.0
No Change
AMD IOV Driver
1.2.0.52 New device ID support added
AMD SMBUS Driver
5.12.0.38
No Change
AMD AS4 ACPI Driver
1.2.0.46
No Change
AMD SFH I2C Driver
1.0.0.86
No Change
AMD USB Filter Driver
2.1.11.304
No Change
AMD SFH Driver
1.0.0.313 Human Object Detection (HOD) feature added
AMD CIR Driver
3.2.4.135
No Change
AMD MicroPEP Driver
1.0.28.0
No Change
Release Highlights
Fixed Issues
6.0.0.9
1.0.0.82 Bug fixes
AMD I2C Driver
1.2.0.117
AMD UART Driver
1.2.0.112
No Change
AMD GPIO2 Driver
2.2.0.130
No Change
PT GPIO Driver
2.0.1.0
No Change
AMD PSP Driver
4.13.0.0
No Change
AMD IOV Driver
AMD SMBUS Driver
5.12.0.38
No Change
AMD AS4 ACPI Driver
1.2.0.46
No Change
AMD SFH I2C Driver
1.0.0.86
No Change
2.1.11.304
No Change
AMD SFH Driver
AMD CIR Driver
3.2.4.135
No Change
AMD MicroPEP Driver
1.0.28.0
No Change
globoko grlo ::
AMD plato zih ne, na kkšno B320 tega verjetno ne gre dajat.
HU testi kažejo, da je R9 5950X najboljši gaming procesor od celotne četverice, začenši z 5600X. Za opazne razlike pri meritvah pa je po navadi potrebno znižati grafične nastavitve.
Ni slabo, razen cene.
Bwaze6 ::
Eh, znižati je potrebno grafične nastavitve v 1080p z RTX 3090, da je sploh opazna razlika med 5600X in 5950X - pa še to le nekaj odstotkov v povprečju. Iz tega potegniti povzetek, da je "R9 5950X najboljši gaming procesor" je precej poenostavljeno.
globoko grlo ::
Najboljši Ryzen proc za gejming pač je, ima največ FPSjev, pa če se na glavo postaviš. Zdej, a se splača, je pa druga stvar, ane :)
Lahko, da je hitrejši za par procentoc. Ampak da bi ga pa kdo kupoval za igranje iger pa priča o izjemnem mentalnem deficitu dotičnega kupca.
Mislim da v tej temi so bile opazke, da je R9 5950X zaradi nižjih all-core boost frekvenc malce slabši za igranje iger od recimo R7 5800X oziroma R9 5900X. Nekaj v tem smislu, da če se hoče kdo metati ven tudi v gamingu, mu lahko to s 16 jedrnikom odlično uspe.
Baje imajo novi Ryzeni v povezavi s PCIE 4.0 grafično velik težave z USB napravami, ki se neprestano odklapljajo. In baje za zdaj ni nobene rešitve, nekateri upajo na BIOS popravke, ampak se dogaja z več matičnimi, tako da je najbrž kriv sam procesor oz. zasnova chipseta.
Je milijone zadetkov na to temo, primer:
https://www.reddit.com/r/Amd/comments/l...
Težava je omejena na nekaj plošč, ki imajo četvorček usb gen2 priklopov skupaj v vrsti, torej Asus B550-E in še nekaj modelov.
globoko grlo ::
Ampak, da je 10400F pri FT 144 ojrov, pa je v špilih praktično enak 5600x, si pa tut ne bi mislil :)
globoko grlo je izjavil:
Povdarek prakticno, pri 1500€ kartici bos sparal na porabi z i5.
PrimozR ::
Kdo pa je rekel karkoli o porabi in 1500 € kartici?
Pa kakorkoli obrneš, 200 € razlike, torej lahko za kartico vržeš 1700 € :P
A to resno? Potem dejansko ni potrebe po par sto evrov dražjem procesorju, če se mi gre samo za igričarstvo?
KAVINSKY ::
Razlik ni, če je najšibkejši člen grafična kartica. Pri 1440p in 4K bo že RTX 3000 ali RX6000 na polno obremenjena, procesorja pa bosta zehala.
