AMD ZEN - nova X86 Jedra
scipascapa ::
my bad, oba imata cooler.
AMD Wraith Spire (RGB programmable LED with compatible motherboards) AMD Ryzen™ 7 2700
AMD Ryzen™ 7 1700
razlika je tudi v performancu
klinker ::
Razlika je v marsicem
AapocalypseE ::
ziga1990 ::
1700 je zakon sploh ga nisem še navil pa dela bp
AapocalypseE ::
Ryzen itak zmaga p/p.
Ahim ::
iloveboobz je izjavil:
Ahim je izjavil:
Treer je izjavil:
Kot sem predvidel, ta Vega 3 je isti drek kot Intelov 630 (torej za gaming ne sploh), cpu del je pa dosti slabši od vseh 4 nitnih Pentiumov, lol
Itak, Pentium G5600 best buy!!!
Aja ne, za 10 evrov manj se dobi vec kot 2x hitrejsi 2200G ... :))
ahem
https://geizhals.eu/intel-pentium-gold-...
Ti si prilepil povezavo do G5400 tam, kjer je bilo govora o G5600 in 2200G ... zakaj ze?
klinker ::
200Mhz manj, sicer enak proc.
Oba sta cheapshit in ne vem zakaj merit e-tica se tu ;((
Vas res teh 10-20% razlike tolko na rit mece al kaj :))
Predator X ::
CPU perf je podoben med 200GE in Pentiumi. GPU je na strani AMD-ja prav tako tudi poraba.
AapocalypseE ::
RTX 2080 and 2080Ti on Ryzen... will it bottleneck??
Tole bo verjetno zanimivo branje.
Up until fairly recently, most home systems that had 2-8 cores were in the position where all the cores could be treated exactly the same - they had the same characteristics, the same main memory latency, and the same access to all the resources in the system as any other core. Over time, initially with dual socket systems for the early adopters, but now with processors like Threadripper, not all resources are created equal. In order to get the most of the system, it relies on having a dedicated scheduler to understand the resources available and distribute work accordingly.
louser ::
AapocalypseE je izjavil:
Nisem gledal, ampak zihr bottlenecka grafa.
  • spremenilo: louser ()
FireSnake je izjavil:
To pisanje je samo ilustracija, kako daleč za časom je softverski ekosistem in kako daleč naprej je hardverski. V hardveru imaš take numa sisteme že več kot dve desetletji, pa jih windowsi še kar trmasto ignorirajo. Ne vem, windows znalci, je windows server kaj bolj kulturen tu?
Poleg tega se v hw svetu pojavljajo še asimetrična cpu jedra, npr. armov big.LITTLE, kar dodaja še eno dimenzijo v problem. Poleg tega nas fizika sili, da trenutno arhitekturo statičnih compute enot, ki jih hranimo s podatki od zunaj, obrnemo na glavo in ustvarimo statična polja podatkov, na katere po potrebi pripenjamo problemu primerno compute enoto. Npr. HPEjev "the machine".
Izgleda, da je prihodnost v orkestraciji množice majhnih OSov z enakim API in ABI, a z nujno zelo različno implementacijo, ker bodo upravljali različne namenske compute procesorje, pripete na isto polje podatkov. Linux lahko evolvira v nekaj takega, Windows pa ... dvomim. Zna pa MS Research naumiti kaj zanimivega, kar redno počno.
AapocalypseE ::
louser je izjavil:
Rdeči bodo raje izpustili ta video :))
louser je izjavil:
Res je. Se manjse razlike so bile, kot smo govorili. Kako grozno:)
AapocalypseE ::
Moraš tudi poslušat video, ne samo gledat ;)
DamijanD ::
@pegasus: zanimiv članek na temo winsov: se ukvarjajo tudi z big.little. Zanimiva je prva slikica :D
  • spremenilo: DamijanD ()
Neke brezvezne trditve, ki jih ni mel s cem podpreti, me niso zanimale. Cifre, ki jih je kazal, so bile jasne.
AapocalypseE ::
Saj je lepo vidno in slišno, da bremza, Intel pa še ma fora.
