AMD ZEN - nova X86 Jedra
tony1 ::
D3m je izjavil:
Hardware Unboxed:
If that's the Godlike motherboard you got in the review kit, get a retail board Jay. The review version was pre-production and does have issues which have been fixed with the retail version, it you have the little blue diagnostic pins on the rear side of the board it's pre-production.
Also AMD's come out and clearly stated that the working voltage for Zen 2 is 0.2v - 1.5v, so up to 1.5v is perfectly fine. I'm not sure why everyone assumes the voltage parameters for a new process node that we've never used before.
Če mora nekdo producirati take bruke gre Intlu res za nohte. Očitno še 5 let AMD ne bo imel nobene konkurence... :))
tikitoki je izjavil:
Dr_M je izjavil:
Stvari SE premikajo na bolje, ampak ce bi intel naredil tak flop bi ga ze zazgali na grmadi :))
Ryzen 1000 je brez veze, to je tako, kot bi sel kupit novega haswella.
Spomin zlate ribice? Intel je že precej večje flope postregel.
Niti ne. So imel par malenkosti, ki so jih zelo hitro resili. Pri amdju traja ze 3 mesece, pa imajo se vedno zelo veliko dela.
Neumnost. Intelu gre za nohte samo zaradi 10nm procesa. Arhitekturo imajo na zalogi, da bi amd povozil po dolgem in pocez, samo imajo to nesreco s proiuvodnjo. Zato je tudi amd navil cene v nebo, 200e procesorje prodajajo po 400e in take smehe...
  • spremenil: Dr_M ()
Bwaze6 ::
AMD Confirms: Ryzen 9 3950X and Threadripper 3rd Generation Coming in November
Hi Everyone,
We are focusing on meeting the strong demand for our 3rd generation AMD Ryzen processors in the market and now plan to launch both the AMD Ryzen 9 3950X and initial members of the 3rd Gen AMD Ryzen Threadripper processor family in volume this November. We are confident that when enthusiasts get their hands on the world’s first 16-core mainstream desktop processor and our next-generation of high-end desktop processors, the wait will be well worth it.
Thank you
AMD Corporate
Fino za Threadripperje, ampak zamudo 3950X bi pa lahko malce bolj taktno sporočili, glede na to da je kar nekaj ljudi zdaj čakalo z nakupom novega sistema, da vidijo benchmarke 3950X v primerjavi s 3900X...
  • spremenilo: Bwaze6 ()
Ne vem, če sem prav razumel.
Ali hočejo povedati, da je najcenejši TR3 24 core?
  • spremenil: D3m ()
FlyingBee ::
Saj lepo piše premiera z 24c. 16c bo pa top Ryzen.
Me prav zanima kdaj bo dejansko 4.7ghz boost pri 3950x.
Zanima me ali bo tudi manj, kot 24 core.
Oz. lahko predpostavljam, da bo 3950x max kar bodo ponudili za X570 ter vstopni 24 core TR za TR4 plate.
  • spremenil: D3m ()
Bwaze6 ::
Fixed it for you!
Boost clock je bolj okrasen, procesor bo tudi enojedrne aplikacije izvajal s podobno frekvenco kot v bistvu vsi Ryzen 3000 procesorji (4.2 - 4.3 GHz).
Za dosego TDP moraš izklopiti Precision Boost 2, kar tudi zniža dosegljive frekvence. Torej ni podan v stock konfiguraciji.
Očitno ne bo na voljo septembra. So sporočili konec septembra.
Če sedaj pogledaš ceno 3900X v evropskih trgovinah, ki jih imajo na zalogi ali jih lahko pošljejo v naslednjih nekaj dneh, je najcenejši 660 EUR. Pa je skoraj 3 mesece od izida. Tako da dvomim, da bo 3950X sploh letos na voljo v kakršnem koli številu.
To si pa hitro popravil.
Še malo. :)
Dr_M je izjavil:
Dr_M je izjavil:
Zlata ribice, dej si mal preberi o flopih pri INTELu. Celo tolk hudo so bili, da so morali CPUje odpoklicat, bolj hudo sploh ne mores zajebat:).
Da o ranljivostih sploh ne govorimo.
tony1 ::
Dr_M je izjavil:
Dr_M je izjavil:
Za razliko od nekaterih mlečnozobcev se jaz še spomnim časov 90 megaherčnega pentiuma (ki je bil svinjsko drag) in kako je okenski kalkulator na njem izpisal rezultat: divide overflow.