Če pa igraš na 1080p, se že zna zgoditi, da se bodo kazale razlike med procesorji (če imaš dovolj močno grafično). i5 10400 ima tudi to cako, da moraš kupiti Z490 matično, da podpira ram na 3000mhz, sicer si omejen na 2666mhz. Kar se tudi lahko že pozna na performansu.
Je pa 5600 300€+, 10400F je pod 150€. Pa ni dvokratne razlike v zmogljivosti. Privarčevano pri procesorju daš v najcenejšo Z490 matično, ostalo pa v grafično (ko bodo na voljo).
XS!D3 ::
Odvisno od igre. Flight Simulator 2020 tudi pri 4K ter detajlni med high in ultra z RTX3080 na 5800X zakucava posamezno jedro, kjer teče glavna nit.
https://ark.intel.com/content/www/us/en...
Tukaj je pod Memory Types navedeno zgolj DDR4-2666.
KAVINSKY ::
Ja, neuradno pa podpira tudi višje frekvence na Z seriji chipsetov. Podobno kot power limit profili pri proizvajalcih matičnih plošč.
Tukaj so testirali z 2666 in 3200 rami na isti matični.
https://www.techspot.com/review/2032-in...
Bwaze6 ::
Bolj kot kaj? Sonce? Ne. 3800X? Ja. 5900X, 5600X? Tudi.
To so izpostavili tako v recenzijah kot uporabniki na forumih. Chiplet je majhen in visoko navit, zaradi majhne površine je z njega težko odvajati toploto (čeprav sama poraba ni ekstremna).
Buggy ::
Je že kdo opazil?
..ce si mislil pa na to da imas na B450 z zadnjim beta BIOS-om omogoceno PCIE Gen4 je pa res cudno, ker jaz na Aorus X470 ultra gaming z isto verzijo BIOS-a tega nimam na voljo niti za izbrat v BIOS-u, kjer je Gen3 max, na AUTO pa je prikazan Gen3, res pa je da nimam Gen4 graficne kartice vtaknjene v plato pa mi CPUZ za "Bus. Spec" prikaze isto kot tebi, za grafo pa GEN3. Ker GPU imas?
Lahko ti samo narobe prikazuje lahko da je na tvoji plati (trenutno) to celo omogoceno, ker je bil svoj cas omogoceno tudi na moji plati pa so potem ven vrgli podoro.
Edino kar ti preostane je, da naredis nekaj testov...Gen3 vs Gen4... za test uporabi CS:GO, kjer se najbolj pozna razlika in porocas ;)
- spremenil: Buggy ()
XS!D3 ::
Ima kdo tule 5800x? Kakšne so kaj temperature? Sem zasledil, da se bolj greje.
Imam, ja, pod polno mutlicore obremenitvijo gredo kar visoko, ampak naj bi bilo "normalno". Nekaj več sem pisal že v tej temi.
Na 5600X/5900X naj bi bilo boljše zaradi manjšega števila jeder na čipletu (poleg tega uporabijo boljših 6 jeder od 8ih, ki sta na čipu), za 5950X pa menda izbirajo res najboljše čiplete, ki laufajajo na nekoliko nižjih voltažah. Vseeno pa tudi 5800X ne generira neke grozne količine toplote in lahko AIO laufam na relativno nizkih obratih, ker praktično ni razlike, če dam ventilatorje in pumpo na max, saj je problem prenosa toplote že iz samega chipleta.
s1m0n ::
Aha torej ima en sam čiplet na voljo pol vseh 105W. No ja saj pol bi pričakoval da se malo bolj greje. Kje kaj spremljate temp? Ker meni HWMonitor in OCCT sporočata različno.
s1m0n ::
HWMonitor mi sporoča samo za package (node 0)...
V mirovanju (idle) se mi giblje med 30-35 °C (sobna temp je 21°C) v loadu vsa jedra na 100% po 15min je bilo maks 63 °C (pri 4.750MHz na vseh jedrih / občasno na 4.840MHz)
OCCT pravi za sam CPU malo drugače 72 °C (maks) za CPU die...
