AMD ZEN - nova X86 Jedra
mahone ::
Razlika v ceni med R3 4/4 ter R5 4/8 je manj kot 30€ medtem ko je R5 6/12 drazji za vsaj 80€. Previsoko ceno so postavili R3 seriji - under 100€ bi morali biti
A ni folk govoru, da je gameplay bolj smooth na Ryzen?
Je smooth. Zakaj?
Cena se še lahko zniža, res pa je, da odsotnost integriranega gpu-ja predstavlja veliko pomanjkljivost za home%office segment.
Če bodo 4C Ryzen APU-ji po 150-170€ bo tole velik flop...ajd, 90€ je še OK. Soliden pentium z igpu-jem je 70€ pri nas npr.
Gameplay je stvar optimizacij, večina iger pa je optimiziranih za 4C.
Torej, po steam statistikah je delež 2C in 4C cpujev skupaj približno 94%.
Some extra notes:
How to reproduce the segmentation faults of Ryzen bug:
http://fujii.github.io/2017/06/23/how-t...
Some users in Japan have done analysis and think it's address shift errata by 64 bytes. If so, it is a hardware defect.
Turning on/off certain hardware features as some people may suggest only reduces the chances of encountering the issue and may introduce other unwanted effects like lower performance or compromised security.
Issue was initially encountered with GCC on Linux, but was later found to also occur on the Windows Linux subsystem. Other *Nixes and BSD has also observed the issue.
Stock CPU and RAM and even ECC RAM does not eliminate the issue.
Quote:
ouch ;((
It's been reported that sporadic segmentation faults were occurred on Linux/Ryzen under heavy CPU loads especially during parallel-compiling large OpenSource code such as Linux kernel, Mesa, LLVM, Chromium and WebKit. But, it's difficult to reproduce the segmentation faults due to the low probability and the uncleared reproducibility conditions. I'd like to summarize the best practices in this post.
Iz muhe delaš slona. As usual.
tut l3 bug je bil kao ful malo verjeten, pa so vseeno dal bios patche in nov stepping.
Misliš TLB?
Iz časa Phenom I.
filip007 ::
Sem mislil, da je AMD kaj boljši, pa samo lovi Core i3.
Zero games, zero talk.
Predator X ::
filip007 je izjavil:
dejno nehi trollat.
Točno zato bo zdej mainstream intel prinesel 6 jeder, in 6C/6T na i5 in 4C/8T na i3... samo zaradi tega, ker AMD komaj lovi i3.
r3 pač ni na nivoju i5ke, zato tudi taka cena
dolenc ::
r3 pač ni na nivoju i3ke, zato tudi taka cena
Sem ti mal popravu :P
Drugače pa bodo tele zen procesorji zakon, naslednja revizija, do takrat bodo že vse popravli, če še mal dodajo in obdržijo/zmanjšajo ceno. Vmes pa še cene ddr4 padejo, pa bo čas za nabavt.
FiLiPiNKO ::
Momvrste specialci :D 3 zalični modeli navedeni pri enem cpuju, kaj se torej sploh prodaja?
https://www.mimovrste.com/procesorji/am...
2 1200, 3 1200 ali 3 1300X ? :D Marsi kdo ne bo vedel :D
FiLiPiNKO (Fsegula62)
Ryzen 2 1200 je verjetno typo/missmanagement.
Zanimiv test:
Pokaže npr., so procesorji med 100€ in 200€ isti šmorn z GTX 1060GTX, štirijedernik lepo deluje z 1070GTX...
D3m0r4l1z3d ::
Cene se glede na performance določajo, razni outrage-i v nekaterih aplikacijah pa so tudi že stara fora. Na mf so spustili ceno r7 1700 na 284eur, zakaj, saj se dobro prodaja tudi za 300eur?
mahone je izjavil:
Za 144hz gaming je 7700k boljša izbira, zato.
Predator X ::
iloveboobz je izjavil:
Je ja.
Intel fanboys...
D3m0r4l1z3d ::
Le linki štejejo, tvoja želja ne.
Predator X je izjavil:
Je ja.
Intel fanboys...
gaming benchi se ne strinjajo s tabo, pravtako ne pricing.
Predator X ::
D3m0r4l1z3d je izjavil:
Sej to.
http://www.anandtech.com/show/11658/the...
Je ja.
Intel fanboys...
Tisti tvoji "gaming" benhcmarki.