Kere bruke.
In, ja, da dodatnega ringa z Minixom, OSom, ki ni bil nikoli mišljen za nobeno sorto produkcije, v vseh Intlovih procih, niti ne omenjam.
Že samo to je zrelo za milijardne tožbe. :D
  • spremenil: tony1 ()
klinker ::
FireSnake je izjavil:
Jaz imam serijo 3000 in ne vem, o kakšni (ne)zansljivosti vi govorite.
Vam je jasen pojem zanesljivega sistema?
Beri kar pisem. Ti imas star chipset, ne pa X570.
In ja, sistem, ki se ne obnasa kot bi se mogu, ni zanesljiv sistem. V tem pogledu je 4xx + Ryzen 2xxx precej boljsi nakup.
In ne, iskal sem taboljse plate za Zen2, vrglo mi je pa ven bolj kot ne same tezave in neke bedne review-je.
Na vase primerjave z Intelom se pa polulam, ker me Intel ne zanima, pa tudi omenjal ga nikjer nisem.
  • spremenilo: klinker ()
FlyingBee ::
Intel je na potezi, stare grehe smo že obema odpustili.
klinker je izjavil:
Poleg ostalega, ko niti omembe ni vredno ... se poslušaš ti?
1% skače zmogljivost gor/dol (ob BIOS nadgradnjah) ti pa tu moraliziraš ko stara oma.
Ohladi se malo.
Še enkrat: ni ti jasen pojem zanesljivega sistema.
Ryzen serije 3000 lahko goniš kolikor ti paše. Zadeva je zanesljiva/stabilna.
Vi pa tu pičkarite kot, da je vsakih 5 sekund reset.
  • spremenilo: FireSnake ()
FlyingBee ::
Tokrat dajem FireSnake-u prav, čeprav je še vedno pi*kica, ki je zamenjal 2700x za 3700x in ne neha tečnariti po tem forumu, kot, da je z nakupom 3700x rešil svet.
bajsibajsi ::
DarwiN je izjavil:
D3m je izjavil:
V bistvu je hitrost sedaj cca. 20%, če računamo še boost fix.
Ampak 20% ni praktično nič.. That's the whole point. Kot bi prodal 5dc kozarec in kupil 6dc kozarec... Pivo boš enako spil z enim in drugim, a ne..
Super primerjava.
Razen tistih, ki dejansko vedo cemu nadgraditi/kupiti nov PC, se je za vse (nas) preostale, ki smo v vecini, preprosto vprasati zakaj kupimo nov PC, kljub temu, da stari se zadovoljivo deluje. Torej, zakaj kupimo nov PC? Ker lahko! V resnici pa pogosto neke prave potrebe ni.
Videti je, da je precej profesionalcev, ki potrebujejo 12, in vec, jedr za hitrejse objavljanje nesmislov na ST.
klinker ::
klinker je izjavil:
Ohladi se malo.
Ne lapaj. Ce komu tu ni jasen pojem zanesljivega sistema, si to vec kot ocitno ti, pa nisi edini kot vidim ;)
Tole je bilo pa čisto po mariborsko. Bravo! Bolj patetično res ne gre.
Ko ti zmanjka argumentov začneš z žaljivkami?
Lepo si si nastavil ogledalo.
Boobiz ::
Ne vem katera tema bi bla primerna za to vprašanje, zato bom kar tole ponucal...
Zanima me tole:
Tudi sam imam podoben problem. Namreč vsako jutro ko računalnik zaženem pride do post screena in potem je cel screen blank in monitor se ugasne, ker nima inputa. Šele reset pride do windowsov. Plata ravno tako MSI (b450 tomahawk max) z zadnjim biosom (ki končno pravilno boosta tako kot mora, ker beta ni).
Ima kdo podobne probleme?
I'm drunk, what's your excuse?
Video sem pogledal do polovice.
Če imaš ti enake težave, potem že nisi osamljen primer.
Pravi, da se je to začelo dogajati po nadgradnji na ABBA.
Potem takem zgleda, da bo treba še počakati.
Po drugi strani pa govori, da to ni generalni problem in, da je vse delalo povsem vredu z BIOSom, ki je bil naložen, ko je matično ploščo vzel iz škatle.
Boobiz ::
Jst ne vem, če je blo okej z OG biosom, ker sem še isti dan flashal abba beto zaradi tistega boost sranja (ker je proc boostal 100mhz pod oglaševanim).
