Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
Predator X ::
StreetRacer vzame raje en i5 kaby, nardi oc dream in bo happy, več jedr bi bilo enostavno too much za njega ;)
Mamin sinko pač ne razume. Vpikne se v eno stvar, za katero zadeva že v prvi vrsti ni namenjena. Ne potegne mu, da imamo eni računalnik za resno delo.
Jah, glej ryzen bo imel vrjetn še nekaj težav z SMTjem in igrcami. To je nekak pričakovano.
- predlagalo izbris: Vanadium ()
dottor ::
Se strinjam, da R7 ni za igre. Tadeva zaživi šele v aplikacijah kjer znajo izkoristit takšno št. jeder/nit ali ko delaš v več aplikacijah istočasno.
V Integer rešitvah ja.
FPU niti ne.
Sedaj pa ponuja konkurenčnost pri obeh.
FPU niti ne.
dottor ::
Jaz bi predvsem počakal da porihtajo ram frekvence, ker 3GHz ram bi bil tu sweet. Treba videt kako se navijajo (sploh 1700/X).
youPlonker ::
Nekaj sem opazil ob primerjavi dveh youtube reviewov:
LinusTechTips: Intel Core i7-6900K 1635 Cinebench multi-threaded,
Hardware Unboxed: Intel Core i7-6900K 1464 Cinebench multi-threaded
Ali nekateri reviewerji ne delajo fer primerjave, če Intele sparijo s high frequency rami ali kaj?
AapocalypseE ::
Saj se že ve kako se navijajo vsi R7
The R7 1800X gave up the ghost at an applied 4050MHz using just shy of 1.45v to the core with the load line calibration set to extreme. The R7 1700X was the first surprise, as it would only hit an applied 4GHz regardless of the voltage used. I even pushed the voltage to 1.5v but it was a 4Ghz only processor. The big surprise was that the least expensive processor, the R7 1700, was the best overclocker in the group. It is the lowest TDP chip of the group and it responded with a stable applied 4.1GHz using 1.425v with the load line calibration set to high.
ko mu bo laptop premalo ;)
Ko bodo ponujali Raven Ridge za laptope.
En Lenovo ThinkPad z Zen + Vega/Polaris in vzamem.
P.S.
While Zen is initially a high-performance x86 core at heart, it is designed to scale all the way from notebooks to supercomputers, or from where the Cat cores (such as Jaguar and Puma) were all the way up to the old Opterons and beyond, all with at least +40% IPC.
Owww yeah.
- spremenil: D3m ()
Predator X ::
Te gaming benchmarki ne povedo lihk vsega.
Noben ne testira MPja, vsi imajo fresh install win10 etc.
Kokr sm opazu, da dobi 5-10% boosta z SMT off
AapocalypseE ::
Predator X je izjavil:
Tukaj ti tudi ta tvoj boost ne pomaga
Predator X ::
iloveboobz je izjavil:
zgleda bo i5ka še mal počakala, da se tole mal spolira...
zdej reviewi vsi mečejo naprej IPC, a mal nazaj je digitalfoundry kazal kako i7 3770K 4.5GHz, 2400MHz DDR4 povozi i5 6600K 4.5GHz
PugPlug ::
Za 360€ Ryzen 7 1700 nima kaj velike konkurence. Do 400€ je to TOP procesor tako za igre kot večino resnejših zadev. Je pa res, da bo imel še nekaj poporodnih težav - čez kakšen mesec bo večina njih rešena.
_koki_ ::
A je kdo našu teste z ryzen 7 1700 in b350 ploščo, če gre 1700 na b350 plošči tudi do 4Ghz?
jest10 ::
Hmmm... Vam navdušenje malo pada? Tisti najbolj glasni izpred nekaj dni ste postali nekam zelo umirjeni
Predator X ::
ziga1990 ::
nevem jaz sem se zanimal za ryzena bolj iz principa future proofinga a sedaj če i7 7700k lahko goni gaming 6 let
- spremenil: DarwiN ()
Predator X ::
Torej čakamo naprej? Na 1600X oz. 1400X? Tisto bo prava reč. :)
BTW, hitro prodajte delnice.![]()
bodo še samo še gor.
https://finance.yahoo.com/quote/AMD?p=A...
Recommendation trends na desni spodaj pravi, da klobasaš bedaije
- spremenilo: FireSnake ()
Bwaze6 ::
TechPowerUp next article:
Ryzen Hype Train: Crashed
Eni pa zganjajo dramo... No, ampak to, da se 1800X sploh ne bo overclockal čez svoj turbo boost, je bilo res nepričakovano. V bistvu so se zafrknili vsi, ki niso kupili 1700 (ne-X).
Dober productivity napram Intelu.
Good job.
Nekateri vidijo samo igre in posledično panika.
Delnice bodo šle gor.
Good job.
- spremenil: D3m ()
We see a lot of benchmark results where AMD is clearly equal or above Intel's HEDT parts in both ST and MT. However there are a few edge cases where AMD is lacking behind 10-20% still, even to Broadwell. These edge cases are difficult to anticipate, and can stem from unoptimized code. One of the benefits of Intel's big R&D juggernaut is the ability to process those edge cases, through prefetch, memory algorithms, and extensive testing. So despite the best will, there's still a large element to having a substantial budget to hire 300+ more engineers to cater for that, which is something AMD wasn't able for Zen or Ryzen.
Več ali manj vsi hvalijo nov procesor. Porabo in zmogljivost. Zdej je treba počakat kako se bo odzval še trg.
Jaz mislim da smo z to novo serijo vsi zmagali. Za resno delo bojo jemali pač 1800x, za špile pa 1700.
- spremenilo: Telbanc ()
SuperVeloce ::
Lepo, bolj ali manj se je držalo tistih najbolj verjetnih napovedi. IPC broadwell+, check. Relativno na intel nižje cene, check. Slabo navijanje (krivec arhitektura ali proces, nema veze, ampak verjetno slednje), check.
Nič presenečenj, sem zadovoljen. Če/ko se potrebuje upgrade, oz. bolj verjetneje še en desktop, je ryzen v ožjem izboru, definitivno.
če bi bla kaka easy varjanta za kupit, bi jih že zdavnaj nabavo..
infamous amd senzorji :)
tudi buldi je hladen, a požrešen :)
Ampak temperatura pa samo 56°C
- spremenil: iloveboobz ()
S tem procesorjem ne.
NightHawk ::
To se tebi zdijo reprezentativni rezultati glede na vse review-e, ki si jih pregledal?
AapocalypseE ::
Average fpsje in bullshit benchmark youtube videje gleda samo tisti, ki trolla ali nima pojma.
http://www.gamersnexus.net/hwreviews/28...
Za vse tiste, ki ne vejo za kaj se gre še prilagam video:
- spremenil: AapocalypseE ()