R5 1600 je na nivoju i7 7800X
govora je o r3 1200, ki pac ni kos i5 v igrah.
Moram reči da je Zen na low end enako revolucijo naredil kot high end. Niti najmanjšega razloga ni, da bi kupil 200EUR Intel i5 sedaj ko imaš Ryzen 1300X, ker je i5 komaj eno malenkost hitrejši, dražji pa za 50%+:
i3 je sicer v nekaterih zadevah izenačen z Ryzen 3, v nekaterih eno malenkost hitrejši(single thread), ampak pri je pri multithread jasno razlika tako ogromna da i3 seveda ni za kupit.
Edino kjer Intel celo ima kaj malega za pokazat je 250EUR+ range, pa še to mora spustiti še vsaj za 20% cene, da bo izenačen. Dobro izjema je recimo 100FPS + gaming, tam se še recimo Intel izbere.
Intel bo pač moral i3 narediti 4 jedrne ter vse i7 8 jedrne, nima druge izbire.
Več kot 1300X za 60FPS gamanje ne potrebuješ, več kupiš recimo za bolj "future proof zadevo", dejanske potrebe pa trenutno ni.
  • spremenil: Lonsarg ()
intel rabi i3ke z 4 jedri, amd pa r3 z grafifo. Velik del segmenta se ven spusti, ce nimas igpuja
Predator X ::
Hojnikb že spet trolla...
R3 1200 vs i5 7400 ~10% avg razlike?
LoL, res je kakšen špil slabo dela z Ryzenom+GTX, nevem zakj ni dodal še AMD grafično pa bi vidl.
z amd bi blo se slabse.
lets face it, r3 brez OCja pac ni primerljiv z i5. Pride blizu, to je pa to. Je pa insane value z 107€ tko da tu ni nobenga dvoma kaj kupit.
Predator X ::
Kako da ni? Če je na nivoju i5 7400.
v kaksnem cinebenchu mogoce. dodaj dobro grafiko, pa i5 kr lepo potegne naprej v vecini spilov. Se vedno ga pa to ne nardi dober value, dalec od tega.
Predator X ::
Kje že? No dej primer.
glej zgornji video. Tvoj najljubsi avstralc..
Predator X ::
Sje gledam in vidim samo dva špila, ki zaradi GTX kažeta malce razlike.
Poglej tole,
vs
Seprav je imel na stock okol 10% slabš perf?
4GHz bi moral imet ~620p CBR15
benhci
in natosledi preobrat
hmm
Pa se nekaj za glodat; kaj se bol splaca za non gaming kisto ? ;)
https://www.mindfactory.de/shopping_car...
ali ryzen
+ r5 230 za cca 30€
Predator X ::
Ampak, ti bi vzel tole primerjavo
ampak nato sledi "šok"
ali ryzen
+ r5 230 za cca 30€
Noben stvar od tega v non gaming kišto, ker je pentium čist dovolj. Dej si tsit napis nazaj, če si "dec"
super fina primerjava z grafikami, ki jih sploh ni za dobit....
a dej no, vse non gaming masine so kr naenkrat samo za office pa word ?
kdo je zdaj zrel za sramotilni podpis..
Predator X ::
Ahaha:)):)):))
Ti očitno nisi.
Če bi bil Ryzen tako počasen kot govorite, bi INTEL naprej spal.
sj nihce ne govori, da je ryzen pocasen. Ampak da bo najcenejši r3 tekmoval z i5 in i7 direktno je pač blodnja vas rdečk. V resnici pa čisto lepo poseka konkurenco v svojem cenovnem rangu (i3) in se lepo približa ali izenači rangu višje (i5) kar je pač bilo za pričakovat.
Predator X ::
To je troll na slotechu.
R3 tekmuje z i5, zato bomo dobil i3 4C/4T. Tud Intel to vidi.
ce bi tekmoval z i5, nebi koštal skor pol manj. Bi amd kr lepo dvignu cene. Tko je pa v večini benchov kr lepo med i3 in i5, po ceni pa z i3, kar ga nardi bolši value.
Razn seveda če skozi rdeča očala vidiš druge bench številke.
Čaki v istem stavku si rekel da je r3 izenačen z entry i5, drugič pa da je to blodnja?
r3 1300X ne tekmuje z entry i5, pač pa jih poje, ker je za skoraj isto performanso močno cenejši. Vsaj taka je moja definicija "poje", ker cena je poglavitna pri odločanju.