Pri graphic interface ti piše pci-e 3.0, samo zgoraj ti piše 4.0.
- spremenil: mtosev ()
PrimozR ::
Motherboard bus specs je 4.0 za oba, Graphics link je 4.0 v enem, 3.0 v drugem primeru. Kar verjetno pomeni, da grafična kartica podpira samo PCIe 3.0.
- spremenil: PrimozR ()
Maš pa starejši bios, ker najnovejši je 5837.
Bwaze6 ::
AMD Ryzen 5000 'Zen 3' Desktop CPUs & X570 Motherboards Have High Failure Rates, Reports PowerGPU
Sicer o tem poročajo prodajalci in sestavljavci z relativno malo prodanimi procesorji, a gre vseeno za visoke odstotke okvarjenih produktov.
Na forumih sem tudi zasledil uporabnike z Zen 3, ki v bistvu ne dosegajo benchmarkov v recenzijah, razlika pa ni majhna - ljudje jih običajno menjajo. Ali procesorji, ki že v stock konfiguraciji niso stabilni ter kažejo WHEA errors. Marsikje pa takšnih vračil ne sprejemajo oz. pri vračilu zaračunavajo restocking - procesor "deluje", težava bi lahko bila tudi v matični, biosu, spominu...
Horas ::
pooryzen, smo že vedeli ja.
8700k+z390, 32gb 3600mhz, 1080ti, 700w gold, 512gb+2x250gb m.2 nvme + 2tb hdd
8500+b360, 32gb 2666mhz, rx 6600, 600w bronze, 512gb+250gb ssd m.2 + 2tb hdd
- predlagalo izbris: klinker ()
Bwaze6 ::
Je pa bizarno, da poročila o tako visokih odstotkih DOA izdelov prihajajo le od dveh majhnih prodajalcev. Kaj pa večji? Decembra 2020 je npr. Mindfactory prodal 40.000 AMD procesorjev. Si predstavljate, da bi dobili 8000 okvarjenih procesorjev za menjavo v enem mesecu?
Si je skoraj lažje predstavljati, da nekdo pri malem sestavljalcu ni prebral navodil, in nekaj počel močno narobe. Tlačil procesorje narobe v socket?
https://www.mindfactory.de/product_info...
RMA z mindfactory za R9 5900X je po njihovih navedbah ob 2980 prodanih procesorjih 0.37%.
RMA za 5800X pa ob preko 10000 prodanih primerkih 0.57%.
Za primerjavo, RMA za 3900X (30000 prodanih procesorjev) je približno 1%.
Morda so pri teh malih sestavljalcih dobili ponedeljkove procesorje, ko so bili delavci v livarnah še z glavo na vikend dopustu.
Pri 7 minutah, je zanimivo.... Primerjajo pač samo amd... 3600x vs 5600x
Senior Dev ::
Cene so napihnjene čisto preveč ker je malo kosov na voljo. Čez kakšno leto, dve, hop na 5950X za 500€.
PrimozR ::
Senior Dev je izjavil:
Takrat bo vreden še kakih 200 €, če bo nov. Čez leto, dve boš lahko kupil 6950X oz. 7950X, oba na DDR5 RAMu.
Rias Gremory ::
Seniorja z rezervo jemljite no, trola ko pes teče.
Pretiravati ni potrebno, še zen+ R5 2600x je okoli 155-170€ že precej časa in so jih tudi v zadnjem času precej prodali / razprodali.
R9 5950X bo držal solidno ceno, dokler ga ne bo zmanjkalo, ker ga bo zmanjkalo.
Bwaze6 ::
Mining farmi ne rabijo ravno močnih procesorjev, vse tole povpraševanje po Ryzen 5000 je dejansko od entuzijastov.
Tako da bi zlom kripta omogočil več gamerjem dostop do grafične kartice - vsaj rabljene, če bodo že trgovine kar vztrajale pri astronomskih cenah še mesece zatem, tako kot v 2018 - posledično bo potreba po novih procesorjih še višja.
