Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
300mhz pac pa nizji ipc in si tamtam.
v resnici je vazna samo avarage frekvenca v nekem workloadu, kar se pac ne da razbrat iz base/turbo frekvence.
Predator X ::
iloveboobz je izjavil:
Go bo delal GPU na polno kr raj glej base freq.
ryzen ima prednost 1C/2T.
Predvsem imajo Intelovi U procesorji trenutno 500% marže, tako da za kupce bo tle tako ali tkao revolucija. Za AMD pa denar.
Predator X je izjavil:
sj tudi pri amd bo frekvenca gpuja padla konkretno, ko bodo delala zram cpu jedra.
D3m0r4l1z3d ::
Vega gpu, lol, 15w my ass
Heavy ::
D3m0r4l1z3d je izjavil:
Okleščena arhitektura. Za laptop procesor ni potrebe, da bi se boril proti namizni 1080ti.
#TeamFelix
D3m0r4l1z3d ::
Ja, že, samo eni privlečejo na plan dober Ryzen, na shity Vego pa pozabijo v tej enačbi.
The response given by Kevin Lensing, AMD's Corporate VP of the Client Business Unit, was that so many of the design ideas that AMD wanted to put into the original desktop Ryzen (but couldn't due to time) eventually ended up in Ryzen Mobile, such as the updated precision boost. While there are no architectural changes to Zen to warrant a next-generation microarchitecture name, this version of Ryzen's periphery (i.e. the power) was more in-line with an original vision and had to be presented as such. This is why we have Ryzen 7 2700U, rather than a Ryzen 7 1700U.
D3m0r4l1z3d ::
Marketinški futter.
Grey ::
S 15W hitrejši od 91W i5 7600K v Cinebench? What sort of trickery is this?
Uff...Ryzen laptop bo zakon. Me zanima, kaj od teh power optimizacij se bo preneslo na februarski updejt desktop procesorjev.
- spremenilo: Grey ()
Predator X ::
Delnica AMDja je padla zaradi napovedi za Q4..., mogoče jim pa uspe naredit kakšen dober deal, pa bi lahko hitr vidl delnico blizu 17-19$.
D3m0r4l1z3d ::
Kje so zdaj teorije zarote kako cb15 ni na strani Intela in kakšna krivica je to :-)
Grey ::
V bistvu je tole potem kaj, R5 2500X? Se pravi desktop varianta februarja verjetno v območju 45W-65W pri 3.8 GHz - 4 GHz? Zanimivo.
Ni ne na strani Intela ne na strani AMDja, hvalabogu eden redkih. Zelo lepo skalira s frekvenco in številom threadov.
To je zanimivo branje.
Zgodbe, ki so se dogajale zadaj.
Threadripperja so naredili zaposleni v prostem času!!!
Res, kapo dol!
Sem pa tudi sam bral, da imajo hudičevo dobre ideje, kaj bodo še vtaknili v naslednjo generacijo (Ryzen 2 in Ryzen 3).
Prav tako so rekli, da so morali izbirati: 6 mesecev zamude, ali 30% (številka ni točna, iz glave) performansa.
Odločili so se, da spilijo do konca.
Noro, se bere, kot kriminalka :D
Pa, a si ti normaln?
Delnica lahko pade tudi do 8USD!
Januarja pa nekje 16 (pred kratkim so bile kupljene opcije za 16 - potečejo januarja).
Od kje tebi 17 - 19?
A spremljaš delniški trg? Jaz ga ... dnevno.
Torej, od kje ti informacija?
- predlagalo izbris: D3m0r4l1z3d ()
To na blef seka.
Recimo če bo imel FireSnake srečo in bo delnica ob ugodnih razmerah prilezla do 20$ v roku 1-2 let.
Kaj je pa Anymala zmotilo, da predlaga izbris?
- spremenil: D3m ()
To mene ne gane.
Pišem pač o tem, o čemer imam informacije.
Ob špici, ki se bo pojavila nekje od januarja do marca 2018 (nekje 16USD), bom prodal.
Se je pa AMD, zaradi svoje volatilnosti, izkazal za lepo priložnost za zaslužek.
- spremenilo: FireSnake ()
Predator X ::
To na blef seka.
vpraš ata googla, sej firesnake ve in spremlja vse. Drgač pa boš hitr opazu za delnico (min - 5$, medium - 14$, max - 22$). Men se zdi da ti nekaj na blef sekaš.
http://money.cnn.com/quote/forecast/for...
Je pa še kr ene par člankov glede tega.