Zadnji (stable) bios je rešil problem z boostom, tega problema z nestabilnostjo pa očitno ne.
FlyingBee ::
Meni pa na default msi b450 tomahawk max in 1600 boosta 100 mhz več od oglaševane.
klinker ::
Kake zaljivke...kako ogledalo...in kako mariborsko :))
Failas na polno misko. Zgleda te resnica malo vrze iz tira :D
Zgleda sem edini Ryzen fanboy, ki zna vsaj objektivno komentirat tudi negativno plat...tako da ogledalo si tu nastavljas edino ti ;)
FlyingBee ::
Njemu x470 in 3700x delata točno tako kot je treba, kaj bi zdaj rad od njega?
Gr8t ::
Tale RAM je bil par minut nazaj 59EUR, pa očitno tudi 26.8.:
https://de.camelcamelcamel.com/Crucial-...
Svoje sem spravil na 3600 16-19-14-14-36-56-1T 1.30V. 3600 16-16-16 pomnilnik drugače pride 170EUR.
tRCDRD je res nekam visok, ampak ne vem če je prav veliko razlike med 19+14 in 16+16.
zmaugy 23.8.2019:
Ne verjamem, da je razlog za vožnjo nad omejitvami iskanje prihrankov na času.
Glavni razlog je dolgčas in nesvoboda vožnje za počasnelami.
  • spremenilo: Gr8t ()
klinker ::
FlyingBee je izjavil:
Se en, ki ne zna brat?
Jst od njega prav nic, ce mogoce nisi opazu. On tu neki lapa cez moje komentarje o X570 + Ryzen 3xxx in hoce imet dokaze o tem, ko pa je cel net preplavljen z raznoraznimi tezavami.
Težave so bolj načelne narave, sicer bi ljudje masovno vračali izdelke v trgovine oz. bi obstajale shitliste matičnih.
Nekako v smislu vent na stock hladilniku je preglasen, temperature oz. vcore po svoje delujejo, boost je 2.5% prenizek...
Verjamem, da ima nek promil uporabnikov določene težave, vrniti matično/rame... v tem primeru. Cpu je nedolžen. :)
klinker ::
Tezave so in ocenit tak sistem za rock solid pac ne mores. In ne krivim CPUja, niti plate...kombinacija pa je loterija, kot berem in kaka stvar zna hecat. Vracat zaradi tega nimas kaj, ker zadeva se ne sesuva ipd. Ni pa zadeva popolnoma brezhibna in fanbojem je to tezko priznat, da je stara serija zaneslivejsa od nove.
In to je itak cel point vse te gnojnice tu, ker si je Opeter raje kupu star sistem, kot pa beta stage last gen in sem mu dal prav, vrli komercijalistek D3m se pa temu blazno cudi, ostali fanboji pa z njim v jok :))
tony1 ::
Boobiz je izjavil:
Zanima me tole:
Da ne bo zamere, ampak daj no poišči enega sosedovega mulca, ki je v življenju že sestavil ene 100 računalnikov, in mu porini 20 evrov v žep. Če ne pozna AMDja, ne bo nobene škode, samo nekaj kilometrine mora imeti za sabo.
Tole so čisto normalni simptomi računalnika, ki je bil sestavljen, nato pa začetnih korakov kot so povezava knofa za reset, vštekanje RAMov v prave slote in porihtanje BIOS nastavitev nekdo ni naredil.
FlyingBee ::
Zdaj pa že dvomim, da bom b450 tomahawk max brez problema naslednje leto z r5 4600 nadgradil.
IMO znajo 4000 serijo prestavit v Q1/2021 in na AM5 plošče. Top zen 1000 je bil splavljen februarja 2017, top zen+ 2000 aprila 2018, top zen2 3000 pa oktobra 2019. Nekak jim spolzi, a ne. Ko upoštevaš še trenutne težave s produkcijo na 7nm, in prehod na 7nm EUV.. V 2021 so lahko tudi pionirji z DDR5 ramom.
Vsekakor ne bo ZEN3 zunaj zgolj pol leta po lansiranju 3950X.
Vidiš, v petih letih štiri arhitekture.. Nekje vmes torej mora bit eno sušno leto. ;)
Edit: Ah, ZEN+ je tist grdi raček tukaj.. Mogoče pa dočakaš ZEN3 konec prihodnjega leta, ampak na AM4 ali AM5, to je zdaj vprašanje.
  • spremenil: DarwiN ()
Od kje vam to, da bo serija 4000 na AM5 podnožju?