Zatiskaj si oči...
Predator X ::
Zatiskaj si oči...
kje ima že fore?
AapocalypseE ::
Ne ŽE, ŠE!
Predator X ::
Dejmo za primerjavo FC5
i7 8700K
1080p : 120fps
1440p : 107fps
1080p cpu bottleneck
@DamijanD Hvala, sem z zanimanjem prebral. Torej imajo "processor groups", nič pa ne piše, kako jih kernel definira. Pravtako me moti popolna odsotnost omembe, da niso vsi proci v sistemu sposobni enako hitro komunicirati z vsemi ostalimi in do bank rama, torej razumevanje NUMA topologija. Glede na to, da imajo winsi težave z amdji, delajo to narobe ali pa sploh ne. Ampak vsaj za datacenter kernel si predstavljam, da to enostavno mora delati prav... ker sicer so velike mašine neuporabne. Obstaja kje kak zapis na to temo?
  • spremenil: pegasus ()
Predator X ::
Pa kr pejmo vse benchmarke 1080p i7 8700K 4,7GHz
Metro = CPU bottleck
Rotr = CPU bottleneck
SoTR = CPU bottleneck
Far cry = CPU bottleneck
Kje ima še fore? To, da bo vsak špil bolj za MT in prilagojen ryzenu?
AapocalypseE ::
Maš video in ti lepo obrazloži.
Predator X ::
Sj sm ti ravno povedal, da je cpu bottleneck... razlike je pa 10-15%
AapocalypseE ::
Ryzen bottlenecka 2080 in 2080 Ti še bolj ja.
Kupi in porocaj.
AapocalypseE ::
Ne rabim, ker je test že narejen.
Lahko pa ti, če ne verjameš.
Hoces reci tisti test, ki se strinja s tvojim pogledom?
AapocalypseE ::
Tisti realni, saj veš.
Predator X ::
kakor tudi i7 8700K
in v rotr je celo amd pred intelom čeprav je cpu bottleneck.
Čist v nobenem testu na 1080P ni bil bottleneck GPU pri testih z GTX 2080TI
kuglvinkl ::
A se pricakujejo nove plate z novim Ryznom?
Načeloma ne.
Buggy ::
D3m je izjavil:
Načeloma ne.
boljs da ne, ker racunam na to.
Če že bo do česar karkoli prišlo je mogoče kaj novega od funkcij. Vendar socket AM4 ostane.
Šele z Zen 3 se pričakuje nov socket.
Predator X ::
uradno rečeno - 4 generacije en socket
neuradno pa do ddr5 pcie 4
kuglvinkl ::
Ok, kdaj bo pa ddr5 in pcie4?
Brane3 ::
Verjetno tam nekje 2020...
klinker ::
D3m je izjavil:
Načeloma ne.
Itak da ja.
Vseeno bo pa 3xxx pasal tudi na stare, ceprav kot v primeru 2xxx na 3xx chipsetu, bo kaka omejitev.
kuglvinkl je izjavil:
Zadnji info je bil za Zen 3.
kuglvinkl ::
Ok, kdaj pa je to?
Brane3 ::
Efektivno konec druga pol 2019 oz 2020.
AapocalypseE ::
2019 Zen 2 7nm
2020 Zen 2+
2021 Zen 3
Zen 2+, še zadnji na AM4.
Brane3 je izjavil:
Leta 2019 ne bodo niti proivodnje DDR5 dobro zalafal. Tko, da pozab to. Vsaj eno generacijo pozneje bo to.
kuglvinkl ::
Skratka, zen 2 ni cist tik pred novo thenologijo in je smiseln nakup. Thnx
Predator X ::
upgrade
AapocalypseE ::
Zanimivo, da toliko vpliva sprememba iz 34 na 28.
klinker ::
AMDjevi CPUji so od vedno imeli radi hitre rame, oz. niso marali pocasnih. Ni to specifika Ryzena, ampak vseh njihovih procesorjev.
Predator X ::
Odvisno od aplikacije/igre itd.
Vsak sistem bo hitrejši, če bo latenca nižja in več bandwidtha.