- predlagal izbris: SuperVeloce ()
put your money where your mouth is. Pa investiraj kak G v amd, ce verjames v tako rast.
To na blef seka.
A ti sploh veš, kaj si linkal?
Daj nam razloži, prosim (ne skopari z besedami, kar razpiši se).
Intel najvijacka je pizabila, kolk vedne so njihovi iGPU
Predator X ::
To na blef seka.
Nisi sposoben sam razumeti strani? Kar je važno je to, da sem jaz "napovedal" 17-19$ kmalu. Če boš malce prebrskal po googlu boš videl tudi napovedi med 17-19$. Skratka kar tistle link pomeni, da nisem rekel nič nemogočega. Sicer pa, če AMD dobi dober "mobile" deal ter pinnacle pokaže zobe kavici zna pridt tud višje.
Še enkrat:
kakorkoli praviš, da že dolgo časa spremljaš delnice... potem sigurno veš, da so napovedi ena najlažji stvari. /s
brezveze upat na amd delnice; mas z kaksno bol stabilno kriptovaluto vec sans da si podvojis kes.
Ravno zato, ker dobro razumem kaj si linkal sem napisal to, kar sem.
Razlagal ti ne bom, ker je preveč pisanja in ni vredno (pa tudi efekta ne bi bilo. Trguješ tako ali tako ne.).
Svetujem ti smo, da se nehaš smešiti in ostaneš pri tem kako je treba VRMje hladiti ko se navija
Kripto valute in stabilnost v enem stavku?
Katera kripto valuta je stabilna?
Za nazaj gledat je brezpredmetno (po vojni so lahko vsi generali).
Zato je tak nasvet povsem brezpredmeten.
Še razlaga glede stabilnosti?
Edit: pa "obračam" tudi kripto valute.
že to da je market cap bitcoina nekje 10x večji pove dost. Pa amdjov bi bil še ziher ene 5x manjši če bi bil ZEN turd. Tako da ja, je z amd delnicami večji gamble kot z bitcoinmom, žal.
Od kdaj je market capitalization relevanten za perpektivo delnice (in kako se da z njo zaslužiti)?
Koliko si že trejdal?
Z enim, ali z drugim?
Govoriš kot, da je to zelo preprosto.
Čudno, da potem niso že vsi bogati, ane?
še vedno pa čakamo na odgovor o stabilnosti.
chipshit pump&dump coin z 50k market capa se bo najbrž veliko hitrej sesul blizu nule čez noč kot pa nekaj kar je bitcoin ki ma kapitalizacijo ene manjše države.
Again, če primerjamo amd in bitcoin je slednji bolj stabilen. Ni pa nič od tega blue chip stabilnost jasno.
no risk no reward.
- spremenil: iloveboobz ()
Kdo, hojnik?
Človek ima komaj 24 let. Saj se mu izkušnje nabirajo.
No, na tem mestu lahko mirno zaključimo debato (ker nismo v temi: "blodnje").
Lej, če zaupaš amdju, pač zaupaš. Jebat ga.
Ko tako pade, kot je sedaj (11.84USD) in še bo padalo ... se bom vsekakor še "oborožil" z njimi.
Zame idealne scenarij, če pade na 8
Fun fact: tudi jaz bom zamenjal prenosnika v naslednjem letu.
Po videnem, bom vzel mobile Ryzen.
Če se zadeva z delnicami izteče, kot predvidevam, bo ravno toliko profita (po tem, ko plačam davek), da mi bo AMDjeva delnica kupila AMDjev prenosnik.
Drugače bom pa nekaj zraven primaknil.
Ahhhh ja. No more cheap AMD.
Single-channel? Why not dual?
- spremenil: D3m ()
Verjetno še bo opcija.
Snake sedaj veselo kupuje.
- spremenil: D3m ()
D3m0r4l1z3d ::
Kakšno leto bo moralo miniti, da se poporodne težave odpravi in cene normalizira.
Jutri je pri nas praznik, borza bo pa odprta.
Nekaj bom kupil, ker ne vem kje je minimum.
Naj bi bil pri 8, a zagotovo ne vemo.
D3m0r4l1z3d ::
8 it is.
Predator X ::
TheStilt:
RZN vs. CFL vs. SKL-X in X265 2.5+31:
RZN: /w AVX2 = 100.00%, /wo AVX2 = 105.21%
CFL: /w AVX2 = 130.61%, /wo AVX2 = 101.13%
SKL-X: w/ AVX2 = 135.47%, /wo AVX2 = 105.21%