AMD vseskozi govori drugače.
AMD je obljubil podporo AM4 do leta 2020... Ampak tu zdaj nastane grey area. Če denimo novembra 2020 lansirajo AM5, so s tem prelomili obljubo ali ne? Nope.. In ker 3950X sploh še ni zunaj, je špekulacija na mestu.. 2020 lahko lansirajo še ZEN2 APU na AM4, potem 2020/Q4 ali 2021/Q1 pa AM5.
scipascapa ::
pa sej ni panike, bomo pač na AM4 do 3900x ali kolikor je pač the best AM4 proc....do takrat bo 2600/3500/3600 služil svojemu namenu.
gddr85 ::
sploh ni panike, ker menda itak če vzameš nov cpu, vzameš še novo plato ;)
kuglvinkl ::
gddr85 je izjavil:
Če bom zdej vzel 3600, bom čez pet let 3900x. Nobene nove plate, nisem nor, da bom šel spet celo kišto prefukavat.
Boobiz ::
tony1 je izjavil:
Kaj je point tvojega posta?
Če ne bo pasalo, boš pa 3700x ali 3900x vzel ;)
tony1 ::
Boobiz je izjavil:
tony1 je izjavil:
Vzrok težav je PEBKAC; opisal pa sem tudi rešitev, ki te bo težav rešila.
scipascapa ::
Nice ABBA za B450 in X470. :)
FlyingBee ::
Ne, hvala. Ne rabimo.
FlyingBee ::
D3m je izjavil:
3700x za 230 eur bo sigurno zelo mamljivo naslednje leto, če bo trend isti kot do zdaj.
gddr85 je izjavil:
Kaj pa misliš, da smo morali narediti vsi, ko smo šli na Ryzna? Mogoče pa bosta ddr5 in pcie5 prevagala in bo padla x580 ali x590 namesto samo nadgradnja cpuja.
gddr85 ::
eno je, če greš iz intela na amd, drugo pa, če samo menjaš cpu na obstoječem socketu, kaj prevaga je pa itak odvisno od posameznika ;)
Si kaj probal igre? Kako je napram 7700?
Evo Bee
ABBA verzija za tvojo plato.
https://www.msi.com/Motherboard/support...
  • spremenil: D3m ()
mailer ::
Dokler proizvajalci ne spolirajo biosa za amd plate ga osebno nebi kupil. Kot je povedal v videu, je bolje imeti počasnejši in manj zmogljiv sistem, kot pa hiter in nestabilen. Porše, ki zjutraj ne vžge ko greš na šiht je slabši kot 10 let star clio ki kresne v prvo. Pa naj poštimajo še nenormalno gretje 570 čipsetov, ker tlačenje ventilatorja na consumer plate je passe.
FlyingBee ::
7700k je šel z 144hz monitorjem drugemu srečnemu lastniku :-)
Trenutno sem na slabšem v gaming smislu, ampak imam dobre temelje z ohišjem in napajalnikom, tako da bo sledilo skozi leta še marsikaj. Še kakšna pisalna mizavmes nova pa hi def zvočniki in evga nu audio. Počasi pa bo, se prav nikamur ne mudi.
mailer je izjavil:
Meho7 je pozabil postati še reply od Hardware Unboxed in MSI predstavnikov, ki so diskreditirali JayZ-jev video zaradi uporabe pre-production matične katera ni bila mišljena za delovanje 3900x out of the box.
Žal nas je meho7 zavedel s svojo click bait video retoriko.
P.S.
JayZ je iz YT komentarjev izbrisal HW post in si prislužil velik minus s strani publike, ki so mu to tudi napisali.
Več pa na JayZ jevem twitterju:
https://twitter.com/JayzTwoCents/status...
  • spremenil: D3m ()
LMAO, torej se je na Jayja usul plaz AMD apologetikov.. Klasika!
In po Twitterju sodeč ponovno tudi miselna povezava med AMD fanboyji in trumptardi... Fake news in alternative facts namreč.. Jay odgovarja, da je matična retail in ne pre-production..
Thou shalt not take the name of the AMD in vain... Dajte si to zapisat v podpis amdtardi. Jao.
DarwiN je izjavil:
Niti enkrat nisi napisal MSI, kar je to izključno njihova napaka.
Včasih mi deluje, da ima AMD v lasti vse AIB proizvajalce. Zahvala gre seveda tebi podobnim.
  • spremenil: D3m ()
418 / 629
