Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
scipascapa ::
my bad, oba imata cooler.
AMD Wraith Spire (RGB programmable LED with compatible motherboards) AMD Ryzen™ 7 2700
AMD Ryzen™ 7 1700
AMD Ryzen™ 7 1700
AapocalypseE ::
1700 je tudi kar nekaj cenejši od 2700
https://www.sestavi.si/index.php/item/d...
ziga1990 ::
1700 je zakon sploh ga nisem še navil pa dela bp
Ahim ::
iloveboobz je izjavil:
Kot sem predvidel, ta Vega 3 je isti drek kot Intelov 630 (torej za gaming ne sploh), cpu del je pa dosti slabši od vseh 4 nitnih Pentiumov, lol
Itak, Pentium G5600 best buy!!!
Aja ne, za 10 evrov manj se dobi vec kot 2x hitrejsi 2200G ...![]()
ahem
https://geizhals.eu/intel-pentium-gold-...
Ti si prilepil povezavo do G5400 tam, kjer je bilo govora o G5600 in 2200G ... zakaj ze?
klinker ::
200Mhz manj, sicer enak proc.
Oba sta cheapshit in ne vem zakaj merit e-tica se tu
Vas res teh 10-20% razlike tolko na rit mece al kaj
Predator X ::
CPU perf je podoben med 200GE in Pentiumi. GPU je na strani AMD-ja prav tako tudi poraba.
Tole bo verjetno zanimivo branje.
Up until fairly recently, most home systems that had 2-8 cores were in the position where all the cores could be treated exactly the same - they had the same characteristics, the same main memory latency, and the same access to all the resources in the system as any other core. Over time, initially with dual socket systems for the early adopters, but now with processors like Threadripper, not all resources are created equal. In order to get the most of the system, it relies on having a dedicated scheduler to understand the resources available and distribute work accordingly.
louser ::
AapocalypseE je izjavil:
RTX 2080 and 2080Ti on Ryzen... will it bottleneck??
Nisem gledal, ampak zihr bottlenecka grafa.
- spremenilo: louser ()
To pisanje je samo ilustracija, kako daleč za časom je softverski ekosistem in kako daleč naprej je hardverski. V hardveru imaš take numa sisteme že več kot dve desetletji, pa jih windowsi še kar trmasto ignorirajo. Ne vem, windows znalci, je windows server kaj bolj kulturen tu?
Poleg tega se v hw svetu pojavljajo še asimetrična cpu jedra, npr. armov big.LITTLE, kar dodaja še eno dimenzijo v problem. Poleg tega nas fizika sili, da trenutno arhitekturo statičnih compute enot, ki jih hranimo s podatki od zunaj, obrnemo na glavo in ustvarimo statična polja podatkov, na katere po potrebi pripenjamo problemu primerno compute enoto. Npr. HPEjev "the machine".
Izgleda, da je prihodnost v orkestraciji množice majhnih OSov z enakim API in ABI, a z nujno zelo različno implementacijo, ker bodo upravljali različne namenske compute procesorje, pripete na isto polje podatkov. Linux lahko evolvira v nekaj takega, Windows pa ... dvomim. Zna pa MS Research naumiti kaj zanimivega, kar redno počno.
AapocalypseE ::
Rdeči bodo raje izpustili ta video
Rdeči bodo raje izpustili ta video![]()
Res je. Se manjse razlike so bile, kot smo govorili. Kako grozno:)
DamijanD ::
@pegasus: zanimiv članek na temo winsov: se ukvarjajo tudi z big.little. Zanimiva je prva slikica
- spremenilo: DamijanD ()
Moraš tudi poslušat video, ne samo gledat![]()
Neke brezvezne trditve, ki jih ni mel s cem podpreti, me niso zanimale. Cifre, ki jih je kazal, so bile jasne.
Predator X ::
Saj je lepo vidno in slišno, da bremza, Intel pa še ma fora.
Zatiskaj si oči...
kje ima že fore?
@DamijanD Hvala, sem z zanimanjem prebral. Torej imajo "processor groups", nič pa ne piše, kako jih kernel definira. Pravtako me moti popolna odsotnost omembe, da niso vsi proci v sistemu sposobni enako hitro komunicirati z vsemi ostalimi in do bank rama, torej razumevanje NUMA topologija. Glede na to, da imajo winsi težave z amdji, delajo to narobe ali pa sploh ne. Ampak vsaj za datacenter kernel si predstavljam, da to enostavno mora delati prav... ker sicer so velike mašine neuporabne. Obstaja kje kak zapis na to temo?
- spremenil: pegasus ()
Predator X ::
Pa kr pejmo vse benchmarke 1080p i7 8700K 4,7GHz
Metro = CPU bottleck
Rotr = CPU bottleneck
SoTR = CPU bottleneck
Far cry = CPU bottleneck
Kje ima še fore? To, da bo vsak špil bolj za MT in prilagojen ryzenu?
Predator X ::
Maš video in ti lepo obrazloži.
Sj sm ti ravno povedal, da je cpu bottleneck... razlike je pa 10-15%
- spremenilo: Predator X ()
Predator X ::
Ryzen bottlenecka 2080 in 2080 Ti še bolj ja.
kakor tudi i7 8700K
in v rotr je celo amd pred intelom čeprav je cpu bottleneck.
Čist v nobenem testu na 1080P ni bil bottleneck GPU pri testih z GTX 2080TI
Če že bo do česar karkoli prišlo je mogoče kaj novega od funkcij. Vendar socket AM4 ostane.
Šele z Zen 3 se pričakuje nov socket.
klinker ::
AapocalypseE ::
2019 Zen 2 7nm
2020 Zen 2+
2021 Zen 3
Zen 2+, še zadnji na AM4.
2020 Zen 2+
2021 Zen 3
- spremenil: AapocalypseE ()
kuglvinkl ::
Skratka, zen 2 ni cist tik pred novo thenologijo in je smiseln nakup. Thnx
Predator X ::
klinker ::
AMDjevi CPUji so od vedno imeli radi hitre rame, oz. niso marali pocasnih. Ni to specifika Ryzena, ampak vseh njihovih procesorjev.
Predator X ::
Odvisno od aplikacije/igre itd.
Vsak sistem bo hitrejši, če bo latenca nižja in več bandwidtha.