Skratka kregamo se zgolj o semantiki in pomenu za Intela, o tem da je r3 1300X izenačen z entry i5 se očitno strinjamo(ker pač tako pravijo benchi).
da se ponekod približa (poseka praktično nikjer) je to za tebe kr acress the board izenačitev ? Enim očitno branje dela hude probleme.
tako jih poje, da praktično v nobenem špilu ne poseka i5ke. Pa tudi v benchih nikjer konkretno ne povede. Poje jih samo v p/p. Velika razlika
p/p je edina relvantna metrika pri odločanju o nakupu, ena in edina. Kupiti nek procesor, ker je 10% bolši brez ozira na to, da je 50% dražji je neumnost 1. klase.
Lonsarg je izjavil:
p/p je edina relvantna metrika pri odločanju o nakupu, ena in edina, kupiti nek procesor, ker je 10% bolši brez ozira na to, da je 50% dražji ne neumnost 1. klase.
super, torej vsi kupimo g4560.
Predator X ::
Sej maš anandtech številke, kaj še rabiš?
R3 1200/1300X sta na nivoju i5 7400/7500.
Nimam rdečih očal, kakor tudi časa ne, da bi se še naprej obadal s tabo. Si kot 5 letn otrok, ki mora zmeraj dobit tisto kar hoče. Glede nato, da si izgubil stave bi lahko imel malce več rešpekta, obljubljal si nekaj česar se nemoreš držat (podpis) zaradi lastne sramote.
Lonsarg je izjavil:
Nikoli neboš imel prav na tem forumu, ker je hojnikb 5 letn troll... lep dan še naprej.
ne, nista. Prideta zelo blizu ponekod, nista pa na nivoju. Vsaj ne out of the box.
Sj amd ni neumen, da bi svoje proce prodajal tako pod ceno. Cene se postavijo tako, da imajo več performanca kot konkurenca za podoben dnar. In točno to jim je uspelo.
Btw, direktno primerjat po ceni (sploh z 1300x) je tko brezveze. i5ke majo grafiko in kuler, 1300x nima nič od tega. Dodaj oboje (recimo da ne igraš iger) pa si z ceno tamtam.
Sta 10% slabša ter imata enako število threadov in jeder. To je pa katerikoli poljubni definiciji isti nivo.
Predator X ::
Zelo se sramuje, da je govoril za ZENa, da ne bo obstajal 3+3 konfig ali 2+2 itd... pač samo 4+0 in 4+4.
Zdej se je pa izkazal ravno obratno, da je ZEN najbolj profitabilen CPU ever. To ga muči. 8-)
Lonsarg je izjavil:
pentium je pa pol cenej k 1200 pa tut samo 10% slabši. Torej amd out ?
Lonsarg je izjavil:
Pentium g je cirka 30% slabši, + pol manj jeder. To je kar konkretna razlika, vsaj en nivo.
in še vedno mi je žal, da nisem mel prav. Bi blo bolje za vse.
no, 4+0 konfig je še pride.
Lonsarg je izjavil:
Lonsarg je izjavil:
pa pol cenej, torej še vedno bolši value. Šteje performance, ne jedra. In izkaže se, da pentium pride zelo blizu 1200, pač odvisno od špila. Je res vredno dat x2 več a 10fps ?
Za marsikoga ne, dejstvo je, da je razlika med Pentium G in 1200 za ene faktor 3 večja, kot razlika med 1300X in i5 7400, ki sta praktično izenačega, tu ne gre za 10FPS več, tu gre za 2 FPS več.
In če se še enkrat obrnemo na avstralca; z grafiko ki spada zram teh cpujev med 1200 in g4560 praktično ni razlik, torej še enkrat; zakaj x2 več za cpu ?
Boš stal za to izjavo?
Lonsarg je izjavil:
laž.
Da, bi stal za to izjavo. R3 1200 jaz ne kupim nikoli. Trenutno so per-moja izjava vredni nakupa zgolj tile procesorji do 250€:
- Pentium G
- R3 1300X
- R5 1600X
Vsi drugi so zaradi bolše p/p ponudbe v istem rangu nevredni nakupa.
ravno X modeli so zgrešen nakup, ker poleg višje cene samga proca rabiš tudi kuler. Torej +40€ za kaj ? 10% ?
Oz v primeru 1600x si v buli vsaj 50€ (+30€ za proc in ene 20e za kuler). Nesmisel.
